LG Front Load Washing Machine Stator Replacement
  1. LG Front Load Washing Machine Stator Replacement, Safety Precautions: crwdns2935265:01crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 LG Front Load Washing Machine Stator Replacement, Safety Precautions: crwdns2935265:01crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Before you begin your repair, perform the following:
    • Turn off the main water supply
    • Unplug your washer
    • Disconnect all water connections at the rear of your washer
    DO NOT USE THESE Instructions 🤦‍♂️. It will take you for ever. Go from the back, lie down on the ground take it I’ll put the new one in done. Or do it with someone you leave it a tad side ways and even easier
    Mechanicbob - crwdns2934203:0crwdne2934203:0
  2. LG Front Load Washing Machine Stator Replacement, Unfasten the rear panel: crwdns2935265:02crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 LG Front Load Washing Machine Stator Replacement, Unfasten the rear panel: crwdns2935265:02crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 LG Front Load Washing Machine Stator Replacement, Unfasten the rear panel: crwdns2935265:02crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Remove the screw(s) securing the rear panel.
    I undertook this repair with the wd14071sd6 model. Unlike this picture the entire back panel has to be removed to access the rotor. This is very very awkward, as multiple electrics are also connected to the panel via plastic clips.
    Phill Birtles - crwdns2934203:0crwdne2934203:0
    Thank you for the additional information. This is especially helpful when manufacturers market different models in different areas worldwide. You would hope that a sensible design for the access, like what is shown in the guide, would be universal, but that's not always the case.
    Bill Gilbert -
  3. LG Front Load Washing Machine Stator Replacement, Remove the rear panel: crwdns2935265:03crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 LG Front Load Washing Machine Stator Replacement, Remove the rear panel: crwdns2935265:03crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 LG Front Load Washing Machine Stator Replacement, Remove the rear panel: crwdns2935265:03crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Unclip the rear panel from the chassis.
  4. LG Front Load Washing Machine Stator Replacement: crwdns2935265:04crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the rear panel.
  5. LG Front Load Washing Machine Stator Replacement, Unfasten the rotor: crwdns2935265:05crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 LG Front Load Washing Machine Stator Replacement, Unfasten the rotor: crwdns2935265:05crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Use an impact driver to remove the 17 mm nut securing the rotor.
    • Alternatively, you can use a wrench and a hammer to loosen the nut.
    • To secure the rotor, you can insert a screwdriver, or a similar tool, between the rotor and the stator. Make sure to brace the tool against one of the screw bosses on the stator.
  6. LG Front Load Washing Machine Stator Replacement, Remove the rotor: crwdns2935265:06crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 LG Front Load Washing Machine Stator Replacement, Remove the rotor: crwdns2935265:06crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • The rotor is magnetically attracted to the stator.
    • Pull the rotor straight off the stator and drive shaft splines to remove it.
    • Wiggle the rotor as you pull to help disconnect it.
    • This may require significant force.
    • During reassembly, watch your fingers when aligning the rotor over the stator, as the rotor gets sucked in easily.
    The wd14071sd6 model includes a white plastic guard at the top of the rotor that appears to be a failsafe to keep the rotor inplace. Remove the two phillips head screws and this guard BEFORE you attempt to pull the rotor off.
    Thank you for your contribution! Having information about machines that are similar but found in a different part of the world is a plus!
    Bill Gilbert -
  7. LG Front Load Washing Machine Stator Replacement, Unfasten the motor harness: crwdns2935265:07crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the screw(s) securing the motor harness.
  8. LG Front Load Washing Machine Stator Replacement, Unfasten the stator: crwdns2935265:08crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 LG Front Load Washing Machine Stator Replacement, Unfasten the stator: crwdns2935265:08crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Hold the stator up as you unfasten the last few bolts, as it can fall over unexpectedly.
    • Remove the bolts securing the stator.
    • During reassembly, refasten the screws in a "star" pattern.
  9. LG Front Load Washing Machine Stator Replacement, Reposition the stator: crwdns2935265:09crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 LG Front Load Washing Machine Stator Replacement, Reposition the stator: crwdns2935265:09crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 LG Front Load Washing Machine Stator Replacement, Reposition the stator: crwdns2935265:09crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Don't pull the stator too far away from the device, as it's still connected by wires.
    • Pull the stator out of its slot on the drum, and flip it so its rear is facing upward.
  10. LG Front Load Washing Machine Stator Replacement, Disconnect the stator: crwdns2935265:010crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 LG Front Load Washing Machine Stator Replacement, Disconnect the stator: crwdns2935265:010crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 LG Front Load Washing Machine Stator Replacement, Disconnect the stator: crwdns2935265:010crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Disconnect the connectors attached to the stator.
    • Always grip cables by their connectors and not the wires themselves.
  11. LG Front Load Washing Machine Stator Replacement, Remove the rotor position sensor: crwdns2935265:011crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 LG Front Load Washing Machine Stator Replacement, Remove the rotor position sensor: crwdns2935265:011crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 LG Front Load Washing Machine Stator Replacement, Remove the rotor position sensor: crwdns2935265:011crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Use your fingers to unclip the rotor position sensor from the stator.
    • Pull the sensor away from the stator to completely unclip it.
    • Remove the rotor position sensor.
    • You're left with the stator.
Repair didn’t go as planned? Ask our Answers community for help.
Bill Gilbert
crwdns2935283:006/30/22crwdne2935283:0
37.712 crwdns2915208:0crwdne2915208:0
crwdns2935297:0261crwdne2935297:0
Staff
crwdns2931471:0120crwdne2931471:0
crwdns2935297:021.113crwdne2935297:0
I don’t have comment just question. Does this particular model have a drive belt? Mine is not spinning properly
Leilani Seymour - crwdns2934203:0crwdne2934203:0
No it does not. It is a direct drive machine, meaning that the motor drives the wash basket directly. Take a look at this link for some help.
Bill Gilbert -
I undertook this repair with the wd14071sd6 model to replace the hall sensor as I was getting the LE error code. I have noted on step 2 that the entire back panel had to be removed to access the rotor. This is very very awkward, as multiple electrics are also connected to the panel via plastic clips.
Despite this, the repair can be achieved without any major electric disconnection work just a matter or having enough space to carefully remove things.
crwdns2936753:030crwdne2936753:0 43
crwdns2942667:0crwdne2942667:0 1,466
