Motorola Edge 5G UW (2022) Lower 5G mmWave Antenna Replacement
  1. Motorola Edge 5G UW (2022) Lower 5G mmWave Antenna Replacement, Heat the left edge: crwdns2935265:01crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Completely power off your phone before you begin.
    • Heat an iOpener and apply it to the back cover's left edge for two minutes.
    • A hair dryer, heat gun, or hot plate may also be used, but be careful not to overheat the phone—the back cover and internal battery are both susceptible to heat damage.
  2. Motorola Edge 5G UW (2022) Lower 5G mmWave Antenna Replacement, Separate the left adhesive: crwdns2935265:02crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Motorola Edge 5G UW (2022) Lower 5G mmWave Antenna Replacement, Separate the left adhesive: crwdns2935265:02crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Motorola Edge 5G UW (2022) Lower 5G mmWave Antenna Replacement, Separate the left adhesive: crwdns2935265:02crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Apply a suction cup to the back of the phone, as close to the bottom left corner as possible.
    • Pull up on the suction cup with a strong, steady force to create a gap between the back cover and the midframe on the left edge.
    • Depending on the age of your phone, this may be difficult. If you're having trouble, apply more heat to the edge and try again.
    • Insert an opening pick into the gap.
  3. Motorola Edge 5G UW (2022) Lower 5G mmWave Antenna Replacement, Slice the left adhesive: crwdns2935265:03crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Motorola Edge 5G UW (2022) Lower 5G mmWave Antenna Replacement, Slice the left adhesive: crwdns2935265:03crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Slide the pick along the left edge of the phone to slice the adhesive securing the back cover to the frame.
    • Leave the pick inserted in the top left corner to prevent the adhesive from resealing.
  4. Motorola Edge 5G UW (2022) Lower 5G mmWave Antenna Replacement, Heat the top edge: crwdns2935265:04crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Apply a heated iOpener to the back cover's top edge for two minutes.
  5. Motorola Edge 5G UW (2022) Lower 5G mmWave Antenna Replacement: crwdns2935265:05crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Motorola Edge 5G UW (2022) Lower 5G mmWave Antenna Replacement: crwdns2935265:05crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Rotate the pick around the top left corner to slice the adhesive.
  6. Motorola Edge 5G UW (2022) Lower 5G mmWave Antenna Replacement: crwdns2935265:06crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Motorola Edge 5G UW (2022) Lower 5G mmWave Antenna Replacement: crwdns2935265:06crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Slide the pick along the top edge to slice the adhesive.
    • Leave the opening pick inserted in the top right corner to prevent the adhesive from resealing.
  7. Motorola Edge 5G UW (2022) Lower 5G mmWave Antenna Replacement: crwdns2935265:07crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Apply a heated iOpener to the back cover's right edge for two minutes.
  8. Motorola Edge 5G UW (2022) Lower 5G mmWave Antenna Replacement: crwdns2935265:08crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Motorola Edge 5G UW (2022) Lower 5G mmWave Antenna Replacement: crwdns2935265:08crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Rotate the pick around the top right corner to slice the adhesive.
  9. Motorola Edge 5G UW (2022) Lower 5G mmWave Antenna Replacement: crwdns2935265:09crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Motorola Edge 5G UW (2022) Lower 5G mmWave Antenna Replacement: crwdns2935265:09crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Slide the pick along the right edge to slice the adhesive.
    • Leave the pick inserted in the bottom right corner to prevent the adhesive from resealing.
  10. Motorola Edge 5G UW (2022) Lower 5G mmWave Antenna Replacement: crwdns2935265:010crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Apply a heated iOpener to the back cover's bottom edge for two minutes.
  11. Motorola Edge 5G UW (2022) Lower 5G mmWave Antenna Replacement: crwdns2935265:011crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Motorola Edge 5G UW (2022) Lower 5G mmWave Antenna Replacement: crwdns2935265:011crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Rotate the pick around the bottom right corner to slice the adhesive.
  12. Motorola Edge 5G UW (2022) Lower 5G mmWave Antenna Replacement: crwdns2935265:012crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Motorola Edge 5G UW (2022) Lower 5G mmWave Antenna Replacement: crwdns2935265:012crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Slide the pick along the bottom edge to slice the adhesive.
  13. Motorola Edge 5G UW (2022) Lower 5G mmWave Antenna Replacement, Heat the camera adhesive: crwdns2935265:013crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Motorola Edge 5G UW (2022) Lower 5G mmWave Antenna Replacement, Heat the camera adhesive: crwdns2935265:013crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • There's a significant amount of adhesive to the right of the cameras that secures the back cover to the motherboard cover.
    • Apply a heated iOpener to the right of the cameras for two minutes.
  14. Motorola Edge 5G UW (2022) Lower 5G mmWave Antenna Replacement, Slice the adhesive around the camera: crwdns2935265:014crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Motorola Edge 5G UW (2022) Lower 5G mmWave Antenna Replacement, Slice the adhesive around the camera: crwdns2935265:014crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Insert an opening pick between the back cover and motherboard cover on the top right edge.
    • Gently pull up on the back cover while sliding the opening pick back and forth along the right side of the cameras to slice the adhesive.
    • The back cover should detach from the phone at this point.
  15. Motorola Edge 5G UW (2022) Lower 5G mmWave Antenna Replacement, Remove the back cover: crwdns2935265:015crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Motorola Edge 5G UW (2022) Lower 5G mmWave Antenna Replacement, Remove the back cover: crwdns2935265:015crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Lift the back cover from the phone and remove it.
    • If the back cover is still stuck to the midframe, slide an opening pick around the edges of the phone until the cover separates completely.
    • During reassembly:
    • This is a good point to test your phone's functionality before sealing it up. Use this guide to run a hardware test. Be sure to power your phone back down completely before you continue working.
    • Follow this guide to replace the back cover adhesive.
  16. Motorola Edge 5G UW (2022) Lower 5G mmWave Antenna Replacement, Unfasten the motherboard cover: crwdns2935265:016crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Motorola Edge 5G UW (2022) Lower 5G mmWave Antenna Replacement, Unfasten the motherboard cover: crwdns2935265:016crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Use a Phillips screwdriver to remove the 13 4 mm screws securing the motherboard cover.
  17. Motorola Edge 5G UW (2022) Lower 5G mmWave Antenna Replacement, Release the motherboard cover clips: crwdns2935265:017crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Motorola Edge 5G UW (2022) Lower 5G mmWave Antenna Replacement, Release the motherboard cover clips: crwdns2935265:017crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Insert a spudger between the motherboard cover and midframe on the top right edge of the phone.
    • Pry up with the spudger to release the clips securing the motherboard cover.
    • During reassembly, press down around the perimeter of the motherboard cover to engage the clips.
  18. Motorola Edge 5G UW (2022) Lower 5G mmWave Antenna Replacement, Remove the motherboard cover: crwdns2935265:018crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Motorola Edge 5G UW (2022) Lower 5G mmWave Antenna Replacement, Remove the motherboard cover: crwdns2935265:018crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Motorola Edge 5G UW (2022) Lower 5G mmWave Antenna Replacement, Remove the motherboard cover: crwdns2935265:018crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Gently pull the motherboard cover up and away from the phone and remove it.
    • Don't pull quickly or forcefully, as the heat spreader very loosely secures the motherboard cover to the battery.
  19. Motorola Edge 5G UW (2022) Lower 5G mmWave Antenna Replacement, Disconnect the battery: crwdns2935265:019crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Motorola Edge 5G UW (2022) Lower 5G mmWave Antenna Replacement, Disconnect the battery: crwdns2935265:019crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Use the pointed end of a spudger to pry up and disconnect the battery's press connector.
    • To re-attach press connectors like this one, carefully align and press down on one side until it clicks into place, then repeat on the other side. Don't press down on the middle. If the connector is misaligned, the pins can bend, causing permanent damage.
  20. Motorola Edge 5G UW (2022) Lower 5G mmWave Antenna Replacement, Remove the lower 5G mmWave antenna: crwdns2935265:020crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Motorola Edge 5G UW (2022) Lower 5G mmWave Antenna Replacement, Remove the lower 5G mmWave antenna: crwdns2935265:020crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Motorola Edge 5G UW (2022) Lower 5G mmWave Antenna Replacement, Remove the lower 5G mmWave antenna: crwdns2935265:020crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Insert the pointed end of a spudger between the motherboard and the right side of the 5G mmWave antenna.
    • Pry up with a strong, steady force to disconnect the press connector and detach the antenna from the motherboard.
    • Adhesive secures the antenna to the motherboard, so this may take significant force and a few attempts.
    • Use tweezers or your fingers to remove the antenna.
Compare your new replacement part to the original part—be sure to transfer remaining components and remove adhesive backings from the new part before installing.
To reassemble your device, follow the instructions in reverse order.
Spencer Day
crwdns2935283:009/14/22crwdne2935283:0
119.190 crwdns2915208:0crwdne2915208:0
crwdns2935297:0838crwdne2935297:0
Staff
crwdns2931471:0119crwdne2931471:0
crwdns2935297:021.739crwdne2935297:0
crwdns2942667:0crwdne2942667:0 684
