crwdns2937539:0crwdnd2937539:0crwdne2937539:0
Kindle 7th Generation LCD Circuit Board Replacement
  1. Kindle 7th Generation LCD Circuit Board Replacement, Front Panel: crwdns2935265:01crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Kindle 7th Generation LCD Circuit Board Replacement, Front Panel: crwdns2935265:01crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Power off your Kindle before beginning disassembly.
    • At each corner, use the blue plastic opening tool to unhook and separate the front panel from the adhesive.
    • Run the tool along the seams to pry open the front panel.
    i had a battery that wouldn't even last a full day in the end. by accident i let the battery fall below 10% charge and when turned on it only showed the battery icon. I fully charged it and now i am having no problems with it. what i think happened is it reset the batteries memory and that was the problem. worth trying anyway before buying a new battery.
    soupamanx - crwdns2934203:0crwdne2934203:0
    I have no idea if my kindle is off. Holding in the button for a minute does nothing.
    Manfred Knorr - crwdns2934203:0crwdne2934203:0
  2. Kindle 7th Generation LCD Circuit Board Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Peel the front panel off to remove it from the Kindle.
    • If this is the first time the front panel has been removed, the adhesive may require a significant amount of force to undo.
    • To prevent damaging the front panel, peel the panel from the corners towards the middle of the Kindle.
    • When reassembling your device, if you are replacing the front panel, additional adhesive may be required.
    What is the adhesive you are using resecure the screen? Would Tesa 61395 Tape work (4mm) or would this create protrusion?
    Camble Scott - crwdns2934203:0crwdne2934203:0
    Did that option work for you? I'm about to try and change my battery and don't have any idea on what backup adhesive to have
    Lagroth -
  3. Kindle 7th Generation LCD Circuit Board Replacement, Back Panel: crwdns2935265:03crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Kindle 7th Generation LCD Circuit Board Replacement, Back Panel: crwdns2935265:03crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Remove the ten 5.0 mm T5 Torx screws.
    • A magnetized screw mat can help you keep track of your screws.
    You will break the newer vision of kindle just like this. there is a peg that connect the top center of the screen to the back case. Remove the black double sided tape in the center and push this peg back .
    Kyle Darnell - crwdns2934203:0crwdne2934203:0
    If you see black double sided tape at the top of your Kindle, as the commenter above did, you are on the wrong model—have a look here to see if this is your model: Kindle Paperwhite 3rd Generation Screen/Display Touch Panel Replacement
    Lipsmeyer - crwdns2934203:0crwdne2934203:0
    My device has a mix of silver 5 mm and black 4 mm screws. The 4 mm screws are the one in the middle of the left side and the 3 on the right side.
    Foxrok - crwdns2934203:0crwdne2934203:0
  4. Kindle 7th Generation LCD Circuit Board Replacement: crwdns2935265:04crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Working evenly along the corners and edges, separate the internal contents from the back panel.
    • There are many clips securing the screen to the back panel. Force will be required to remove the back, but you should never feel that the Kindle may break.
    後の手順5の画像で確認できる、バッテリーの周り4か所が主なクリップ箇所です。
    hi.kinta - crwdns2934203:0crwdne2934203:0
    補足:バックパネル交換ガイドを読んでいる場合は手順5以降がないので、上記の画像を確認したい場合はマザーボード交換ガイドの手順5などを参照して下さい。
    Servause -
  5. Kindle 7th Generation LCD Circuit Board Replacement, Motherboard: crwdns2935265:05crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Kindle 7th Generation LCD Circuit Board Replacement, Motherboard: crwdns2935265:05crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Flip the screen over to face the motherboard and battery pack.
    • Use the blunted precision tweezers to gently unclip and detach the cable connecting the battery pack and motherboard.
  6. Kindle 7th Generation LCD Circuit Board Replacement: crwdns2935265:06crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Kindle 7th Generation LCD Circuit Board Replacement: crwdns2935265:06crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Kindle 7th Generation LCD Circuit Board Replacement: crwdns2935265:06crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Use the tip of the spudger to flip up the small retaining flap on the copper colored zero insertion force (ZIF) connector.
    • Make sure to flip up the flap and not the connection itself.
    • Pull the cable from the connector.
    • No force is required to do this, as the name, ZIF, implies.
  7. Kindle 7th Generation LCD Circuit Board Replacement: crwdns2935265:07crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Kindle 7th Generation LCD Circuit Board Replacement: crwdns2935265:07crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Similar to the previous step, flip up the retaining flap on the white cable connector.
    • Pull the white cable from the connection.
    • During reassembly, make sure the retaining flaps for both the white and copper colored cable connections are secured. As these are zero insertion force connections, the cables could potentially slide out if this is not done.
  8. Kindle 7th Generation LCD Circuit Board Replacement: crwdns2935265:08crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Kindle 7th Generation LCD Circuit Board Replacement: crwdns2935265:08crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Disconnect the touch digitiser bridge cable by using your Spudger to lift up the white tabs on both connectors.
    • Use tweezers to pull out the cable.
    • The touch digitiser bridge cable is the one connecting between these two connectors.
  9. Kindle 7th Generation LCD Circuit Board Replacement: crwdns2935265:09crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Kindle 7th Generation LCD Circuit Board Replacement: crwdns2935265:09crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Use the T5 Torx screwdriver to remove the eight 3.0 mm Phillips Head screws.
    • Some screws have washers associated with them. It is important to keep track of the washers and remember which thread they came from.
  10. Kindle 7th Generation LCD Circuit Board Replacement: crwdns2935265:010crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the motherboard.
  11. Kindle 7th Generation LCD Circuit Board Replacement, LCD Circuit Board: crwdns2935265:011crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Kindle 7th Generation LCD Circuit Board Replacement, LCD Circuit Board: crwdns2935265:011crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Remove the two 2.5 mm Phillips Head screws using the T5 Torx screwdriver.
  12. Kindle 7th Generation LCD Circuit Board Replacement: crwdns2935265:012crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Run the plastic opening tool around the edge to separate the bezel from the adhesive.
  13. Kindle 7th Generation LCD Circuit Board Replacement: crwdns2935265:013crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Lift the bezel from the screen.
    • Use care, the bezel and circuit board are flimsy and the adhesive is strong.
  14. Kindle 7th Generation LCD Circuit Board Replacement: crwdns2935265:014crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Flip the bezel over to view the circuit board.
    • Use the T5 Torx screwdriver to undo the six 2.0 mm screws holding the circuit board to the bezel.
    • Remove the LCD circuit board.
Julien
crwdns2935283:002/03/15crwdne2935283:0
143 crwdns2915208:0crwdne2915208:0
Cal Poly, Team 6-28, Amido Winter 2015 crwdns2935289:0Cal Poly, Team 6-28, Amido Winter 2015crwdne2935289:0
CPSU-AMIDO-W15S6G28
crwdns2935297:022crwdne2935297:0
Where do you buy the replacement parts?
Freedom Rose - crwdns2934203:0crwdne2934203:0
crwdns2936753:07crwdne2936753:0 23
crwdns2936753:030crwdne2936753:0 49
crwdns2942667:0crwdne2942667:0 4,946
