Logitech MX Master 3S Top Shell Replacement
  1. Logitech MX Master 3S Top Shell Replacement, Soften the mouse feet adhesive: crwdns2935265:01crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Logitech MX Master 3S Top Shell Replacement, Soften the mouse feet adhesive: crwdns2935265:01crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Logitech MX Master 3S Top Shell Replacement, Soften the mouse feet adhesive: crwdns2935265:01crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Flip the mouse's power switch into the OFF position, unplug any cables, and flip it over so the feet are facing up.
    • The unique shape of some mice can prevent them from laying flat. If you need to, lay your mouse on a soft towel to prevent wobble.
    • If you're planning to reuse your existing mouse feet, note that the adhesive needs to be thoroughly heated for them to be cleanly removed.
    • Heat an iOpener and apply it to each of the mouse feet for about one minute each.
    • Alternatively, you can use a hair dryer to soften the mouse feet adhesive.
    • When using a hair dryer, don't heat the feet for more than a couple seconds at a time—anything hotter than just warm to the touch risks melting or warping the plastic lower case.
    • The information sticker adhesive may soften during this step, but you don't need to remove it.
  2. Logitech MX Master 3S Top Shell Replacement, Separate the mouse foot adhesive: crwdns2935265:02crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Logitech MX Master 3S Top Shell Replacement, Separate the mouse foot adhesive: crwdns2935265:02crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Logitech MX Master 3S Top Shell Replacement, Separate the mouse foot adhesive: crwdns2935265:02crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Slide an opening pick under an edge of the left mouse foot.
    • Go slowly, and make sure the pick slides underneath both the foot and its adhesive pad. These layers separate easily.
    • If you plan on reusing your mouse feet, be careful not to crease them or separate them from their adhesive pads.
    • If the foot feels stuck, apply more heat before continuing.
    • Slide your pick under the foot to separate its adhesive until you can grab it with your fingers.
    • Peel up and remove the left mouse foot.
  3. Logitech MX Master 3S Top Shell Replacement, Remove the remaining feet: crwdns2935265:03crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Logitech MX Master 3S Top Shell Replacement, Remove the remaining feet: crwdns2935265:03crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Logitech MX Master 3S Top Shell Replacement, Remove the remaining feet: crwdns2935265:03crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Repeat the previous two steps for the three remaining feet.
    • The front foot doesn't cover any screws—if you're only removing the mouse feet to open up the mouse, you don't need to remove this foot.
  4. Logitech MX Master 3S Top Shell Replacement, Reassembly information: crwdns2935265:04crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Logitech MX Master 3S Top Shell Replacement, Reassembly information: crwdns2935265:04crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Logitech MX Master 3S Top Shell Replacement, Reassembly information: crwdns2935265:04crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • If the adhesive separated from the foot:
    • Slide the flat end of a spudger under an edge of the adhesive. If the adhesive seems stuck, you may need to heat the adhesive further.
    • Use a pair of tweezers or a spudger to remove any large chunks of leftover adhesive.
    • For installing new mouse feet or reusing your old ones:
    • Thoroughly clean the bottom of the mouse with isopropyl alcohol and a lint-free of microfiber cloth. Allow the surface to dry completely.
    • Peel your new mouse feet away from their adhesive liners and press them firmly into place.
    Why are we removing leftover adhesive if we went to the trouble of heating for full removal (and reuse)?
    This makes no sense. Might as well just rip em off!
    craigalanelliott - crwdns2934203:0crwdne2934203:0
  5. Logitech MX Master 3S Top Shell Replacement, Unfasten the lower case: crwdns2935265:05crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Use a Phillips screwdriver to remove the five 4.3 mm‑long screws securing the bottom half of the lower case.
    • Use a T5 Torx driver to remove the one 4.2 mm‑long screw securing the top half of the lower case.
    El texto del segundo paso está mal. Se repite con el primero.
    Manuel Sánchez - crwdns2934203:0crwdne2934203:0
    Whats the circumference of the screws? You just talk about the length.
    phonc - crwdns2934203:0crwdne2934203:0
  6. Logitech MX Master 3S Top Shell Replacement, Release the left clips: crwdns2935265:06crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Logitech MX Master 3S Top Shell Replacement, Release the left clips: crwdns2935265:06crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Logitech MX Master 3S Top Shell Replacement, Release the left clips: crwdns2935265:06crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Insert your opening pick into the seam between the thumb rest and the lower case.
    • Slide your pick right, towards the rear of the upper shell and pry upward to release the left clips.
  7. Logitech MX Master 3S Top Shell Replacement, Release the right clips: crwdns2935265:07crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Logitech MX Master 3S Top Shell Replacement, Release the right clips: crwdns2935265:07crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Gently pry the upper shell and lower case apart to release the clips on the right side of the mouse.
    • Don't try to fully remove the top shell just yet—another clip and a delicate cable connect the upper shell to the lower case.
  8. Logitech MX Master 3S Top Shell Replacement, Release the final clip: crwdns2935265:08crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Logitech MX Master 3S Top Shell Replacement, Release the final clip: crwdns2935265:08crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Logitech MX Master 3S Top Shell Replacement, Release the final clip: crwdns2935265:08crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Lay your mouse down onto your work surface, making sure none of the clips re-engage.
    • Grasp the upper shell and partially lift up the right edge.
    • Pull the upper shell up and back to release the final clip and separate the upper shell from the lower case.
    • Still keep the two halves close together—a cable is still tethered to the upper shell.
    • To reinstall the upper shell, slide the front edge into place first, then press down around the perimeter of the upper shell to engage the remaining clips.
  9. Logitech MX Master 3S Top Shell Replacement, Reposition the upper shell: crwdns2935265:09crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Logitech MX Master 3S Top Shell Replacement, Reposition the upper shell: crwdns2935265:09crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Logitech MX Master 3S Top Shell Replacement, Reposition the upper shell: crwdns2935265:09crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Be careful not to strain the cable connecting the upper shell to the lower case.
    • Lift the upper shell away from the lower case and lay it to the right of the mouse.
  10. Logitech MX Master 3S Top Shell Replacement, Disconnect the interconnect cable: crwdns2935265:010crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Logitech MX Master 3S Top Shell Replacement, Disconnect the interconnect cable: crwdns2935265:010crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Logitech MX Master 3S Top Shell Replacement, Disconnect the interconnect cable: crwdns2935265:010crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Use the flat end of a spudger to gently lift up the sliding lock on the interconnect cable socket.
    • Slide the cable straight out of its socket on the motherboard.
    • During reassembly, insert the cable into the socket with its blue tab facing out, then push down the sliding lock to secure the cable.
    The lock broke trying to reinsert the ribbon cable. Be careful.
    Garrett Vogele - crwdns2934203:0crwdne2934203:0
  11. Logitech MX Master 3S Top Shell Replacement, Remove the upper shell: crwdns2935265:011crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the upper shell from the lower case.
    Dear Logitech, please support the upper Shell as replacement Part (without doughter-boards)
    FusterCluck - crwdns2934203:0crwdne2934203:0
  12. Logitech MX Master 3S Top Shell Replacement, Disconnect the horizontal scroll wheel assembly: crwdns2935265:012crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Logitech MX Master 3S Top Shell Replacement, Disconnect the horizontal scroll wheel assembly: crwdns2935265:012crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Logitech MX Master 3S Top Shell Replacement, Disconnect the horizontal scroll wheel assembly: crwdns2935265:012crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Lay the top shell upside down on your work surface.
    • Use the flat end of a spudger to push out the plastic latch on the connector near the right side of the shell.
    • You should feel the latch pop into the unlocked position. Don't push too far, or the latch may come completely off the connector.
    • Use tweezers or your fingers to gently pull the cable straight up and out of its socket.
    • The cable should come out easily. If you feel any resistance, push the latch out a little more and try again.
  13. Logitech MX Master 3S Top Shell Replacement, Unfasten the horizontal scroll wheel assembly: crwdns2935265:013crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Logitech MX Master 3S Top Shell Replacement, Unfasten the horizontal scroll wheel assembly: crwdns2935265:013crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Use a Phillips screwdriver to remove the three 3.5 mm‑long screws securing the gesture button board assembly to the underside of the thumb rest.
    • Don't remove the two smaller screws in the board itself.
  14. Logitech MX Master 3S Top Shell Replacement, Unclip the gesture button board: crwdns2935265:014crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Logitech MX Master 3S Top Shell Replacement, Unclip the gesture button board: crwdns2935265:014crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Logitech MX Master 3S Top Shell Replacement, Unclip the gesture button board: crwdns2935265:014crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Don't try to fully remove the gesture button board assembly. It'll be removed together with the horizontal scroll wheel assembly in a few steps.
    • Push down the outer edge of the thumb rest to unclip the right edge of the gesture button board assembly.
    • Lift the assembly off its alignment posts and pull it towards the center of the shell.
  15. Logitech MX Master 3S Top Shell Replacement, Remove the horizontal scroll wheel assembly screws: crwdns2935265:015crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Logitech MX Master 3S Top Shell Replacement, Remove the horizontal scroll wheel assembly screws: crwdns2935265:015crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Use a Phillips screwdriver to remove the two 3.5 mm‑long screws securing the horizontal scroll wheel assembly.
    How big are these 3.5mm long screws? As in, what diameter
  16. Logitech MX Master 3S Top Shell Replacement, Remove the horizontal scroll wheel assembly: crwdns2935265:016crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Logitech MX Master 3S Top Shell Replacement, Remove the horizontal scroll wheel assembly: crwdns2935265:016crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Logitech MX Master 3S Top Shell Replacement, Remove the horizontal scroll wheel assembly: crwdns2935265:016crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Removing the horizontal scroll wheel assembly is tricky and may take a few tries—be patient and work slowly.
    • Firmly secure the top shell with one hand.
    • Use your free hand to rotate the horizontal scroll wheel assembly away from the shell and lift to remove it.
    • During reassembly:
    • Make sure the cables in the center of the shell are out of the way so they don't get trapped under the horizontal scroll wheel assembly.
    • Put the assembly back into place so the horizontal scroll wheel and side buttons go into their slots and the plastic housing's circular cutouts go over their pegs.
  17. Logitech MX Master 3S Top Shell Replacement, Remove the left and right click buttons: crwdns2935265:017crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Logitech MX Master 3S Top Shell Replacement, Remove the left and right click buttons: crwdns2935265:017crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Use a Phillips screwdriver to remove the three 3.1 mm‑long screws securing the left and right click buttons.
  18. Logitech MX Master 3S Top Shell Replacement: crwdns2935265:018crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Logitech MX Master 3S Top Shell Replacement: crwdns2935265:018crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Logitech MX Master 3S Top Shell Replacement: crwdns2935265:018crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Be very careful not to lose the two small springs on either side of the scroll wheel cutout. Otherwise, the buttons won't click properly when the mouse is reassembled.
    • Use your fingers to remove the left and right click buttons.
  19. Logitech MX Master 3S Top Shell Replacement, Remove the scroll mode board: crwdns2935265:019crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Logitech MX Master 3S Top Shell Replacement, Remove the scroll mode board: crwdns2935265:019crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Use a Phillips screwdriver to remove the three 3.5 mm‑long screws securing the scroll mode button board.
  20. Logitech MX Master 3S Top Shell Replacement: crwdns2935265:020crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Logitech MX Master 3S Top Shell Replacement: crwdns2935265:020crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Use your fingers to gently lift and remove the scroll mode button board.
  21. Logitech MX Master 3S Top Shell Replacement, Remove the scroll mode button: crwdns2935265:021crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Logitech MX Master 3S Top Shell Replacement, Remove the scroll mode button: crwdns2935265:021crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Use a Phillips screwdriver to remove the 3.1 mm‑long screw securing the scroll mode button.
  22. Logitech MX Master 3S Top Shell Replacement: crwdns2935265:022crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Logitech MX Master 3S Top Shell Replacement: crwdns2935265:022crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Use tweezers or your fingers to lift and remove the scroll mode button.
  23. Logitech MX Master 3S Top Shell Replacement, Remove the battery status indicator: crwdns2935265:023crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Logitech MX Master 3S Top Shell Replacement, Remove the battery status indicator: crwdns2935265:023crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Use a Phillips screwdriver to remove the 3.5 mm‑long screw securing the battery status indicator.
  24. Logitech MX Master 3S Top Shell Replacement: crwdns2935265:024crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Logitech MX Master 3S Top Shell Replacement: crwdns2935265:024crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Logitech MX Master 3S Top Shell Replacement: crwdns2935265:024crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Use tweezers or your fingers to lift the battery status indicator off its post and remove it.
    • During reassembly, insert the indicator into its slot on the edge of the shell and then lower it into place so the screw hole goes onto its post.
  25. Logitech MX Master 3S Top Shell Replacement, Remove the battery status indicator housing: crwdns2935265:025crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Logitech MX Master 3S Top Shell Replacement, Remove the battery status indicator housing: crwdns2935265:025crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Use a Phillips screwdriver to remove the 3.4 mm‑long screw securing the battery status indicator housing.
  26. Logitech MX Master 3S Top Shell Replacement: crwdns2935265:026crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Logitech MX Master 3S Top Shell Replacement: crwdns2935265:026crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Logitech MX Master 3S Top Shell Replacement: crwdns2935265:026crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Use the flat end of a spudger to lift the battery status indicator housing off its post and unclip it.
    • If you're having trouble, use a spudger to push in the housing's small clip.
    • Remove the housing.
    • During reassembly, push the housing into its cutout until it clicks into place.
  27. Logitech MX Master 3S Top Shell Replacement, You're left with the top shell: crwdns2935265:027crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Logitech MX Master 3S Top Shell Replacement, You're left with the top shell: crwdns2935265:027crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Logitech MX Master 3S Top Shell Replacement, You're left with the top shell: crwdns2935265:027crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • You're left with the top shell.
    • During reassembly, you'll need to transfer the parts you removed from the old shell to the new one.
Spencer Day
crwdns2935283:009/14/22crwdne2935283:0
117.474 crwdns2915208:0crwdne2915208:0
crwdns2935297:0837crwdne2935297:0
Staff
crwdns2931471:0119crwdne2931471:0
crwdns2935297:021.044crwdne2935297:0
crwdns2947412:09crwdne2947412:0
Hello. Interesting guide. Where can I buy the top shell? I can't see any option to purchase it. Thanks.
Alan Naïve - crwdns2934203:0crwdne2934203:0
For anyone here with the clicks being less responsive after using it for a while (I used it for a few years before this started happening), I found that after removing the top shell and getting to the switches, and clicking the switches with isopropyl alcohol cotton swab for several times (loosening the dirt between the switch button and the switch body) and drying it, and reconnecting it worked relatively well.
Jun Sung Kim - crwdns2934203:0crwdne2934203:0
Hi, this guide is great, but where can we get a replacement shell?
Chris Jung - crwdns2934203:0crwdne2934203:0
3D printed parts.
Yuhan Liu -
Where is the replacement shell available?
Nick Maskell - crwdns2934203:0crwdne2934203:0
Really really wish a replacement shell would be available from iFixit - it would be an instant buy from me. Honestly if Logitech cares about replacement parts at all they need to make this available. The MX3 top shell is known to get damaged quickly. I have a 3 and a 2S - the 2S looks almost brand new and the 3's shell is breaking down. I'm not buying a $130+ CAD mouse from Logitech again only for this to keep happening with no replacement options out of warranty.
Andre Lapointe - crwdns2934203:0crwdne2934203:0
Soo, still no replacement shell after all this time... Shame.
Other than that, if you are having issues with the responsiveness of the left click after some time, what worked for me was simply running through the solder joints on the left button board with some flux and a hot soldering iron. My guess is (since it is a widespread issue) that they used some low quality solder which gets cracked with time and under stress from the clicks.
teodor1992 - crwdns2934203:0crwdne2934203:0
Hi, I have found the replacement shell in AliExpress. There are several vendors.
Martin Klewe - crwdns2934203:0crwdne2934203:0
The only replacement shells on AliExpress I can see are in the region of €50+ which makes it almost pointless. I did find some sticker sets for €3-5 so will try those instead
Snoopey - crwdns2934203:0crwdne2934203:0
crwdns2936751:024crwdne2936751:0 40
crwdns2936753:07crwdne2936753:0 393
crwdns2936753:030crwdne2936753:0 1,695
crwdns2942667:0crwdne2942667:0 10,671
