Nintendo Game Boy Advance SP Power Switch Cover Replacement
  1. Nintendo Game Boy Advance SP Power Switch Cover Replacement, Battery: crwdns2935265:01crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Use a standard Phillips #00 screwdriver to loosen the 4 mm screw that keeps the battery cover attached to the device.
    Quel est le nom du vis svp je l'ai perdu et j'ai pas la référence
    la chaîne de Samarium - crwdns2934203:0crwdne2934203:0
    Bonjour @lachainede96340 D'après les instructions du tutoriel, il s'agit d'une vis Phillips (ou cruciforme) #00 de 4 mm de long. Ces mesures devraient suffire pour trouver une vis de remplacement dans votre stock de vis ou en magasin le cas échéant.
    Claire Miesch -
  2. Nintendo Game Boy Advance SP Power Switch Cover Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Lift the battery cover up and remove it from the device.
    • The screw will remain attached to the battery cover because of Nintendo's design.
  3. Nintendo Game Boy Advance SP Power Switch Cover Replacement: crwdns2935265:03crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Use your fingers or a plastic opening tool to remove the battery from the device.
    • Caution: Please exercise caution when handling the battery. If it appears to be swelling or damaged at all it is considered a fire hazard.
  4. Nintendo Game Boy Advance SP Power Switch Cover Replacement, Back Cover: crwdns2935265:04crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Nintendo Game Boy Advance SP Power Switch Cover Replacement, Back Cover: crwdns2935265:04crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Remove four 6.5 mm screws from the corners of the back cover using a tri-point Y00 screwdriver.
    • Remove two 4.6mm screws from the top-center and bottom-center of the device using a tri-point Y00 screwdriver.
  5. Nintendo Game Boy Advance SP Power Switch Cover Replacement: crwdns2935265:05crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Lift the back cover off of the device.
    • Potential for device damage: These inner components are vulnerable to static electricity. Exercise caution when handling these next steps to prevent damaging the device.
    • Look out for the power switch that can fall out when taking the back cover off.
  6. Nintendo Game Boy Advance SP Power Switch Cover Replacement, Power Switch Cover: crwdns2935265:06crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Nintendo Game Boy Advance SP Power Switch Cover Replacement, Power Switch Cover: crwdns2935265:06crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Lift the power switch cover away from the left side of the device using your fingers or tweezers.
crwdns2935229:017crwdne2935229:0
DJ Pantone
crwdns2935283:001/11/13crwdne2935283:0
1,968 crwdns2915208:0crwdne2915208:0
Cal Poly, Team 17-22, Forte Winter 2013 crwdns2935289:0Cal Poly, Team 17-22, Forte Winter 2013crwdne2935289:0
CPSU-FORTE-W13S17G22
crwdns2935297:041crwdne2935297:0
This doesn't explain anything about how to replace the switch
Michael - crwdns2934203:0crwdne2934203:0
Maybe the guide was for replacing the power switch cover?
Dominick Scheible - crwdns2934203:0crwdne2934203:0
where to buy invidual y00,y0 or y1 bit?
Coola Nillon - crwdns2934203:0crwdne2934203:0
crwdns2936753:030crwdne2936753:0 128
crwdns2942667:0crwdne2942667:0 22,062
