Logitech MX Anywhere 3 Mouse Feet Replacement
  1. Logitech MX Anywhere 3 Mouse Feet Replacement, Soften the mouse feet adhesive: crwdns2935265:01crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Logitech MX Anywhere 3 Mouse Feet Replacement, Soften the mouse feet adhesive: crwdns2935265:01crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Flip the mouse's power switch into the OFF position, unplug any cables, and flip it over so the feet are facing up.
    • The unique shape of some mice can prevent them from laying flat. If you need to, lay your mouse on a soft towel to prevent wobble.
    • If you're planning to reuse your existing mouse feet, note that the adhesive needs to be thoroughly heated for them to be cleanly removed.
    • Heat an iOpener and apply it to the mouse feet for about two minutes.
    • Alternatively, you can use a hair dryer to soften the mouse feet adhesive.
    • When using a hair dryer, don't heat the feet for more than a couple seconds at a time—anything hotter than just warm to the touch risks melting or warping the plastic lower case.
  2. Logitech MX Anywhere 3 Mouse Feet Replacement, Disassembly information: crwdns2935265:02crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Logitech MX Anywhere 3 Mouse Feet Replacement, Disassembly information: crwdns2935265:02crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • There are small gaps in the rims surrounding each foot. This is where to place the tool in the next step.
  3. Logitech MX Anywhere 3 Mouse Feet Replacement, Remove the feet: crwdns2935265:03crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Logitech MX Anywhere 3 Mouse Feet Replacement, Remove the feet: crwdns2935265:03crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Logitech MX Anywhere 3 Mouse Feet Replacement, Remove the feet: crwdns2935265:03crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Push the tip of an opening pick underneath the mouse foot adhesive, into the gap in the rim.
    • Go slowly, and make sure the pick slides underneath both the foot and its adhesive pad. These layers separate easily.
    • If you plan on reusing your mouse feet, be careful not to crease them or separate them from their adhesive pads.
    • Slide your pick under the foot to separate its adhesive until you can grab it with your fingers.
    • Repeat to remove the three remaining mouse feet.
    • For installing new mouse feet or reusing your old ones:
    • Use a pair of tweezers or a spudger to remove any large chunks of leftover adhesive. Thoroughly clean the bottom of the mouse with isopropyl alcohol and a lint-free of microfiber cloth. Allow the surface to dry completely.
    • Peel your new mouse feet away from their adhesive liners and press them firmly into place.
    I would also suggest Tesa 61395 Tape as a replacement for the adhesive for the feet. It is extremely strong when applied.
    I use it on the back of a metal plate adhered to my phone for a magnet mount in my car. And is on a silicone case.
    Amazing tape and extremely thin.
    Paolo Alberto - crwdns2934203:0crwdne2934203:0
Compare your new replacement part to the original part—you may need to transfer remaining components or remove adhesive backings from the new part before you install it.
Tobias Isakeit
crwdns2935283:003/31/14crwdne2935283:0
125.811 crwdns2915208:0crwdne2915208:0
crwdns2935297:0189crwdne2935297:0
Tobias Isakeit - Repairability Engineer crwdns2935289:0Tobias Isakeit - Repairability Engineercrwdne2935289:0
Business
crwdns2935297:01.137crwdne2935297:0
After I reassembled my MX Anywhere 3 mouse, when I turn on the switch, the LED at the back of the mouse wheel only blinks red. I have already tried charging it, but the red LED keeps blinking whether it is charging (with the power switch turned on or off) or not charging (with the power switch turned on). Additionally, the LED on the Bluetooth switch, which has 3 options to connect up to 3 devices, no longer turns on. Does anyone can help me?
Alexandre Abreu - crwdns2934203:0crwdne2934203:0
crwdns2936751:024crwdne2936751:0 9
crwdns2936753:07crwdne2936753:0 39
crwdns2936753:030crwdne2936753:0 150
crwdns2942667:0crwdne2942667:0 4,413
