JBL Xtreme 2 Battery Replacement
  1. JBL Xtreme 2 Battery Replacement, Pry up the fabric cover: crwdns2935265:01crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 JBL Xtreme 2 Battery Replacement, Pry up the fabric cover: crwdns2935265:01crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 JBL Xtreme 2 Battery Replacement, Pry up the fabric cover: crwdns2935265:01crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Before starting repairs, turn off your device and unplug any cables.
    • The fabric cover of the JBL Xtreme 2 is secured by plastic clips and screws. To avoid damaging the cover, begin prying on the edge closest to the ports.
    • Insert the flat end of a metal spudger into the seam between the two halves of the fabric cover.
    • Push the spudger underneath the edge of the fabric cover and pry upwards to release its plastic clips.
  2. JBL Xtreme 2 Battery Replacement, Release the plastic clips: crwdns2935265:02crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 JBL Xtreme 2 Battery Replacement, Release the plastic clips: crwdns2935265:02crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 JBL Xtreme 2 Battery Replacement, Release the plastic clips: crwdns2935265:02crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Insert the flat end of a metal spudger underneath the edge of the fabric cover's center section.
  3. JBL Xtreme 2 Battery Replacement, Pry up the second short edge: crwdns2935265:03crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 JBL Xtreme 2 Battery Replacement, Pry up the second short edge: crwdns2935265:03crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Insert the flat end of a metal spudger underneath the second short edge of the fabric cover.
  4. JBL Xtreme 2 Battery Replacement, Unfasten the fabric cover: crwdns2935265:04crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 JBL Xtreme 2 Battery Replacement, Unfasten the fabric cover: crwdns2935265:04crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Use a Phillips screwdriver to remove the two 8.6 mm-long screws securing the fabric cover.
    • Don't try to remove the fabric cover all the way yet, as it‘s still held in place by more plastic clips.
  5. JBL Xtreme 2 Battery Replacement, Pry up the short edge of the fabric cover: crwdns2935265:05crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 JBL Xtreme 2 Battery Replacement, Pry up the short edge of the fabric cover: crwdns2935265:05crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Repeat the previous prying procedure, starting with the opposing short edge of the fabric cover.
    • Insert the flat end of a metal spudger and pry upwards to release the plastic clips.
  6. JBL Xtreme 2 Battery Replacement, Pry up the long edge of the fabric cover: crwdns2935265:06crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 JBL Xtreme 2 Battery Replacement, Pry up the long edge of the fabric cover: crwdns2935265:06crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 JBL Xtreme 2 Battery Replacement, Pry up the long edge of the fabric cover: crwdns2935265:06crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Insert the flat end of a metal spudger underneath the long edge of the fabric cover and pry upwards to release the plastic clips.
  7. JBL Xtreme 2 Battery Replacement, Release the remaining plastic clip: crwdns2935265:07crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 JBL Xtreme 2 Battery Replacement, Release the remaining plastic clip: crwdns2935265:07crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Insert the flat end of a metal spudger underneath the short edge of the fabric cover and pry upwards to release the remaining plastic clip.
  8. JBL Xtreme 2 Battery Replacement, Open the fabric cover: crwdns2935265:08crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 JBL Xtreme 2 Battery Replacement, Open the fabric cover: crwdns2935265:08crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • The fabric cover of the JBL Xtreme 2 is equipped with a hinge.
    • Place your speaker on your working surface with the Xtreme 2 branding facing upwards.
    • Open the hinge of the fabric cover by folding it upwards.
  9. JBL Xtreme 2 Battery Replacement, Remove the fabric cover: crwdns2935265:09crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 JBL Xtreme 2 Battery Replacement, Remove the fabric cover: crwdns2935265:09crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 JBL Xtreme 2 Battery Replacement, Remove the fabric cover: crwdns2935265:09crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Lift the speaker assembly up and away from the fabric cover.
    • Remove the fabric cover.
  10. JBL Xtreme 2 Battery Replacement, Unfasten the battery cover: crwdns2935265:010crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 JBL Xtreme 2 Battery Replacement, Unfasten the battery cover: crwdns2935265:010crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Use a Phillips screwdriver to remove the six 8.6 mm-long screws securing the battery cover.
  11. JBL Xtreme 2 Battery Replacement, Remove the battery cover: crwdns2935265:011crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 JBL Xtreme 2 Battery Replacement, Remove the battery cover: crwdns2935265:011crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Remove the battery cover.
    note the orientation of the battery cover, as there are receptacle holes in the battery cover for the small pegs in the fabric cover. If the battery cover gets turned around, it will still be able to be screwed in, but the pegs in the fabric cover will no longer be aligned with the receptacle holes in the battery cover
    Mark Kurschner - crwdns2934203:0crwdne2934203:0
  12. JBL Xtreme 2 Battery Replacement, Pry up the battery: crwdns2935265:012crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 JBL Xtreme 2 Battery Replacement, Pry up the battery: crwdns2935265:012crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Insert a spuder into the gap between the bottom end of the battery and its recess.
    • Pry upwards to lift the battery until you can grip it with your fingers.
  13. JBL Xtreme 2 Battery Replacement, Move the battery: crwdns2935265:013crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 JBL Xtreme 2 Battery Replacement, Move the battery: crwdns2935265:013crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Avoid straining or sharply bending the battery cable during the following step. Move the battery just enough to get access to the battery connector.
    • Lift the battery out of its recess and carefully pull it to the side to get free access to the battery connector.
    • During reassembly, this is a good point to power on your device and test your repair before reinstalling the fabric cover.
  14. JBL Xtreme 2 Battery Replacement, Disconnect the battery: crwdns2935265:014crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 JBL Xtreme 2 Battery Replacement, Disconnect the battery: crwdns2935265:014crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 JBL Xtreme 2 Battery Replacement, Disconnect the battery: crwdns2935265:014crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • The battery is connected to the motherboard with a power cable connector that has a small tab on the side that locks it in place.
    • Insert a spudger into the cut-out in the battery recess where the battery connector is located.
    • Use your spudger to squeeze the tab against the connector to release it.
    • Use your free hand to grab the battery cable just above the connector. Pull the connector straight up from its socket, wiggling it back and forth to loosen the clips securing it.
  15. JBL Xtreme 2 Battery Replacement, Remove the battery: crwdns2935265:015crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the battery.
If possible, power on your device and test your repair before reassembly. For optimal performance, calibrate your newly installed battery after completing this guide.
crwdns2935229:08crwdne2935229:0
Dominik Schnabelrauch
crwdns2935283:011/23/16crwdne2935283:0
235,621 crwdns2915208:0crwdne2915208:0
crwdns2935297:0682crwdne2935297:0
Staff
crwdns2931471:0119crwdne2931471:0
crwdns2935297:021,024crwdne2935297:0
My JBL stop working, it's connected wi/fi on, but no sound
Adam Cleveland - crwdns2934203:0crwdne2934203:0
Mine powers on for 5 seconds and keeps turning off, the reset won't work either
A Zack - crwdns2934203:0crwdne2934203:0
hi i have a problem with my jbl xtreme 2 speaker when i turn on and play music it’s suddenly turn in off and when in turn in off it’s suddenly turn on it’s weird what i supposed to do fix my speaker please help me how to fix my speaker thank you.
Jayvie - crwdns2934203:0crwdne2934203:0
Dimana ada jual case jbl extreme 2, mohon info
TOM - crwdns2934203:0crwdne2934203:0
crwdns2936753:07crwdne2936753:0 59
crwdns2936753:030crwdne2936753:0 325
crwdns2942667:0crwdne2942667:0 6,525
