Logitech K800 Battery Replacement
crwdns2942287:0crwdne2942287:0Use this guide to replace the battery in a Logitech K800 wireless keyboard.
For your safety, discharge the battery below 25% before disassembling your keyboard. This reduces the risk of a dangerous thermal event if the battery is accidentally damaged during the repair. If your battery is swollen, take appropriate precautions.
crwdns2944105:0crwdne2944105:0
Use a Phillips driver to remove the 5.7 mm screw securing the rear compartment.
Slide the rear compartment toward the top of the keyboard and remove it.
Slide the edge of an opening tool underneath the bottom edge of the rear cover and pry the cover up to create a gap.
Keeping the opening tool under the rear cover, slide it around the right side of the cover to separate the adhesive and clips on that side.
It may help to push the tool farther under the cover, toward the middle of the keyboard.
Keeping the opening tool under the rear cover, slide it around the left side of the cover to separate the adhesive and clips on that side.
Hinge the bottom of the rear cover up until the clips along the top edge of the cover disengage, then lift the whole cover up to remove it.
Place the top edge of the cover slightly above the top edge of the keyboard, then slide it down into place.
Use a Phillips driver to remove the twelve 5.7 mm screws securing the front cover.
Use a Phillips driver to remove the three 4.7 mm screws securing the keyboard keys.
Slide an opening tool into the seam along one edge of the front cover. Pry the cover up to create a gap.
Slide the opening tool around the perimeter of the front case to release all the clips securing the front cover.
With all the clips released, lift the front cover and remove it.
Be carful when reassembling power switch on circuit must line up with power switch on plastic cover
Use a Phillips driver to remove the six screws securing the keyboard keys.
Four 5.7 mm screws
Two 4.7 mm screws
Gently flip the keyboard keys up and over the top of the keyboard to reveal the backlight.
Gently flip the backlight up and over the top of the keyboard to reveal the keyboard backplate.
Grasp one end of the backplate and lift it off of the keyboard case.
Remove the backplate.
Grasp the top edge of the battery connector with your fingers or a tweezer.
Pull the connector straight out of its socket on the motherboard.
crwdns2935267:0crwdne2935267:0Tweezers$4.99
Use tweezers to remove the tape securing the battery cable to the case.
Pull the battery cable out of its slots in the keyboard case.
Heat an iOpener and apply it to the keyboard case underneath the battery for two minutes.
Use a spudger to pry the battery away from the keyboard case.
If you encounter significant resistance, stop and apply more heat.
Remove the battery.
Thank you, I was looking for a guide like this for a long time.
Easy to follow but why is battery ID picture upside down, and why didn't you snap a decent pic of the connector? Other than that, Well done.
crwdns2935229:018crwdne2935229:0
crwdns2947412:015crwdne2947412:0
the original took 2 lithium AA rechargeables. their update just creates ewaste
not lithium! Just standard Ni-MH AA's. I was pretty disappointed when I bought the second keyboard (the fist one was already pretty beaten up) only to discover that below the battery door there is just plastic and no battery! bastards... I used the keyboard from time to time as 2xAA charger (as most of the time it was connected to power) and I swapped those fully charged batteries with discharged ones from other devices that take 2xAAs aswell
Do you have a part number for the replacement battery?
https://www.canadianbatteries.com/logite...
Search engines are your friend
Gord N -
The part in the canadianbatteries.com link is not the correct part for this keyboard.
The correct PN is 533-000141, this has longer leads on the battery and the battery capacity is larger than the one linked. Aliexpress is the only place I have been able to locate a new one.
Kevin, exactly right. I have 2 of these, the original and this one. Whoever the brain trust was that came up with this cockamamy idea was a numbskull. The rechargeable batteries dont last forever, why make a product. you must basically throw away because of the imbecile design? Sheesh.
This is the correct battery for my K800
I was able to remove my battery and keep my K800 operating with USB power. I can wait for a battery from AliExpress.
Part No.---Logitech 802085P
https://www.aliexpress.com/item/10050047...
How well does the Aliexpress battery work. I have been hesitant to purchase from them. thanks, John V.
The correct battery is available from the same location
What keyboard would have a similar feel to the K800? `
I wander if it's possible to replace some parts from old K800, the one powered by 2 AA batteries, and make a new one to run on AA batteries?
Any advice on how to deal with it? I have both old one, which is fatigued, but working, and a new one.
I've always chosen Logitech for quality and durability of their products. Here this company have clearly made a move to products that can't be repaired even for the most common cause of issue: change the battery. Wrong choice, really, completely in the reverse of where the world need to go.
As software engineer, I have always recommended Logitech products for my family, for office. Well, I'm done with Logitech.
This company is malfunctioning and now needs to be stopped.
Here is the correct link to the battery https://www.canadianbatteries.com/produc...
I didn't know there were two versions of this keyboard. Mine wasn't taking a charge and I found this website. I hopped over to Amazon, found the kit and battery, bought it. It was delivered this morning and I was all prepared to do an archaeological dig on this keyboard. I take the battery cover off and bam! 2 rechargeable batteries right there. Guess I could've done more research and read you guys' comments. 😅
