Logitech G502 Lightspeed Battery Replacement
crwdns2942287:0crwdne2942287:0Use this guide to replace a worn-out or dead battery in your Logitech G502 Lightspeed.
If you plan to reuse the mouse feet, you’ll need to apply heat to loosen the adhesive and remove the feet with minimal bending. Bent or torn mouse feet may require replacement.
If the battery is swollen, take appropriate precautions. For your safety, discharge your battery below 25% before disassembling your device. This reduces the risk of a dangerous thermal event if the battery is accidentally damaged during the repair.
You might need replacement adhesive to reattach the new battery. Check the guide and your replacement battery in advance.
crwdns2942269:0crwdne2942269:0
crwdns2942337:0crwdne2942337:0
crwdns2944105:0crwdne2944105:0
Before you begin, flip the power switch into the OFF position.
Heat an iOpener and apply it to the mouse feet for one minute.
Insert the tip of an opening pick underneath the front foot at the gap in its recess.
When possible, grab with your fingers and slowly pull to peel it off completely.
Insert the tip of an opening pick underneath the tiny front right foot at the gap in its recess.
Insert the tip of an opening pick underneath the rear foot starting at the gap in its recess.
Use a spudger to carefully scrape up and remove any remaining adhesive bits.
Use isopropyl alcohol and a microfiber cloth to thoroughly clean all adhesive residue from the foot recesses. Allow the surface to completely dry.
Remove the feet from their backing and firmly press them into place.
Use your fingers to remove the weight hatch by pulling the bottom part of the thumb rest straight down.
Remove the four 5.4 mm long Phillips screws at the underside of the mouse.
Note: The beginning of this guide says to use Phillips #00 but my iFixit #000 fits correctly.
Insert an opening pick between the bottom plate and the upper shell starting at the rear of the mouse.
Slide the opening pick along the gap between the two halves towards the outer flank of the mouse.
Twist the opening pick to disengage the clips holding both halves together.
Again insert the tip of an opening pick between the bottom plate and the top shell starting at the rear.
Slide the pick along the gap between the two halves towards the thumb rest.
Twist the opening pick to unhinge the remaining clips.
Flip the mouse over on its (removed) feet and hinge the top shell open towards the right side.
Hold the battery cable close to the connector and carefully "walk it out" by pulling parallel to the motherboard rocking the connector side to side.
You can also use a pair of angled tweezers to grip the connector head and pull it straight out of its socket.
Using a hard sewing needle and pushing the connector out by inserting the tip in the two rectangular holes, alternating. Mine has really soft cables and wouldn't come out by "waking it out". I was afraid to not rip the cables out.
Use a spudger or your fingernail to flip up the small, hinged locking flap of both ZIF connectors to disconnect and free the interconnect cables.
This is great to open the case.. be careful if you want to disassemble further.. there are at least 20 more screws if you want to completely tear these down
Insert the tip of an opening pick between the battery and its plastic tub.
Use an opening pick to pry the battery up slightly to loosen the adhesive underneath.
Push the opening pick all the way under the battery.
Slowly pull the opening pick towards the rear of the mouse to slide the battery out from under the plastic tab and out of its tub.
If possible, turn on your device and test your repair before installing new adhesive and resealing.
Secure the new battery with pre-cut adhesive or double-sided adhesive tape if the battery comes without one. Press the new battery firmly into place.
To reassemble your device, follow these instructions in reverse order. Apply new adhesive where necessary after cleaning the relevant areas with isopropyl alcohol (>90%).
For optimal performance, calibrate your newly installed battery: Charge it to 100% and keep charging it for at least 2 more hours. Then use your device until it shuts off due to low battery. Finally, charge it uninterrupted to 100%.
crwdns2935229:025crwdne2935229:0
crwdns2947821:0crwdne2947821:0
crwdns2947823:0crwdne2947823:0crwdns2947412:08crwdne2947412:0
What type of battery is needed as replacement?
The battery model is "AHB521630"
Very good tutorial !
If you are searching a new battery, Aliexpress is your friend :)
Thank u for the Instruction, has take less than 10 Min
A really easy and useful fix. In my experience, step 12 was unnecessary. It is easy to lay both sides down and remove the battery while they are still connected.
With how clumsy some people are, i imagine they could damage the ribbon cables, hence the precautionary step
Thanks for the tutorial really handy!
After 3 years the battery in my G502 wasn't holding charge for long anymore and discovering a new one of this mouse still costs over £100 made me want to cry until I saw this guide. Our good friends in China only want a fiver for a replacement battery (AliExpress FTW!). Hardest part for me was removing the plug from the old battery (Step 11), no amount of rocking the connector from side to side made it want to budge, so I used a small falt-head screwdriver to gently lever the plug at each side until it finally started to come out. Even with this, it took only 10 mins to replace the battery and I didn't need to replace any other parts, just cleaned everything with an alcohol wipe before reassembly. Also agree with the comment that Step 12 isn't necessary, getting access to the battery without removing those other connectors is no problem. Great guide thank you much, mouse is like new again.
