Nintendo Game Boy Advance SP Power Switch Cover Replacement
crwdns2942287:0crwdne2942287:0This guide will walk you through the steps necessary to replace the power switch cover on your Game Boy Advance SP. The power switch of the Game Boy Advance SP is small and attaches to the motherboard itself. For this reason, the device features a much larger cover to help the user turn their device on and off. Follow this guide if your power switch cover is damaged or needs to be swapped out.
- Li‑ion Nintendo Game Boy Advance SP 3.7V 600mAh Batterycrwdns2943225:0crwdne2943225:0crwdns2931591:0Amazoncrwdne2931591:0
crwdns2944105:0crwdne2944105:0
Use a standard Phillips #00 screwdriver to loosen the 4 mm screw that keeps the battery cover attached to the device.
Lift the battery cover up and remove it from the device.
Use your fingers or a plastic opening tool to remove the battery from the device.
Remove four 6.5 mm screws from the corners of the back cover using a tri-point Y00 screwdriver.
Remove two 4.6mm screws from the top-center and bottom-center of the device using a tri-point Y00 screwdriver.
Lift the back cover off of the device.
crwdns2935267:0crwdne2935267:0Tweezers$4.99
Lift the power switch cover away from the left side of the device using your fingers or tweezers.
crwdns2935229:017crwdne2935229:0
This doesn't explain anything about how to replace the switch
Maybe the guide was for replacing the power switch cover?
where to buy invidual y00,y0 or y1 bit?
Quel est le nom du vis svp je l'ai perdu et j'ai pas la référence
la chaîne de Samarium - crwdns2934203:0crwdne2934203:0
Bonjour @lachainede96340 D'après les instructions du tutoriel, il s'agit d'une vis Phillips (ou cruciforme) #00 de 4 mm de long. Ces mesures devraient suffire pour trouver une vis de remplacement dans votre stock de vis ou en magasin le cas échéant.
Claire Miesch -
