Microsoft Surface Pro 7 Screen Adhesive Replacement
  1. Microsoft Surface Pro 7 Screen Adhesive Replacement, Remove the old adhesive: crwdns2935265:01crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Microsoft Surface Pro 7 Screen Adhesive Replacement, Remove the old adhesive: crwdns2935265:01crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Microsoft Surface Pro 7 Screen Adhesive Replacement, Remove the old adhesive: crwdns2935265:01crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Scrape away all traces of adhesive and debris from the Surface's case and screen.
    • Use high concentration isopropyl alcohol (over 90%) or iFixit adhesive remover and a lint-free cloth to clean the adhesion surfaces on both the case and the screen.
    • If glue or glass remnants are left behind, the new screen will not mount correctly and may be damaged.
    • Lay the adhesive strips out to get an idea of where they go.
  2. Microsoft Surface Pro 7 Screen Adhesive Replacement, Apply the new adhesive: crwdns2935265:02crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Microsoft Surface Pro 7 Screen Adhesive Replacement, Apply the new adhesive: crwdns2935265:02crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Peel the white backing off of one adhesive strip, and carefully align it with the edge that matches the cutouts in the strip.
    • Lay the strip down lightly on its matching edge and make sure all the cutouts and edges of the strip line up with the Surface case.
    • Once aligned, use your fingers to press the adhesive strip down against the case.
    • Repeat this procedure for the remaining three adhesive strips.
  3. Microsoft Surface Pro 7 Screen Adhesive Replacement, Install the display: crwdns2935265:03crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Continue reassembly until the cables are reconnected and you're ready to install the screen.
    • If possible, test your screen's functionality before sticking it in place.
    • Remove the clear backing from the adhesive strips.
    • Align the screen with the case and set it on top of the adhesive. Once it's aligned, press down on the edges of the screen to set the adhesive.
    • Apply a few books worth of weight on top of the screen for an hour to help the adhesive bond.
Sam Omiotek
crwdns2935283:002/25/19crwdne2935283:0
90,692 crwdns2915208:0crwdne2915208:0
crwdns2935297:0290crwdne2935297:0
Pictures of the original adhesive configuration would be helpful.
HuntTheHunters - crwdns2934203:0crwdne2934203:0
where can i buy the adshevies for surface pro 8 please
Joyce Woodhead - crwdns2934203:0crwdne2934203:0
Bonjour
Je voudrais savoir si ces adhésifs sont valable pour la surface 7+
Merci
Christophe - crwdns2934203:0crwdne2934203:0
crwdns2936753:07crwdne2936753:0 38
crwdns2936753:030crwdne2936753:0 143
crwdns2942667:0crwdne2942667:0 6,757
