Microsoft Surface Pro 4 Screen Adhesive Replacement
    1. Microsoft Surface Pro 4 Screen Adhesive Replacement, Remove the old adhesive: crwdns2935265:01crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Microsoft Surface Pro 4 Screen Adhesive Replacement, Remove the old adhesive: crwdns2935265:01crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Microsoft Surface Pro 4 Screen Adhesive Replacement, Remove the old adhesive: crwdns2935265:01crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
      • Scrape away all traces of adhesive and debris from the Surface's case and screen.
      • Use high concentration isopropyl alcohol (over 90%) or iFixit adhesive remover and a lint-free cloth to clean the adhesion surfaces on both the case and the screen.
      • If glue or glass remnants are left behind, the new screen will not mount correctly and may be damaged.
      • Lay the adhesive strips out to get an idea of where they go.
    2. Microsoft Surface Pro 4 Screen Adhesive Replacement, Apply the new adhesive: crwdns2935265:02crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Microsoft Surface Pro 4 Screen Adhesive Replacement, Apply the new adhesive: crwdns2935265:02crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
      • Peel the white backing off of one adhesive strip, and carefully align it with the edge that matches the cutouts in the strip.
      • Lay the strip down lightly on its matching edge and make sure all the cutouts and edges of the strip line up with the Surface case.
      • Once aligned, use your fingers to press the adhesive strip down against the case.
      • Repeat this procedure for the remaining three adhesive strips.
    3. Microsoft Surface Pro 4 Screen Adhesive Replacement, Install the display: crwdns2935265:03crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
      • Continue reassembly until the cables are reconnected and you're ready to install the screen.
      • If possible, test your screen's functionality before sticking it in place.
      • Remove the clear backing from the adhesive strips.
      • Align the screen with the case and set it on top of the adhesive. Once it's aligned, press down on the edges of the screen to set the adhesive.
      • Apply a few books worth of weight on top of the screen for an hour to help the adhesive bond.
crwdns2935229:012crwdne2935229:0
Sam Omiotek
crwdns2935283:002/25/19crwdne2935283:0
99 986 crwdns2915208:0crwdne2915208:0
crwdns2935297:0289crwdne2935297:0
crwdns2936753:07crwdne2936753:0 29
crwdns2936753:030crwdne2936753:0 109
crwdns2942667:0crwdne2942667:0 12,080
