Microsoft Surface Pro 4 Kickstand Replacement
  1. Microsoft Surface Pro 4 Kickstand Replacement, Open the kickstand: crwdns2935265:01crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Microsoft Surface Pro 4 Kickstand Replacement, Open the kickstand: crwdns2935265:01crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Microsoft Surface Pro 4 Kickstand Replacement, Open the kickstand: crwdns2935265:01crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Place your device screen-down on a clean work surface.
    • Place your device on top of a clean cloth, such as a microfiber towel, if you feel the need to protect against scratching.
    • Open the kickstand as wide as it is designed to go (about 135 degrees).
  2. Microsoft Surface Pro 4 Kickstand Replacement, Unscrew the kickstand: crwdns2935265:02crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Microsoft Surface Pro 4 Kickstand Replacement, Unscrew the kickstand: crwdns2935265:02crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Use a T5 Torx screwdriver to remove the two 3.3 mm screws securing each hinge to the kickstand.
    • Support the kickstand from behind to prevent damage to the hinges while removing the screws.
    • Do not remove the kickstand yet.
    • The kickstand remains held in place by two flexible appendages between the hinges.
  3. Microsoft Surface Pro 4 Kickstand Replacement, Close the kickstand: crwdns2935265:03crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Microsoft Surface Pro 4 Kickstand Replacement, Close the kickstand: crwdns2935265:03crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Microsoft Surface Pro 4 Kickstand Replacement, Close the kickstand: crwdns2935265:03crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Press the kickstand from directly behind the hinges and close it fully.
    • Do not exert force on the kickstand anywhere except for behind the hinges.
    • This step does not apply during reassembly.
  4. Microsoft Surface Pro 4 Kickstand Replacement, Remove the kickstand: crwdns2935265:04crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Microsoft Surface Pro 4 Kickstand Replacement, Remove the kickstand: crwdns2935265:04crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Microsoft Surface Pro 4 Kickstand Replacement, Remove the kickstand: crwdns2935265:04crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Pull the kickstand straight out from the bottom of the device.
    • Begin reassembly now before proceeding to steps 5 and 6:
    • Install your new kickstand by inserting its two appendages into the back of the device.
    • Press your new kickstand towards the top of the device until it is fully inserted.
    • Open the kickstand 180 degrees to expose the hinges.
  5. Microsoft Surface Pro 4 Kickstand Replacement, Reassembly tips: crwdns2935265:05crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Microsoft Surface Pro 4 Kickstand Replacement, Reassembly tips: crwdns2935265:05crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Microsoft Surface Pro 4 Kickstand Replacement, Reassembly tips: crwdns2935265:05crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • To open the hinge, insert your T5 Torx screwdriver into one of the screw holes and gently pry towards the top of your device until the hinge is exposed.
    • Make sure the complete step 4 and begin installing the kickstand first.
  6. Microsoft Surface Pro 4 Kickstand Replacement: crwdns2935265:06crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Microsoft Surface Pro 4 Kickstand Replacement: crwdns2935265:06crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Use your fingers or the flat end of a spudger to pry the hinge up into its fully open position.
Sam Omiotek
crwdns2935283:002/25/19crwdne2935283:0
87 709 crwdns2915208:0crwdne2915208:0
crwdns2935297:0290crwdne2935297:0
Is there a way to fix or replace the hinge? The kickstand on my Surface Pro is fine but the left hinge broke so now it won’t hold it up
Joel Hanson - crwdns2934203:0crwdne2934203:0
Joel - did you find a solution? My left hinge broke a week ago and I’m looking for a solution. Thanks!
Cora Willett -
I’m sorry for the delayed reply. I didn’t check on the hinges when I was working on the guide and unfortunately I don’t have the device still. In my online research, I found that the hinges are replaceable but I wasn’t able to find replacement parts.
Sarah Westberg -
crwdns2936753:07crwdne2936753:0 21
crwdns2936753:030crwdne2936753:0 87
crwdns2942667:0crwdne2942667:0 11,344
