Microsoft Surface Pro 5 Battery Replacement
  1. Microsoft Surface Pro 5 Battery Replacement, Heat the screen: crwdns2935265:01crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Completely power off the Surface before you begin disassembly.
    • If the screen's glass is cracked, keep further breakage contained and prevent bodily harm during your repair by taping over the glass. Lay overlapping strips of clear packing tape over the display until all the glass is covered. Wear safety glasses to protect your eyes.
    • Heat an iOpener and apply it to the right edge of the Surface's screen for two minutes.
    • You may need to reheat and reapply the iOpener several times to get the Surface warm enough. Follow the iOpener instructions to avoid overheating.
    • A hair dryer, heat gun, or hot plate may also be used for more heat, but be careful not to overheat the Surface—the screen and internal battery are susceptible to heat damage.
    You may want to discharge the battery completely as I found it quite easy to accidentally bump the power button and turn the surface on while cutting through the screen adhesive.
    Emma Strainis - crwdns2934203:0crwdne2934203:0
    I used my Mrs heat pad (a small electric blanket thing) just lay the tablet face down and fold the excess blanket over the back, in an hour its toasty .I also cleverly tore off the antenna which came off with the screen but found replacement at Aliexpress
    david granger - crwdns2934203:0crwdne2934203:0
  2. Microsoft Surface Pro 5 Battery Replacement, Take note of the adhesive layout: crwdns2935265:02crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Microsoft Surface Pro 5 Battery Replacement, Take note of the adhesive layout: crwdns2935265:02crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Take note of the screen adhesive layout before continuing:
    • These areas only contain adhesive and are safe to cut.
    • The display board and flex cables sit here close to the edge. Cut very carefully and do not insert the pick as deep under the display.
    • Fragile antenna cables lie under this part of the screen. Carefully follow the procedure to avoid damaging them. The adhesive is also the thickest here.
    Be careful at the bottom of the screen also. If you put the picks in too far, you can severe the screen ribbon cables which happened to me. I successfully removed the screen without breaking it but severed those cables.
    Randall Takahashi - crwdns2934203:0crwdne2934203:0
  3. Microsoft Surface Pro 5 Battery Replacement, Insert an opening pick into the speaker opening: crwdns2935265:03crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Microsoft Surface Pro 5 Battery Replacement, Insert an opening pick into the speaker opening: crwdns2935265:03crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Insert an opening pick into the speaker opening on the screen and slide the pick under the glass. Do not press the pick into the speaker grille, as the grille is easily torn.
    • Don't insert the opening pick any deeper than the black bezel on the side of the screen. Inserting the pick too far may damage the LCD.
  4. Microsoft Surface Pro 5 Battery Replacement, Slide an opening pick under the screen: crwdns2935265:04crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Microsoft Surface Pro 5 Battery Replacement, Slide an opening pick under the screen: crwdns2935265:04crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Rotate the pick toward the bottom of the Surface to slide it underneath the lower edge of the speaker cutout.
  5. Microsoft Surface Pro 5 Battery Replacement, Cut through the screen adhesive: crwdns2935265:05crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Microsoft Surface Pro 5 Battery Replacement, Cut through the screen adhesive: crwdns2935265:05crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Slide the pick down the right edge of the Surface to slice through the adhesive under the screen.
    • Throughout the rest of the procedure, if you encounter significant resistance while sliding the pick, stop and reheat the section you're working on. Applying too much pressure with the pick can crack the glass.
    • Leave this opening pick in the right edge to prevent the adhesive from resealing.
  6. Microsoft Surface Pro 5 Battery Replacement: crwdns2935265:06crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Reheat the iOpener and apply it to the bottom edge of the Surface's screen for two minutes.
  7. Microsoft Surface Pro 5 Battery Replacement: crwdns2935265:07crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Microsoft Surface Pro 5 Battery Replacement: crwdns2935265:07crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Microsoft Surface Pro 5 Battery Replacement: crwdns2935265:07crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Insert a new opening pick into the bottom right corner and slide it around the corner toward the bottom edge.
    • Slide the pick along the bottom edge of the Surface to cut through the screen adhesive.
    • Leave this pick in the bottom edge to prevent the adhesive from resealing.
    Avoid pressing the pick more than 5mm into the lower edge. Driving the pick in as far as the edge of the bezel on the lower edge will damage ribbon cables.
    Bill Mills - crwdns2934203:0crwdne2934203:0
    Bill is right! DO NOT GO IN MORE THAN 5mm, or 1/4 of an inch! Instructions should be corrected, including the top diagram! Be extremely careful on the bottom side, just as the top!
    Bill - crwdns2934203:0crwdne2934203:0
  8. Microsoft Surface Pro 5 Battery Replacement: crwdns2935265:08crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Reheat the iOpener and apply it to the left edge of the Surface's screen for two minutes.
  9. Microsoft Surface Pro 5 Battery Replacement: crwdns2935265:09crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Microsoft Surface Pro 5 Battery Replacement: crwdns2935265:09crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Microsoft Surface Pro 5 Battery Replacement: crwdns2935265:09crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Insert a new opening pick into the bottom left corner and slide it around the corner toward the left edge.
    • Take care cutting under the lower 2.5 inches (65 mm) of the left edge. Do not insert the opening pick more than 1/8 inches (3 mm) here. The display cables sit near this part of the bezel and are easily damaged. Once past the display cable area, do not insert the pick past the bezel.
    • Slide the pick along the left edge of the Surface to cut through the screen adhesive.
    • Leave this pick in the left edge to prevent the adhesive from resealing.
  10. Microsoft Surface Pro 5 Battery Replacement: crwdns2935265:010crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Reheat the iOpener and apply it to the top edge of the Surface's screen for two minutes.
    • The adhesive is thickest along this edge, and you may need to reheat and reapply the iOpener several times to get the Surface warm enough. Follow the iOpener instructions to avoid overheating.
  11. Microsoft Surface Pro 5 Battery Replacement: crwdns2935265:011crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Microsoft Surface Pro 5 Battery Replacement: crwdns2935265:011crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Microsoft Surface Pro 5 Battery Replacement: crwdns2935265:011crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Round the left corner with the opening pick and slide it along the top edge of the Surface. Stop when the pick is 2.75 inches (70 mm) away from the left edge.
    • The next 6 inches (15 cm) of the top edge of the case is covered by the left and right antennas, which sit between the case and the screen bezel. Follow the next steps carefully to avoid damaging the antennas.
  12. Microsoft Surface Pro 5 Battery Replacement: crwdns2935265:012crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Microsoft Surface Pro 5 Battery Replacement: crwdns2935265:012crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Microsoft Surface Pro 5 Battery Replacement: crwdns2935265:012crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Insert the point of a pick under the display where you just stopped cutting. Do not insert the pick deeper than the edge of the bezel.
    • Carefully roll the pick to the right, pressing the long edge of the pick into the screen adhesive underneath the bezel, cutting the adhesive as you go. Do not slide the pick along the edge of the Surface.
    • Keep the pick parallel to the screen throughout the whole procedure so that it doesn't catch on the antennas. Do not press the pick against the case.
    • Repeat this motion of inserting the point of the pick where you just cut, and rolling to the right all along the top edge of the Surface, until the pick is 2.5 inches (64 mm) from the right edge of the Surface.
  13. Microsoft Surface Pro 5 Battery Replacement: crwdns2935265:013crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Microsoft Surface Pro 5 Battery Replacement: crwdns2935265:013crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Microsoft Surface Pro 5 Battery Replacement: crwdns2935265:013crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Once you cut the adhesive over the antennas (8.5 inches, or 22 cm, away from the left edge), slide the pick the rest of the way along the top edge of the surface and round the top right corner to slice through any remaining adhesive.
  14. Microsoft Surface Pro 5 Battery Replacement, Open the Surface: crwdns2935265:014crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Microsoft Surface Pro 5 Battery Replacement, Open the Surface: crwdns2935265:014crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Microsoft Surface Pro 5 Battery Replacement, Open the Surface: crwdns2935265:014crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Very slowly lift the screen assembly away from the Surface case. If you encounter any resistance, stop and check that all the adhesive is separated.
    • Do not remove the screen yet. It is still connected to the motherboard by two cables.
    • Use an opening pick to cut through any remaining adhesive.
    • The flash lens may fall out of the Surface case. Keep track of the lens and return it to its cutout in the case during reassembly.
  15. Microsoft Surface Pro 5 Battery Replacement: crwdns2935265:015crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Microsoft Surface Pro 5 Battery Replacement: crwdns2935265:015crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Microsoft Surface Pro 5 Battery Replacement: crwdns2935265:015crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Lift the top of the screen assembly away from the case while sliding the bottom of the screen closer to the motherboard display connectors.
    • Gently lay the screen down on the case with the connectors facing up. Take care to avoid creasing the display cables.
    No llega el cable derecho de la pantalla, al voltear la Tablet y este se romperá, lo ideal sera levantar la pantalla un poco y desconectar el cable de la tablet no de la pantalla.
    Francisco Arocas Cases - crwdns2934203:0crwdne2934203:0
  16. Microsoft Surface Pro 5 Battery Replacement, Disconnect the screen: crwdns2935265:016crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Microsoft Surface Pro 5 Battery Replacement, Disconnect the screen: crwdns2935265:016crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Use an opening pick to pry up one edge of the EMI shield covering the display board.
    • Repeat this procedure at different points around the shield until it is free.
    • Try not to deform the shield too much—you will need to reinstall it during reassembly.
    I had better results using the black spudger to free the shields without damaging them.
  17. Microsoft Surface Pro 5 Battery Replacement: crwdns2935265:017crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Lift the EMI shield away from the display board and remove it.
  18. Microsoft Surface Pro 5 Battery Replacement: crwdns2935265:018crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Microsoft Surface Pro 5 Battery Replacement: crwdns2935265:018crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Use the flat end of a spudger to pry the display interconnect cable straight up and out of its socket on the board.
  19. Microsoft Surface Pro 5 Battery Replacement: crwdns2935265:019crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Microsoft Surface Pro 5 Battery Replacement: crwdns2935265:019crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Insert one point of a pair of pointed tweezers into a gap in the edge of the EMI shield covering the digitizer connector.
    • Use the tweezers to pry the EMI shield away from the display as much as you can without bending it.
    • Repeat this procedure at different points around the shield until it is free. Remove the shield.
  20. Microsoft Surface Pro 5 Battery Replacement: crwdns2935265:020crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Pull the rest of the shield off of the digitizer connector and remove it.
  21. Microsoft Surface Pro 5 Battery Replacement: crwdns2935265:021crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Microsoft Surface Pro 5 Battery Replacement: crwdns2935265:021crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Use the tip of a spudger to pry the digitizer connector straight up and out of its socket on the screen.
  22. Microsoft Surface Pro 5 Battery Replacement: crwdns2935265:022crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the screen assembly from the Surface.
    • During reassembly, pause here and follow this guide to replace the screen adhesive.
  23. Microsoft Surface Pro 5 Battery Replacement, Disconnect the antenna support: crwdns2935265:023crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Microsoft Surface Pro 5 Battery Replacement, Disconnect the antenna support: crwdns2935265:023crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Use the point of a spudger to pry the microphone connector straight up and out of its socket on the motherboard.
  24. Microsoft Surface Pro 5 Battery Replacement, Unscrew the antenna support: crwdns2935265:024crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Use a T5 Torx driver to remove the four screws securing the antenna support:
    • Three 4.5 mm screws
    • One 6 mm screw
  25. Microsoft Surface Pro 5 Battery Replacement, Remove the antenna support: crwdns2935265:025crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Microsoft Surface Pro 5 Battery Replacement, Remove the antenna support: crwdns2935265:025crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Microsoft Surface Pro 5 Battery Replacement, Remove the antenna support: crwdns2935265:025crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Use a spudger to lift the antenna support out of its recess in the Surface.
    • Remove the antenna support.
  26. Microsoft Surface Pro 5 Battery Replacement, Remove the heat sink shield: crwdns2935265:026crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Microsoft Surface Pro 5 Battery Replacement, Remove the heat sink shield: crwdns2935265:026crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Insert one point of a pair of pointed tweezers into a gap in the corner of the EMI shield covering the heat sink.
    • Use the tweezers to pry the EMI shield away from the motherboard as much as you can without bending it. Do not remove it yet.
    • Take care not to puncture the battery with the tweezers while working on this shield.
    Black spudger worked best to get the emu shields out without damaging them.
  27. Microsoft Surface Pro 5 Battery Replacement: crwdns2935265:027crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Microsoft Surface Pro 5 Battery Replacement: crwdns2935265:027crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Microsoft Surface Pro 5 Battery Replacement: crwdns2935265:027crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Repeat the last step for each corner of the EMI shield covering the heat sink.
  28. Microsoft Surface Pro 5 Battery Replacement: crwdns2935265:028crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the heat sink shield.
  29. Microsoft Surface Pro 5 Battery Replacement, Remove the heat sink: crwdns2935265:029crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Microsoft Surface Pro 5 Battery Replacement, Remove the heat sink: crwdns2935265:029crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Remove the nine Torx screws securing the heat sink:
    • Five 2.6 mm-long T3 screws
    • Four 3.3 mm-long T5 screws
    • During reassembly, tighten the heat sink screws in the following criss-cross pattern, one turn at a time, until they're tight:
    • Screw 1
    • Screw 2
    • Screw 3
    • Screw 4
    Just like to add, on my i7, there is a fan in the top left corner and the heat sink is glued to the cover. The cover must be removed using a ph0 x 3 and one T3 (I think that is the sizes)
    Richard Wellesley - crwdns2934203:0crwdne2934203:0
    As the other person commented, mine also had a fan connected to the heatsink. This is present in the version with an Intel Core i7-7660U. It requires removing a T3 and T5 screw and the fan connector. Below is a link to an image showing this step.
    Surface Pro 5 with fan
    Brian T - crwdns2934203:0crwdne2934203:0
    While I do not have the fan present in my i5 version, the copper heat pipe does extend further down on the far left side (as oriented in the picture). There is an additional T3 screw on this arm as well as a small dab of adhesive on the very end.
    My i5 surface pro 5 has 6 of the T3 screws as the heat sink extends slightly further down.
    Joshua Dunsire - crwdns2934203:0crwdne2934203:0
  30. Microsoft Surface Pro 5 Battery Replacement: crwdns2935265:030crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Microsoft Surface Pro 5 Battery Replacement: crwdns2935265:030crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Microsoft Surface Pro 5 Battery Replacement: crwdns2935265:030crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
  31. Microsoft Surface Pro 5 Battery Replacement, Disconnect the left speaker: crwdns2935265:031crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Microsoft Surface Pro 5 Battery Replacement, Disconnect the left speaker: crwdns2935265:031crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Use the point of a spudger to lift the left speaker connector out of its socket on the motherboard.
  32. Microsoft Surface Pro 5 Battery Replacement, Disconnect the volume and power buttons: crwdns2935265:032crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Microsoft Surface Pro 5 Battery Replacement, Disconnect the volume and power buttons: crwdns2935265:032crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Microsoft Surface Pro 5 Battery Replacement, Disconnect the volume and power buttons: crwdns2935265:032crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Use the point of a spudger to flip up the small locking flap securing the volume and power button cable ZIF connector.
    • Slide the volume and power button cable straight out of its socket on the motherboard.
  33. Microsoft Surface Pro 5 Battery Replacement, Disconnect the right speaker: crwdns2935265:033crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Microsoft Surface Pro 5 Battery Replacement, Disconnect the right speaker: crwdns2935265:033crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Use the point of a spudger to lift the right speaker connector out of its socket on the motherboard.
  34. Microsoft Surface Pro 5 Battery Replacement, Unscrew the right speaker: crwdns2935265:034crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Use a T5 Torx driver to remove the two screws securing the right speaker:
    • One 6 mm screw
    • One 3.7 mm screw
  35. Microsoft Surface Pro 5 Battery Replacement, Remove the right speaker: crwdns2935265:035crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Microsoft Surface Pro 5 Battery Replacement, Remove the right speaker: crwdns2935265:035crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Microsoft Surface Pro 5 Battery Replacement, Remove the right speaker: crwdns2935265:035crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Use a spudger to lift the left edge of the right speaker so that it clears the components around the speaker.
    • With the left edge lifted, slide the speaker to the left, straight out of its recess in the case.
  36. Microsoft Surface Pro 5 Battery Replacement, Remove the camera connector shield: crwdns2935265:036crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Microsoft Surface Pro 5 Battery Replacement, Remove the camera connector shield: crwdns2935265:036crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Microsoft Surface Pro 5 Battery Replacement, Remove the camera connector shield: crwdns2935265:036crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Insert one point of a pair of pointed tweezers into a gap in the corner of the EMI shield covering the camera connectors.
    Black spudger worked better for me again here to remove the shields.
  37. Microsoft Surface Pro 5 Battery Replacement, Disconnect the front-facing cameras: crwdns2935265:037crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Microsoft Surface Pro 5 Battery Replacement, Disconnect the front-facing cameras: crwdns2935265:037crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Use the flat end of a spudger to pry the front-facing camera connector up and out of its socket on the motherboard.
  38. Microsoft Surface Pro 5 Battery Replacement: crwdns2935265:038crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Microsoft Surface Pro 5 Battery Replacement: crwdns2935265:038crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Use the flat end of a spudger to pry the face-detection camera connector up and out of its socket on the motherboard.
  39. Microsoft Surface Pro 5 Battery Replacement, Disconnect the rear-facing camera: crwdns2935265:039crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Microsoft Surface Pro 5 Battery Replacement, Disconnect the rear-facing camera: crwdns2935265:039crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Use the flat end of a spudger to pry the rear-facing camera connector up and out of its socket on the motherboard.
  40. Microsoft Surface Pro 5 Battery Replacement, Disconnect the microphone: crwdns2935265:040crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Microsoft Surface Pro 5 Battery Replacement, Disconnect the microphone: crwdns2935265:040crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Use the flat end of a spudger to pry the microphone connector up and out of its socket on the motherboard.
  41. Microsoft Surface Pro 5 Battery Replacement, Remove the microSD card reader connector shield: crwdns2935265:041crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Microsoft Surface Pro 5 Battery Replacement, Remove the microSD card reader connector shield: crwdns2935265:041crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Microsoft Surface Pro 5 Battery Replacement, Remove the microSD card reader connector shield: crwdns2935265:041crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Insert one point of a pair of pointed tweezers into a gap in the corner of the EMI shield covering the microSD card reader connector.
  42. Microsoft Surface Pro 5 Battery Replacement, Disconnect the microSD card reader: crwdns2935265:042crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Microsoft Surface Pro 5 Battery Replacement, Disconnect the microSD card reader: crwdns2935265:042crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Use the flat end of a spudger to pry the microSD card reader connector up and out of its socket on the motherboard.
  43. Microsoft Surface Pro 5 Battery Replacement, Disconnect the SurfaceConnect port: crwdns2935265:043crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Microsoft Surface Pro 5 Battery Replacement, Disconnect the SurfaceConnect port: crwdns2935265:043crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Use the flat end of a spudger to lift the flap that sits over the SurfaceConnect port connector.
  44. Microsoft Surface Pro 5 Battery Replacement: crwdns2935265:044crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Microsoft Surface Pro 5 Battery Replacement: crwdns2935265:044crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Slide the SurfaceConnect port connector out of its socket on the motherboard.
  45. Microsoft Surface Pro 5 Battery Replacement, Disconnect the headphone jack: crwdns2935265:045crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Microsoft Surface Pro 5 Battery Replacement, Disconnect the headphone jack: crwdns2935265:045crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Microsoft Surface Pro 5 Battery Replacement, Disconnect the headphone jack: crwdns2935265:045crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Use the point of a spudger to flip up the small locking flap securing the headphone jack cable ZIF connector.
    • Slide the headphone jack cable straight out of its socket on the motherboard.
  46. Microsoft Surface Pro 5 Battery Replacement, Remove the two large EMI shields: crwdns2935265:046crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Microsoft Surface Pro 5 Battery Replacement, Remove the two large EMI shields: crwdns2935265:046crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Microsoft Surface Pro 5 Battery Replacement, Remove the two large EMI shields: crwdns2935265:046crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Insert one point of a pair of pointed tweezers into a gap in the corner of the left-most of the remaining large EMI shields.
  47. Microsoft Surface Pro 5 Battery Replacement: crwdns2935265:047crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Microsoft Surface Pro 5 Battery Replacement: crwdns2935265:047crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Microsoft Surface Pro 5 Battery Replacement: crwdns2935265:047crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Repeat the previous step to remove the remaining large EMI shield from the right side of the motherboard.
  48. Microsoft Surface Pro 5 Battery Replacement, Remove the motherboard assembly: crwdns2935265:048crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Use a T3 Torx driver to remove the eight 2.5 mm screws securing the motherboard.
  49. Microsoft Surface Pro 5 Battery Replacement: crwdns2935265:049crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Microsoft Surface Pro 5 Battery Replacement: crwdns2935265:049crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Microsoft Surface Pro 5 Battery Replacement: crwdns2935265:049crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Lift the non-port-side of the motherboard up slightly, just enough so that it clears the components around it and the edge of the case.
    • Slide the motherboard away from the ports. Make sure the ports are completely out of their slots in the case before removing the motherboard.
    • Remove the motherboard.
  50. Microsoft Surface Pro 5 Battery Replacement, Heat the battery connector: crwdns2935265:050crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Heat an iOpener and apply it to the battery connector for two minutes to soften the adhesive securing the connector to the case.
  51. Microsoft Surface Pro 5 Battery Replacement, Separate the battery connector adhesive: crwdns2935265:051crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Microsoft Surface Pro 5 Battery Replacement, Separate the battery connector adhesive: crwdns2935265:051crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Microsoft Surface Pro 5 Battery Replacement, Separate the battery connector adhesive: crwdns2935265:051crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Starting at the edge closest to the battery, slide an opening pick under the battery connector to separate the adhesive underneath.
    • Make sure the battery connector is completely free from the case.
    Note that the keyboard cable and connector are under the battery connector. Make sure not to remove that.
    Mike Jaster - crwdns2934203:0crwdne2934203:0
  52. Microsoft Surface Pro 5 Battery Replacement, Remove the battery: crwdns2935265:052crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Microsoft Surface Pro 5 Battery Replacement, Remove the battery: crwdns2935265:052crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Microsoft Surface Pro 5 Battery Replacement, Remove the battery: crwdns2935265:052crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Prop the top edge of the Surface up a couple inches so the whole Surface slopes towards the bottom edge.
    • Apply adhesive remover or high-concentration (90% or higher) isopropyl alcohol to the top edge of the battery.
    • If you are using adhesive remover, follow these preparation steps first.
    • Let the adhesive remover sit and soak into the adhesive for 2–3 minutes before continuing.
  53. Microsoft Surface Pro 5 Battery Replacement: crwdns2935265:053crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Microsoft Surface Pro 5 Battery Replacement: crwdns2935265:053crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Microsoft Surface Pro 5 Battery Replacement: crwdns2935265:053crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    Plastic Cards
    $2.99
    • Take care not to puncture or bend the battery with your tools—a punctured or bent battery may leak dangerous chemicals or cause a thermal event.
    • Slide a plastic card under the left side of the top edge of the battery.
    • If you encounter significant resistance at any point during this procedure, stop, apply a little more adhesive remover, and wait for it to soak in.
    • Slide the card side to side under the upper left battery cell to slice through the adhesive underneath.
  54. Microsoft Surface Pro 5 Battery Replacement: crwdns2935265:054crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Microsoft Surface Pro 5 Battery Replacement: crwdns2935265:054crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Microsoft Surface Pro 5 Battery Replacement: crwdns2935265:054crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Slide the plastic card around the left edge of the battery and under the bottom left battery cell.
    • Slide the card side to side under the bottom left cell to slice through the adhesive underneath.
  55. Microsoft Surface Pro 5 Battery Replacement: crwdns2935265:055crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Microsoft Surface Pro 5 Battery Replacement: crwdns2935265:055crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Microsoft Surface Pro 5 Battery Replacement: crwdns2935265:055crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Repeat the previous two steps for the right side of the battery to release the two right cells from their adhesive.
  56. Microsoft Surface Pro 5 Battery Replacement: crwdns2935265:056crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Microsoft Surface Pro 5 Battery Replacement: crwdns2935265:056crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Microsoft Surface Pro 5 Battery Replacement: crwdns2935265:056crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Lift each side of the battery with a plastic card and make sure all the adhesive is separated from the battery.
    • Gently lift the battery out of the case.
    • Do not reuse the battery after it has been removed, as doing so is a potential safety hazard. Replace it with a new battery.
    • During reassembly, follow this guide to clean off old adhesive and apply new adhesive from a pre-cut adhesive card.
For optimal performance, calibrate your newly installed battery after completing this guide.
Repair didn’t go as planned? Try some basic troubleshooting, or ask our Answers community for troubleshooting help.
crwdns2935229:039crwdne2935229:0
Sam Omiotek
crwdns2935283:002/25/19crwdne2935283:0
87,069 crwdns2915208:0crwdne2915208:0
crwdns2935297:0290crwdne2935297:0
crwdns2947412:023crwdne2947412:0
This looks like the most stressful repair possible. It’s criminal how sealed up these devices are. Microsoft seems to be going in the right direction with repair, but this was really atrocious.
[deleted] - crwdns2934203:0crwdne2934203:0
Or one can use the Surface Pro without a battery by simply cutting the battery connector pictured in step 51. To do this follow the steps until step 22, then remove the single screw for the heat sink branch that lies over the battery connector, cut the battery connector with a pair of needle-nosed snips while gently lifting the heat sink branch out of the way, continue with steps 52 through 56, and finally seal the cut end of the battery connector with some non-conductive tape and reassemble.
And BTW, you can find replacement antennas on eBay or Amazon if you damaged either while removing the screen.
darthhack - crwdns2934203:0crwdne2934203:0
Have you tried it? Are you sure it works? Everywhere online it says that the Surface Pro 5 will not work without a working battery inside.
Andrei Petrache -
New battery is in and it seems to charge but windows wont recognize a battery as being installed(even after reinstalling acpi drivers for it). The install itself went pretty flawless so I have no idea how to get it to recognize it. It wont show any battery statistics/status/%. Research seems to show this is a common thing but I have found no solutions. If one is known, adding it to this tutorial would be awesome.
Danner Builds - crwdns2934203:0crwdne2934203:0
Hello Community,
I replaced my bloated battery in the Surface Pro 5 today using the ifixit guide. Everything went great so far. The device turns on, recognizes the battery. Only the battery does not charge. The charger does not light up when the Surface is turned off. When the Surface is turned on, the charger blinks dimly. The error is not due to the charger, because it behaves identically with the docking station. What have I overlooked? Here a Screenshot of the windows battery report : Battery Report
Thanks!
Alex - crwdns2934203:0crwdne2934203:0
I have been using my surface daily for the last 4 years. Now with a fresh battery it is good for few more. Apart from an iPhone SE battery, I had no experience with fixing electronics. Took me 10 hours to complete the whole operation. I wouldn't have even attempted the repair if it wasn't for the detailed guide. Thank you.
Daniel Borýsek - crwdns2934203:0crwdne2934203:0
i fixed it today and it worked very well.
Thanks for the detailed guidance! :)
what i was missing were some parts to order and maybe a full list of things i need to order. Getting the Stripes for rebuilding it was a little complicated in germany.
After finishing (without gluing it together) the manual keyboard can't get recognized from the surface.
Did i make a mistake? there was no step where the connection was explained.
Stefan Pöppel - crwdns2934203:0crwdne2934203:0
Great guide. Full repair in 5 hours, my trickiest one yet. No issues with the battery.
New problem arose....
I have a thick black line in the centre third of my screen. I don't see any damage to the screen, and have tested the screen connectors. Is there another connector I may have missed?
Rob Thompson - crwdns2934203:0crwdne2934203:0
I also have a thick black line directly lined up with the digitizer connection. If I press around on the connector the lines change in appearance. I can't find any physical damage to the screen, ports, or cable. I don't know what's wrong and I'm thinking of replacing the screen.
Emma Strainis -
An update - I ordered a new display cable to see if I had damaged the original one. The problem has persisted with the new cable, so it looks like I'll be replacing the screen. Luckily I have not adhered the screen back to the body so I don't have to get it open again.
Emma Strainis -
I just did this repair on my Surface Pro 5 with no issues. I had previously changed the battery on my wife's Surface Pro 4 last year so was familiar with the process, but for hers I used a heating pad to remove the screen and for mine I used the iOpener. The iOpener is definitely the way to go! With the heating pad heating up the whole device, I think I overheated her digitizer and separated it a bit from the screen so hers now has faint backlight fingers protruding from the edges of the screen. With the iOpener, heat is only applied to the very edges of the screen and is much safer. Well worth the money. Also purchase the precut screen adhesive strips while you're at it!!
And for anyone outside the US searching for batteries, iFixit doesn't ship batteries outside the US (I'm in Canada), so I took a chance with a Canadian aftermarket supplier and ordered Cameron Sino branded batteries for both mine and my wife's Surface's. Both are working fine and are registering slightly over 100% rated capacity.
It's very hard job to remove the display without damaging the display (is it even possible at the first time?) or the 2 cables that connect to the motherboard. I'm normally very skilled doing this repairs but the Surface it's an exeption.
Patrick De Angelis - crwdns2934203:0crwdne2934203:0
do i need to add new connectivity paste between the battery and the motherboard connection
Isaac Valdez - crwdns2934203:0crwdne2934203:0
Hi, after I replaced the battery. The wifi adapter was missing. Should I replace the wifi antenna or should I check something else that I forgot to connect? Thanks
sheungching lam - crwdns2934203:0crwdne2934203:0
I have had my Surface Pro 5 for about 6 or 7 years, and it now only holds a charge for 15-20 minutes. I was going to attempt the repair, but after looking at how delicate it is and all of the problems encountered above with many that have attempted it, I think I’ll just use it plugged in and purchase another computer for portability. I’m a bit miffed that Microsoft considered such an expensive piece of hardware disposable. It could have been designed such that the battery was user replaceable without having to spend 5 hours doing it and likely cracking the screen in the process. Even a local repair shop that said they do this battery replacement noted that they charge up front for a new screen due to the likelihood that they will break it as well as I would. Poor design.
Baltovet - crwdns2934203:0crwdne2934203:0
I attempted this as my second ever repair and ended up cracking the screen. Definitely me not being careful and this being a really difficult repair. Godspeed for everyone who did this and succeeded! I did really love my surface but, wow, Microsoft did not want me to open this thing hahaha
I am grateful I have all these iFixit tools for when I need to repair other things
Maxwell Rowshandel - crwdns2934203:0crwdne2934203:0
Replaced the battery, no visible damage to the display (I was very, very careful!) but when I turned it back on the screen had various issues. Replaced the screen and now it's like new again! Would recommend being prepared to spend another £100 or so on buying a replacement screen if replacing the battery - worth it to be able to use the laptop for longer than half an hour off charge though!
Kathryn - crwdns2934203:0crwdne2934203:0
The guide Surface is not equipped with a fan. I had to remove two additional screws in opposite corners of the fan assembly. No need to remove the tiny screws on top of the fan itself. The fan is integrated with the heatsink pipes, so this step is needed for lifting off the heatsink pipes. Thank you for a great guide and an awesome initiative!
Jonas Thonell - crwdns2934203:0crwdne2934203:0
Who at Microsoft thought it was a good idea to use that much adhesive on the battery,
Wow that was a nightmare to remove, even with tons of isopropyl alcohol.
I used no alcohol and raw force and a credit card... After everything is already out there is not a lot left to damage. That is the only advantage tho.
You are right the glue was incredibly strong. I think iþs because the battery is only connected by pins and can under no circumstances moove even a lillte bit. As it is not plugged in. Horrible design
I cant believe you have to remove the motherboard to remove the battery.
And all the emf cages... Aaaaahhh it was awful... But it worked
Geo Golfschläger -
Hi, I am from Bahrain and while placing the order the system rejected the battery as it can only be delivered within the contiguous USA.
Can anyone help me if there is a way to get the battery replacement pack in Bahrain... maybe through Aramex, Fedex etc.?
Sumit Pandey - crwdns2934203:0crwdne2934203:0
Thanks, Sam!! Totally completed the task at hand in less than 4 hours, wow!!! Your instructions are 99% accurate, just minor adjustment(s) due to the i7 processor, and the cooling fan screw. Saved me at least $250 for the labor & part ($25 off eBay). Greatly appreciate you!!
Jonathan Nugent - crwdns2934203:0crwdne2934203:0
surface 6 pro, replaced my battery ut windows does not detect it.
Hertzel Armengol - crwdns2934203:0crwdne2934203:0
crwdns2936751:024crwdne2936751:0 37
crwdns2936753:07crwdne2936753:0 340
crwdns2936753:030crwdne2936753:0 1,347
crwdns2942667:0crwdne2942667:0 72,885
