Use this guide to replace the battery in your Motorola Edge (2022).
This guide is for the official Motorola replacement part.
Before you begin, download the Software Fix app to backup your device and diagnose whether your problem is software or hardware related.
For your safety, discharge the battery below 25% before disassembling your phone. This reduces the risk of fire if the battery is accidentally damaged during the repair. If your battery is swollen, take appropriate precautions.
You'll need replacement adhesive to complete this repair.
Heat an iOpener and apply it to the back cover's right edge for two minutes.
Apply a suction cup to the back of the phone, as close to the middle of the right edge as possible.
Pull up on the suction cup with a strong, steady force to create a gap between the back cover and the frame.
Insert an opening pick into the gap.
Slide the pick along the right edge to slice the adhesive.
Leave the pick in the bottom right edge to prevent the adhesive from resealing.
Apply a heated iOpener to the back cover's bottom edge for two minutes.
Rotate the pick around the bottom right corner to slice the adhesive.
Slide the pick along the bottom edge to slice the adhesive.
Leave the pick in the bottom left edge to prevent the adhesive from resealing.
Apply a heated iOpener to the back cover's left edge for two minutes.
Rotate the pick around the bottom left corner to slice the adhesive.
Slide the pick along the edge to slice the adhesive.
Leave the pick in the top left edge to prevent the adhesive from resealing.
Apply a heated iOpener to the back cover's top edge for two minutes.
Rotate the pick around the top left corner to slice the adhesive.
Slide the pick along the top edge to slice the adhesive.
Lift the back cover from the phone and remove it.
Insert an opening pick between the right edge of the camera bezel and the motherboard cover.
Slide the pick back and forth along the edge to slice the adhesive.
Insert an opening pick between the left edge of the camera bezel and the motherboard cover.
Lift the camera bezel from the phone and remove it.
This is a good point to test your phone's functionality before sealing it up. Use this guide to run a hardware test. Be sure to power your phone back down completely before you continue working.
If you are replacing the fingerprint sensor or screen assembly, use this guide to calibrate the fingerprint sensor.
Follow this guide to replace the back cover and camera bezel adhesive.
Insert the pointed end of a spudger underneath the tape that connects the wireless charging coil to the speaker on the bottom left of the phone.
Slowly lift the spudger up until the tape detaches from the speaker.
Insert a spudger underneath the tape that connects the wireless charging coil to the daughterboard cover on the bottom right of the phone.
Slowly lift the spudger up until the tape detaches.
Use a Phillips screwdriver to remove the ten 4 mm screws securing the motherboard cover.
Adhesive secures the motherboard cover to the motherboard itself.
Apply a heated iOpener between the bottom edge of the motherboard cover for two minutes.
Insert an opening tool between the motherboard cover and the midframe.
Pry up with the opening tool until you are able to grab the motherboard cover with your fingers.
Slowly pull the motherboard cover up and away from the phone and remove it.
Use your fingers to move the graphite film that covers the battery out of the way.
Use the pointed end of a spudger to pry up and disconnect the battery's press connector.
Apply a few drops of high-concentration (90% or higher) isopropyl alcohol to the gaps along the battery's edges.
Tilt the device as you apply alcohol to help it flow under the battery.
Wait one minute to allow the isopropyl alcohol to penetrate the adhesive.
Apply a suction cup to the battery.
Pull up on the suction cup with strong, steady force to create a gap between the battery and the frame.
Continue to pull up on the suction cup while sliding the opening pick back and forth to slice the adhesive. Continue this process until the battery separates from the frame.
Remove the battery from the midframe.
crwdns2935267:0crwdne2935267:0Tweezers$4.99
Use tweezers or your fingers to remove the foam strip from the battery's bottom edge.
To reassemble your device, follow the instructions in reverse order.
For optimal performance, calibrate your newly installed battery after completing this guide.
Hello! Thanks for the tuto. Is it the same config for the Moto Edge 20? If not, where can I found a Moto Edge 20 tutorial for battery replacement?
Tks
Does this work for the Motorola edge+ 2022?
