MacBook Pro 15" Touch Bar 2019 Screen Replacement
  1. MacBook Pro 15" Touch Bar 2019 Screen Replacement, Disable Auto Boot: crwdns2935265:01crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 MacBook Pro 15" Touch Bar 2019 Screen Replacement, Disable Auto Boot: crwdns2935265:01crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 MacBook Pro 15" Touch Bar 2019 Screen Replacement, Disable Auto Boot: crwdns2935265:01crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Before starting this procedure, you must disable your Mac's Auto Boot feature. Auto Boot powers on your Mac when you open the lid, and may be accidentally triggered during disassembly. Use this guide or follow the abbreviated instructions below to disable Auto Boot. This command may not work on all Macs.
    • Power on your Mac and launch Terminal.
    • Copy and paste the following command (or type it exactly) into Terminal:
    • sudo nvram AutoBoot=%00
    • Press [return]. If prompted, enter your administrator password and press [return] again. Note: Your return key may also be labeled ⏎ or "enter."
    • You can now safely power down your Mac and open the bottom case, without it accidentally powering on.
    • When your repair is complete and your Mac is successfully reassembled, re-enable Auto Boot with the following command:
    • sudo nvram AutoBoot=%03
    Is this step necessary? I can’t perform this step as I am attempting to repair water damage and need to remove logic board & most likely replace the battery.
    Macrepair SF - crwdns2934203:0crwdne2934203:0
    @mac_medic You definitely don’t want the power coming on while the board is wet. In your case, I think powering on the machine to disable Auto Boot would do more damage than it prevents. I agree, skip this step and be prepared to disconnect the battery quickly if the laptop automatically powers on. Good luck!
    Jeff Suovanen -
    Thats right! You don't want power running while working on your logic board.
    Dan -
    This did not work when running High Sierra.
    Kyle B - crwdns2934203:0crwdne2934203:0
    Tried this on a 2018 MBP 13” Touchbar (there’s no iFixit guide for this model yet). Need to replace a broken screen.
    Luckily I managed to connect to an external screen (Cmd-Down Brightness to switch displays) and enter above command. Seems to work, but there’s another problem with this model - it powers up as soon as any key is pressed……. ffs <gnashes teeth>
    Cool_Breeze - crwdns2934203:0crwdne2934203:0
    I unscrew the battery first and wrap electrical tape over the logic board battery connector before attempting any repairs to the board. Haven’t had any problems yet and I’ve worked on about 10 of these models already. Also when you open the bottom case use a suction cup at the bottom and pull up then run a plastic spudger along the edges to disconnect the clips. Also only use a plastic spudger on the board. Saw a youtube video from a repair shop and he did not disconnect the power and used all metal tools during the entire process of removing the board. His last step was to disconnect the battery terminal.
    Brian - crwdns2934203:0crwdne2934203:0
    Is this step necessary if my mac can turn on? Battery fully dead(
    Nursat b - crwdns2934203:0crwdne2934203:0
    BEFORE YOU START: The included torx head stripped off before I was done (and you might need an additional T4) so stop now and go buy a good one. Also they fail to warn you above to get some blue threadlocker ahead of time.
    Jason Sherron - crwdns2934203:0crwdne2934203:0
    This command did not work for me and I read that sometime in later 2020 Apple stopped this command from working…any ideas on a work around?
    Patrick Machacek - crwdns2934203:0crwdne2934203:0
    Not able to do that with damaged screen
    richardjgreen - crwdns2934203:0crwdne2934203:0
    If you have a damaged screen you can still use a converter from thunderbolt (USB 3) to HDMI and plug your Macbook Pro to your TV as monitor display. Just make sure to chose the right Source (HDMI IN) in your TV. I did it and to make it work I unplug and plug again in my Macbook and so I could disable the Auto boot
    Roberto Sanchez Bustos -
    Hi. This does not work on 2018 13” MacBook Pro with Touch Bar. I did exactly this to disable auto boot. But when I check by using nvram -p it says: auto-boot true. Am I doing something incorrectly? I did everything step by step. Copied and pasted the sudo command, pressed enter and then entered my password. I have Big Sur 11.1 installed. Is there any other way since I need to replace the screen. Thank you. Adrian
    Adrian Vizik - crwdns2934203:0crwdne2934203:0
    Hi everyone. This is also a little pointless if you can’t see anything on the screen, and you don’t have a display adapter to USB C to display it. I agree with Brian about removing the back and disconnecting the battery cable before you even think about opening the lid of the MacBook. Applying the insulation tape is also a handy little tip that just makes sure there is no way to discharge from either the board or battery.
    Roberto Enrieu - crwdns2934203:0crwdne2934203:0
    running `nvram -p | grep 'AutoBoot'` in terminal verifies that it was accepted
    result: `AutoBoot %00`
    Marek Polák - crwdns2934203:0crwdne2934203:0
    Running Big Sur 11.6.7 on a 2019 16" MBP, it's "auto-boot". So it's: nvram -p | grep 'auto-boot' to display the current state, the default is true - and then to change it, sudo nvram auto-boot=false which turns it off.
    Ed Mechem -
    This step is completely unnecessary if you follow the guide to disconnect the battery properly. Just put some tape between the battery and logic board connection to prevent it from accidentally touching and therefore powering on the laptop.
    Grant Ormsby - crwdns2934203:0crwdne2934203:0
    It took me a few tries to make this command work, as I was able to copy and paste the command into Terminal, but could not type in my laptop’s password. I finally typed my password into a text document, copied it (command C), and then pasted it into Terminal and it worked.
    tommy404 - crwdns2934203:0crwdne2934203:0
    I didn’t do this. Mine never auto-booted before I replaced the battery. Now it does.
    hatuxka - crwdns2934203:0crwdne2934203:0
    BEFORE YOU DO ANYTHING - CHECK THE BATTERY!
    I-fixit sent me a bad battery, which I didn’t realize until it was already install. They sent me a new one, but I wasted hours uninstalling and reinstalled.
    Get a volt meter and measure the voltage on the output of the battery pack. If it reads 0 V, SEND IT BACK. It should read over 2 V.
    bcardanha - crwdns2934203:0crwdne2934203:0
    I've just received my replacement battery and it reads 0,042V between the two main connectors. Do you think it's dead?
    peter sussex -
    When I did this from Terminal.app within Recovery Mode, the “sudo” was not recognized but I could invoke it without the sudo part. It seems to have been accepted when looking at “nvram -p”
    johann beda - crwdns2934203:0crwdne2934203:0
    When in Recovery Mode, you already have superuser powers. So you don't need to prefix commands with the sudo command to invoke them with root privileges; you already have them. Do a pwd (print working directory) after opening Terminal in Recovery Mode, and you'll see that you're in the root user's directory.
    Ed Mechem -
    I received the battery kit for my 2018 MacBook Pro and as per the above comment from bcardanha - Oct 12, 2021, I checked the voltage on the pads marked + and - . It was zero volts so I panicked a bit.
    I sent a message on the iFixiT Facebook page and I got no reply. I finally found the customer service email for Ifixit Europe and sent them an email voicing my concern as I was not keen to work for couple of hours just to discover that the battery is faulty. I had an almost instant reply on the email (kudos to them) and they adviced me to go ahead and install the new battery as the voltage measured when battery is not connected is not relevant.
    I took a leap of faith and after two hours… the new battery showed 50% charge and everything seems to be working just fine. I am happy it worked.
    Mircea Comanici - crwdns2934203:0crwdne2934203:0
    After removing the old battery and installing the new battery I powered up the MBP before screwing the bottom on. I discovered the my keyboard would not function. It took a few hours of investigation and frustration that I discovered the track pad power ribbon had become partially dislodged from the trackpad. I was able to see that this through the little machined slot where the battery sat. I had to remove the trackpad to reinsert the power ribbon back into the connector in the trackpad. after reassembling and reinstalling the battery etc the keyboard worked. Just food for thought if your run into the keyboard issue.
    Ed Mease - crwdns2934203:0crwdne2934203:0
    This should be the default. IMO I tell you to power on - not the lid.
    G Sena - crwdns2934203:0crwdne2934203:0
    Est ce que cela fonctionne sur un macbook pro 2017 sans touchbar ?
    maël muzelet - crwdns2934203:0crwdne2934203:0
    Bonjour Maël, oui, ce tutoriel concerne "les MacBook Pro 2016 (et plus récents) et les MacBook Retina 12" 2017 (et plus récents)"
    Claire Miesch -
    Excellent instructions. I was able to follow and install the new screen. I recommend that you get a good set of tools before you begin. I started with an inexpensive repair kit bought online. The Penta and torx bits failed. I bought an IFIXIT kit with quality bits and I was able to do everything I needed.
    Tom Markham - crwdns2934203:0crwdne2934203:0
    If you're not running an admin account the sudo command won't work (which honestly, you should not be running admin). Rather than logging in to your admin amount via the OS, in the terminal type "login [admin username]," then the password and you'll be able to do the sudo command as described above. Once you're complete, type "logout [admin username]" and you'll be good to go. Obviously replace [admin username] with whatever the account name for your admin user is.
    arichard2401 - crwdns2934203:0crwdne2934203:0
    For those unable to complete this step because the screen is too damaged I recommend leaving your macbook on until the battery dies.
    Nicholas R Licato - crwdns2934203:0crwdne2934203:0
    Just replaced my 2018 15" MBP battery. Running Sonoma.
    I found no way to disable AutoBoot (The status can be checked in the Power section of system report).
    Anyway, i left my battery completely drain before opening the MBP, and had no issues during the process.
    Cédric Bontems - crwdns2934203:0crwdne2934203:0
    After sending this command in terminal when I checked what happens if I now open the lid, instead the screen lit slightly up (still black) then a battery symbol showing the charging state showed up.
    Now, after replacement of the battery, this is all I get to see.
    No reset of NVRAM nor PRAM helped.
    Currently the new battery charges (58% atm) and it feels like it‘s mocking me.
    webrockers - crwdns2934203:0crwdne2934203:0
    I suspected the keyboard or TouchID sensor wouldn’t work, so I went on and checked every connector.
    I missed connecting the left TouchID sensor from step 31.
    webrockers -
    Read the comments section at the bottom of the article before proceeding with the repair. It is unnecessary to remove the logic board. I actually removed the 45mm plastic bar to enable the cables to slip out then in. It is only there to frustrate repairers!
    Jack - crwdns2934203:0crwdne2934203:0
  2. MacBook Pro 15" Touch Bar 2019 Screen Replacement, Lower Case: crwdns2935265:02crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 MacBook Pro 15" Touch Bar 2019 Screen Replacement, Lower Case: crwdns2935265:02crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    Magnetic Project Mat
    $19.95
    • Completely power off and unplug your MacBook Pro before you start. Close the display and flip the entire laptop upside-down.
    • Use a P5 Pentalobe driver to remove six screws securing the lower case, of the following lengths:
    • Four 4.7 mm screws
    • Two 6.6 mm screws
    • Note how the screws come out at a slight angle—you must reinstall them the same way.
    • Throughout this repair, keep track of each screw and make sure it goes back exactly where it came from to avoid damaging your device.
    I miss a printable template to leave the screws and removed parts on it for future identification when reassembly, linked maybe with the location in the Macbook, or with the number of the step.
    Juan Ignacio Fernández García - crwdns2934203:0crwdne2934203:0
  3. MacBook Pro 15" Touch Bar 2019 Screen Replacement: crwdns2935265:03crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 MacBook Pro 15" Touch Bar 2019 Screen Replacement: crwdns2935265:03crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Press a suction handle into place near the front edge of the lower case, between the screw holes.
    • Pull up on the suction handle just enough to open a small gap under the lower case.
    Throw away this suction cup and get another. It just doesn't work! Luckily I had one that does work in my tool kit.
    Greek Taylor - crwdns2934203:0crwdne2934203:0
  4. MacBook Pro 15" Touch Bar 2019 Screen Replacement: crwdns2935265:04crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 MacBook Pro 15" Touch Bar 2019 Screen Replacement: crwdns2935265:04crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 MacBook Pro 15" Touch Bar 2019 Screen Replacement: crwdns2935265:04crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Slide the corner of an opening pick into the gap you just created underneath the lower case.
    • Slide the opening pick around the nearest corner and then halfway up the side of the MacBook Pro.
    • This releases the first of the hidden clips securing the lower case. You should feel and hear the clip pop free.
  5. MacBook Pro 15" Touch Bar 2019 Screen Replacement: crwdns2935265:05crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 MacBook Pro 15" Touch Bar 2019 Screen Replacement: crwdns2935265:05crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 MacBook Pro 15" Touch Bar 2019 Screen Replacement: crwdns2935265:05crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Repeat the previous step on the other side, using an opening pick to to release the second clip.
  6. MacBook Pro 15" Touch Bar 2019 Screen Replacement: crwdns2935265:06crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Lift the front edge of the lower case (the side opposite the display hinge) enough to slide your fingertips underneath and get a good grip on it.
    • Two additional hidden clips near the middle of the cover should pop free at this point, if they haven't already.
    • Don't lift more than an inch or so, and don't try to remove the lower case yet.
  7. MacBook Pro 15" Touch Bar 2019 Screen Replacement: crwdns2935265:07crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 MacBook Pro 15" Touch Bar 2019 Screen Replacement: crwdns2935265:07crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 MacBook Pro 15" Touch Bar 2019 Screen Replacement: crwdns2935265:07crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Pull firmly to slide the lower case towards the front edge of the MacBook (away from the hinge area) to separate the last of the clips securing the lower case.
    • Pull first at one corner, then the other.
    • Pull to the side—not up.
    • This may require a lot of force.
    With the amount of force needed to carefully pull the back panel out, this caused the back panel to scratch the battery. I don't see or hear any expansion, but this still has me concerned.
    gladgura - crwdns2934203:0crwdne2934203:0
    this step must require a lot of force. I tried to pull it with the plastic hookie thing from the ifixit set by hooking it in one of the screw holes — the tip of the hookie thing broke.
    Oleksii Toldaiev - crwdns2934203:0crwdne2934203:0
    The amount of force required for removing the bottom cover is absolutely ridiculous. Almost feels like i'm about to push my MacBook towards the wall the second it comes off.
    Be careful, I ended up breaking 2 grounding pins on the motherboard last time I tried opening my computer up.
    techtalkf - crwdns2934203:0crwdne2934203:0
    PLEASE DON'T PULL!!!
    Instead just gently push with plastic pick from the other side (where vents outputs are) towards the center... Cover will very easily open that way.
    I hope iFixit will correct this step.
    Kamil Roman - crwdns2934203:0crwdne2934203:0
    Came here to share exactly this.
    Robert -
    That's definitely how this step should be done. Thanks!
    VovS -
    If someone has a photo to share regarding this comment, it might be very useful. Thanks.
    Mark Cohen -
    I used a screwdriver at 45 degrees angle and pushed the cover from the hinges, it worked really smooth. I had it close to the corners.
    Martin Lundgren - crwdns2934203:0crwdne2934203:0
    Yeah, definitely don't pull; if you do, wear protective gloves. Mine was stuck so strongly that I just cut my palm quite deep.
    Kirill Chernov (PowerDoge) - crwdns2934203:0crwdne2934203:0
    You would think ifixit would investigate why the last step required them to pull with great force to remove the bottom case lid as the solution.
    It's counter-intuitive to use an excessive method to remove a part.
    There's always an easier way. It's frustrating because you can't see inside.
    Cary B - crwdns2934203:0crwdne2934203:0
    Using the iFixit opening Tool in the hinge opening required close to no force to open.
    Anders Markstrom - crwdns2934203:0crwdne2934203:0
    Ah... after attempting to 'pull' this rear cover off, to no avail, I tried to coax the cover off with a nylon pry tool. MUCH better! iFixIt will do well to amend it's recommendation to 'pull' this cover in any way. All I wanted to do was a little house cleaning and exorcize the dust bunnies that took up residence in my MBP's fans. Today is much quieter. Thank you all for pointing out the obvious.
    P.C. - crwdns2934203:0crwdne2934203:0
    I was able to very simply slide the case forward from the back of the hinges toward the front (where the trackpad is) and using the spudger thing to gently pry the edge of the bottom case (near the vents / display) 'forward' instead of pulling corners etc. Was actually really easy and slid simply.
    James Scanlon - crwdns2934203:0crwdne2934203:0
    This tip was the most helpful for me, used the blue prying tool that comes in the kit and lifted the hinge end up just slightly aiming for the middle of the cover, then pulled the whole cover towards the front (not lifting, pulling towards the front) and is slide right out.
    Stanley Dharan -
    Correction; When prying, aim just slightly left or right from the middle of the cover about and inch or so because there is some insulating material right in the middle that can get peeled off if you go dead center
    Stanley Dharan -
    I agree this is the easiest way to do it.
    LeBarron Durant -
    Stanley Dharan - crwdns2934203:0crwdne2934203:0
    Well, I tried a few things including pulling forward with a large piece of strong adhesive tape. What finally worked for me was using a rubber mallet to tap gently on the cover's side edges near its two front corners, to loosen it. Then I was able to pull it forward and off.
    Kenneth Chin - crwdns2934203:0crwdne2934203:0
  8. MacBook Pro 15" Touch Bar 2019 Screen Replacement: crwdns2935265:08crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 MacBook Pro 15" Touch Bar 2019 Screen Replacement: crwdns2935265:08crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 MacBook Pro 15" Touch Bar 2019 Screen Replacement: crwdns2935265:08crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Remove the lower case.
    • To reinstall the lower case:
    • Set it in place and align the sliding clips near the display hinge. Press down and slide the cover toward the hinge. It should stop sliding as the clips engage.
    • When the sliding clips are fully engaged and the lower case looks correctly aligned, press down firmly on the lower case to engage the four hidden clips underneath. You should feel and hear them snap into place.
    If I had it all to do over, again, I would blow out the dust with compressed air at this point. During the disassembly, I kept encountering little dust bunnies, and I was very worried that one would get caught in one of the connectors when I plugged everything back up (which wouldn’t get discovered until I put it all back together and tried out all of the components).
    Joe Emenaker - crwdns2934203:0crwdne2934203:0
  9. MacBook Pro 15" Touch Bar 2019 Screen Replacement, Battery Connector: crwdns2935265:09crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Peel up and remove the insulating sticker covering the battery board, on the edge of the logic board nearest the battery.
    • If the cover doesn't peel up easily, apply mild heat with an iOpener, hair dryer, or heat gun to soften the adhesive underneath, and try again.
    • If the cover doesn't seat securely during reassembly, try rotating it 180 degrees. It must be oriented correctly in order for the adhesive pads underneath to contact the board screws.
    i need a ziff connector flap for step 10
    Gregg Gorin - crwdns2934203:0crwdne2934203:0
  10. MacBook Pro 15" Touch Bar 2019 Screen Replacement: crwdns2935265:010crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 MacBook Pro 15" Touch Bar 2019 Screen Replacement: crwdns2935265:010crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 MacBook Pro 15" Touch Bar 2019 Screen Replacement: crwdns2935265:010crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Peel back any tape covering the battery board data cable connector.
    • Use a spudger to gently pry up the locking flap on the ZIF connector for the battery board data cable.
  11. MacBook Pro 15" Touch Bar 2019 Screen Replacement: crwdns2935265:011crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 MacBook Pro 15" Touch Bar 2019 Screen Replacement: crwdns2935265:011crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Disconnect the battery board data cable by sliding it out from its socket on the logic board.
    • Slide parallel to the logic board, in the direction of the cable.
  12. MacBook Pro 15" Touch Bar 2019 Screen Replacement: crwdns2935265:012crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 MacBook Pro 15" Touch Bar 2019 Screen Replacement: crwdns2935265:012crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Pry up and disconnect the locking flap on the connector at the opposite end of the battery board data cable.
  13. MacBook Pro 15" Touch Bar 2019 Screen Replacement: crwdns2935265:013crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 MacBook Pro 15" Touch Bar 2019 Screen Replacement: crwdns2935265:013crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Slide the battery board data cable out of its socket on the battery board, and remove it completely.
    • Take care not to install this cable backwards or upside-down. When installed correctly, the white liquid indicator sticker should face up, positioned directly over the battery power connector screw.
    Bonjour, super Tuto, petite question elle sert a quoi cette nappe , et quesqui se passe si elle est pas branché ?
    Jorgio -aigleBrun- - crwdns2934203:0crwdne2934203:0
  14. MacBook Pro 15" Touch Bar 2019 Screen Replacement: crwdns2935265:014crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 MacBook Pro 15" Touch Bar 2019 Screen Replacement: crwdns2935265:014crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Use a T5 Torx driver to remove the 3.7 mm pancake screw securing the battery power connector.
  15. MacBook Pro 15" Touch Bar 2019 Screen Replacement: crwdns2935265:015crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 MacBook Pro 15" Touch Bar 2019 Screen Replacement: crwdns2935265:015crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Use a spudger to lift the battery power connector, disconnecting the battery.
    • Lift the connector high enough to keep it separated from its socket while you work. If it accidentally makes contact, it could damage your MacBook Pro.
    Put a little bit of insulating tape over the terminal to be safe.
    Brian Tibbels - crwdns2934203:0crwdne2934203:0
    Agreed - once this is back in place, the system is energized, you run the risk of creating little sparks or worse if metal objects such as cover brackets accidentally touch areas of the logic board.
    bkbkbk - crwdns2934203:0crwdne2934203:0
    I used painters tape to insulate the contacts. LOL!
    VicRod74 - crwdns2934203:0crwdne2934203:0
  16. MacBook Pro 15" Touch Bar 2019 Screen Replacement, Screen: crwdns2935265:016crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 MacBook Pro 15" Touch Bar 2019 Screen Replacement, Screen: crwdns2935265:016crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Use a T3 Torx driver to remove the two 3.5 mm screws securing the cover on the display board flex cable.
    • Remove the display board flex cover.
    T3 or T4? I almost damage the screw trying with the T3.
    Christian Polychroniadis - crwdns2934203:0crwdne2934203:0
    I’d say T4 as T3 was definitely too small
    David Smith -
  17. MacBook Pro 15" Touch Bar 2019 Screen Replacement: crwdns2935265:017crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 MacBook Pro 15" Touch Bar 2019 Screen Replacement: crwdns2935265:017crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Use a T3 Torx driver to remove the two 1.7 mm screws securing the bracket for the display board cable connector.
    • Remove the display board cable connector bracket.
    Step requires T4 Torx instead of T3 Torx.
    Banana - crwdns2934203:0crwdne2934203:0
    I damaged the screw trying to use a T3. Now I am screwed.
    markshain - crwdns2934203:0crwdne2934203:0
    This wasn't seated right when I reassembled and the MBP didn't turn on. Crestfallen.... I had to take it apart and really make sure that this seated properly. It powered up.
    Sean Williams - crwdns2934203:0crwdne2934203:0
  18. MacBook Pro 15" Touch Bar 2019 Screen Replacement: crwdns2935265:018crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 MacBook Pro 15" Touch Bar 2019 Screen Replacement: crwdns2935265:018crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Pry the display board flex cable straight up from its socket to disconnect it from the display board.
  19. MacBook Pro 15" Touch Bar 2019 Screen Replacement: crwdns2935265:019crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 MacBook Pro 15" Touch Bar 2019 Screen Replacement: crwdns2935265:019crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Use a T3 Torx driver to remove the four 2.0 mm screws from the hinge covers (two screws on each side).
  20. MacBook Pro 15" Touch Bar 2019 Screen Replacement: crwdns2935265:020crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 MacBook Pro 15" Touch Bar 2019 Screen Replacement: crwdns2935265:020crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 MacBook Pro 15" Touch Bar 2019 Screen Replacement: crwdns2935265:020crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Remove both hinge covers.
  21. MacBook Pro 15" Touch Bar 2019 Screen Replacement: crwdns2935265:021crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 MacBook Pro 15" Touch Bar 2019 Screen Replacement: crwdns2935265:021crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Use a T5 Torx driver to remove the single 2.9 mm screw securing the antenna cable bundle.
  22. MacBook Pro 15" Touch Bar 2019 Screen Replacement: crwdns2935265:022crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 MacBook Pro 15" Touch Bar 2019 Screen Replacement: crwdns2935265:022crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 MacBook Pro 15" Touch Bar 2019 Screen Replacement: crwdns2935265:022crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Disconnect all three antenna cables by prying each one straight up from its socket.
    • Slide your tweezers or the flat end of your spudger underneath each cable until it's near the socket, and then gently twist or pry up to disconnect it.
    • To reconnect each cable, align the connector directly over its socket, and then press down so it snaps into place.
  23. MacBook Pro 15" Touch Bar 2019 Screen Replacement: crwdns2935265:023crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 MacBook Pro 15" Touch Bar 2019 Screen Replacement: crwdns2935265:023crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 MacBook Pro 15" Touch Bar 2019 Screen Replacement: crwdns2935265:023crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Use a T5 Torx driver to remove the four 3.3 mm screws securing the display board.
    • Before reinstalling these screws:
    • Make sure the display board flex cable lies on top of the board, not trapped underneath.
    When reassembling, I found that I had to press in on the outer edge of the antenna (top edge when looking at the picture) at the midpoint between the left 8 screws and the right 8 screws as I screwed the display board screws in. I found that the outside antenna edge would otherwise rub against the display halfway through opening it making a pop sound. Installing this way fixed the problem.
    Robert Scheid - crwdns2934203:0crwdne2934203:0
    Running into the same issue with the pop sound. Could you explain a bit more as to what exactly needs to be pressed in, its a bit unclear :/
    Shubhang sharma -
  24. MacBook Pro 15" Touch Bar 2019 Screen Replacement: crwdns2935265:024crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 MacBook Pro 15" Touch Bar 2019 Screen Replacement: crwdns2935265:024crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Use a P2 Pentalobe driver to remove the sixteen 1.5 mm screws securing the antenna assembly.
    I’m having difficulty removing the screws. I’m not sure if the p2 screwdriver is defective but I am now stuck at this step.
    Sonia Carrillo-Ramirez - crwdns2934203:0crwdne2934203:0
    i can only seem to get 2/3 of the screws out
    Leif - crwdns2934203:0crwdne2934203:0
    After giving up, someone else got them all out in about 10 sec using the Apple pentalope screwdriver, specific to Apple.
    The 4 of Pentalobe5 screws in the middle between the two sets of 8 screws also need to be removed.
    pboyle - crwdns2934203:0crwdne2934203:0
    Oooops, wrong, those are 4 of T5 screws in the middle
    Ok, wrong again. Step 23 is this set of 4 of T5s.
    The step that is missing is removing the set of 4 of T3s that hold the display flexes and springs.
    Sorry about the mess of corrections.
    We had 4 MBP's that I removed the displays from. On this step, I stripped a 'middle' screw on each side.
    On the second one, I also noticed the middle screws didn't exactly want to easily come loose as I worked my way down the row.
    I wound up putting all screws back in, loosened then tightened the screw on the opposite end, then removed the two in the middle (without issue), then an outside screw going back and forth, until I just had one on each end. Since I had already removed and replaced them, they came out without issue.
    I used this method on the remaining 2 MBP's and had no further issues.
    YMMV and it may not even be necessary. Just seemed removing the screws from end to end put enough pressure on the remaining ones that they were harder to remove. Whereas a patterned removal seemed to resolve that 'issue'.
    fozman2 - crwdns2934203:0crwdne2934203:0
    so i had to first loosen all the screws just a little bit and then bit by bit remove one from each side, then remove the corresponding one from the other side and so on. This helped make sure that the entire thing comes off properly.
    I think the reason people were running into issues is because the screws are keeping the two parts together under tension, and if you remove a few of them completely, the remaining screws get under a lot of stress. So yeah, just loosen all of them a little bit first
    Shubhang sharma - crwdns2934203:0crwdne2934203:0
  25. MacBook Pro 15" Touch Bar 2019 Screen Replacement: crwdns2935265:025crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 MacBook Pro 15" Touch Bar 2019 Screen Replacement: crwdns2935265:025crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 MacBook Pro 15" Touch Bar 2019 Screen Replacement: crwdns2935265:025crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Use an opening pick to pry up the antenna assembly and separate it from the MacBook Pro.
    • Watch out for the delicate ribbon cables in the middle section. Avoid sliding the pick from side to side so as not to damage the cables.
  26. MacBook Pro 15" Touch Bar 2019 Screen Replacement: crwdns2935265:026crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 MacBook Pro 15" Touch Bar 2019 Screen Replacement: crwdns2935265:026crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 MacBook Pro 15" Touch Bar 2019 Screen Replacement: crwdns2935265:026crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Carefully remove the antenna assembly, while simultaneously feeding the antenna cable bundle out from underneath the heat sink.
    • During reassembly, gently pinch the cable bundle together and guide it under the heat pipe into the correct position on the board. If needed, use your tools to help guide it through, but don't force it.
  27. MacBook Pro 15" Touch Bar 2019 Screen Replacement: crwdns2935265:027crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 MacBook Pro 15" Touch Bar 2019 Screen Replacement: crwdns2935265:027crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Use a T3 Torx driver to remove the four 3.9 mm screws securing the display cable cover springs.
    nah T3 for the macbook pro 15 inch 2019 A1990
  28. MacBook Pro 15" Touch Bar 2019 Screen Replacement: crwdns2935265:028crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 MacBook Pro 15" Touch Bar 2019 Screen Replacement: crwdns2935265:028crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Use a T8 Torx driver to remove two 4.9 mm screws from each hinge (four screws total).
    • Each hinge has a third screw, which you should leave in place for now.
    needed some a gentle but extra torque to loosen them up
  29. MacBook Pro 15" Touch Bar 2019 Screen Replacement: crwdns2935265:029crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 MacBook Pro 15" Touch Bar 2019 Screen Replacement: crwdns2935265:029crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 MacBook Pro 15" Touch Bar 2019 Screen Replacement: crwdns2935265:029crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • During reassembly, first install the hinge screws without tightening them. Then adjust the screen until it is correctly centered and aligned on each side. Finally, tighten the screws.
    • If your screen clicks or snaps upon opening, loosen the hinge screws and adjust the alignment. Make sure the screen doesn't sit too far forward, or it can catch on the body when opening and closing.
    • If desired, add a little blue threadlocker to the screw threads to prevent them from loosening over time.
  30. MacBook Pro 15" Touch Bar 2019 Screen Replacement: crwdns2935265:030crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 MacBook Pro 15" Touch Bar 2019 Screen Replacement: crwdns2935265:030crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • If you plan to re-use your screen, open it and apply a piece of tape to the glass directly above each hinge. This helps protect the glass from getting scratched in the following step.
    • Fully open the screen and stand your MacBook Pro up on one side.
  31. MacBook Pro 15" Touch Bar 2019 Screen Replacement: crwdns2935265:031crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 MacBook Pro 15" Touch Bar 2019 Screen Replacement: crwdns2935265:031crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 MacBook Pro 15" Touch Bar 2019 Screen Replacement: crwdns2935265:031crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Use a T8 Torx driver to remove the two remaining 4.9 mm hinge screws (one from each hinge).
    • Remove the topmost screw last, using one hand to steady both halves of the MacBook Pro to make sure they don't separate and fall over unexpectedly.
  32. MacBook Pro 15" Touch Bar 2019 Screen Replacement: crwdns2935265:032crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 MacBook Pro 15" Touch Bar 2019 Screen Replacement: crwdns2935265:032crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 MacBook Pro 15" Touch Bar 2019 Screen Replacement: crwdns2935265:032crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Keep a firm grip on both the screen and main body of the MacBook Pro. Either half can fall unexpectedly during this step.
    • Push both halves of the MacBook Pro together so that the hinges can be lifted clear of their recesses in the chassis.
    • Push the main body of the MacBook Pro away from you while pulling the screen toward you to separate it.
  33. MacBook Pro 15" Touch Bar 2019 Screen Replacement: crwdns2935265:033crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the screen.
crwdns2935229:022crwdne2935229:0
Jeff Suovanen
crwdns2935283:008/06/13crwdne2935283:0
440,922 crwdns2915208:0crwdne2915208:0
crwdns2935297:0259crwdne2935297:0
Staff
crwdns2935297:019,857crwdne2935297:0
crwdns2947412:09crwdne2947412:0
This is such a noob question but how do I marked that”I did this repair”.
Andres Torres - crwdns2934203:0crwdne2934203:0
Do you have a link to a Apple Screen?
Paul - crwdns2934203:0crwdne2934203:0
wo bekommt man denn einen MacBook pro 15 zoll 2019 Display her?
drumma15 - crwdns2934203:0crwdne2934203:0
I followed all of these steps to replace my display and when I put it all back together my Mac would only turn on when it was plugged into the wall. So the new display works fine but it doesn’t seem to recognize the battery at all. Has anyone run into this problem and know what the issue might be?
Jason - crwdns2934203:0crwdne2934203:0
Jason - did you plug the battery connector and cable back in correctly?
Kevin Gill - crwdns2934203:0crwdne2934203:0
I need anew battery connector mine i missing one end maybe …
my screen was replaced by a dealer and I found missing screws and the battery board data cable was glued so hard with a piece of tape when I pulled it out one side showed connection wires the other was nothing ,what don I do when I get a new one (if i can get one?..,,,
Robert Reser - crwdns2934203:0crwdne2934203:0
i am confused by the direction and how difficult such a simple step can stop me cold the battery connector is very fragile and i was not prepared for the outcome
i need help what can i do next. Thanks
Robert Reser
Can this model MacBook Pro 2019 A1990 work as a headless Mac
KrazyKaleb - crwdns2934203:0crwdne2934203:0
Is there a specific screen that is specific to this Touch Bar MacBook please? Or is it simply a second hand screen from any A1990 MacBook Pro 15”, right colour? There are a few on eBay etc
Slatez - crwdns2934203:0crwdne2934203:0
crwdns2936753:07crwdne2936753:0 66
crwdns2936753:030crwdne2936753:0 333
crwdns2942667:0crwdne2942667:0 54,536
