Huawei P10 Lite Display Assembly with Frame Replacement
  1. Huawei P10 Lite Display Assembly with Frame Replacement, Back cover: crwdns2935265:01crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Huawei P10 Lite Display Assembly with Frame Replacement, Back cover: crwdns2935265:01crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Huawei P10 Lite Display Assembly with Frame Replacement, Back cover: crwdns2935265:01crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Insert the tip of an opening pick between the back cover and the mid frame and slide it around the phone, to cut the adhesive.
    • Using a suction handle to lift the back cover may help to get an initial gap for the opening pick to put in.
    • If the adhesive is hard to cut, use an iOpener to loosen it.
    Mit dem Saugnapf die Rückseite anheben hilft ungemein…
    Matthias Eberle - crwdns2934203:0crwdne2934203:0
    Had to use blue wedge tool to wedge open bottom plate from the rim part in order to then use the tip of the blue opening pick under the back plate to then cut the glue. It’s like placing a pie server or knife under the plate once there’s a gap between the rim and the back plate.
    Jane - crwdns2934203:0crwdne2934203:0
    Be careful, there’s a cable to fingerprint sensor, very close to the edge (see pictures below)… It’s very easy to cut it through with the pick, as I just learned :)
    dambig - crwdns2934203:0crwdne2934203:0
  2. Huawei P10 Lite Display Assembly with Frame Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Huawei P10 Lite Display Assembly with Frame Replacement: crwdns2935265:02crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Huawei P10 Lite Display Assembly with Frame Replacement: crwdns2935265:02crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • After you cut the adhesive on every edge, twist your opening pick, to separate the rear cover from the phone.
    • Flip the rear cover over to the right side of the phone.
  3. Huawei P10 Lite Display Assembly with Frame Replacement: crwdns2935265:03crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Huawei P10 Lite Display Assembly with Frame Replacement: crwdns2935265:03crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Use a pair of tweezers to remove the sticker.
    • Remove the two Phillips #00 screws.
    • Remove the four 2.5 mm Phillips #00 screws.
    Schritt 3 und 4 kann man sich komplett sparen. Wozu auch. Kann gleich mit Schritt 5 weitergemacht werden, zuvor einfach das Flachbandkabel vom Fingerabdrucksensor an der Rückabdeckung abklemmen und fertig.
    Bobby mcgee - crwdns2934203:0crwdne2934203:0
    There are four silver screws and two black to be removed.
    Translate what Bobby mcgee said:
    Step 3 and 4 can be completely ignored. What for? You can continue with step 5, just disconnect the ribbon cable from the fingerprint sensor on the back cover and you're done.
    Antonio Sun - crwdns2934203:0crwdne2934203:0
    However, the reason step 3 and 4 should not be skipped is Step 6 — Use an iOpener to loosen the adhesive beneath the battery. I.e., the adhesive cannot be easily removed without heat, however, that heat might damage the electric chips. Thus they’d better be removed first.
  4. Huawei P10 Lite Display Assembly with Frame Replacement: crwdns2935265:04crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Huawei P10 Lite Display Assembly with Frame Replacement: crwdns2935265:04crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Use tweezers to remove the mainboard shield.
    • Use the flat end of a spudger to disconnect the finger print sensor flex cable.
    • When reassembling apply new adhesive where it is necessary.
    Welchen Klebstoff soll man verwenden?
    josef navratil - crwdns2934203:0crwdne2934203:0
    Hallo Josef,
    sollte bei deinem Ersatzteil kein Klebstoff oder Klebeband dabei gewesen sein, kannst du dünne Streifen Doppelseitiges Klebeband verwenden. Es gibt für das Huawei P10 Lite auch schon zugeschnittene Klebestreifen zu erwerben, hierbei gilt aber je nach Händler Rezessionen zu lesen, ob die Klebestreifen auch wirklich halten.
    Dominik Schnabelrauch -
    Note that there is a copper-colored sticker to lift up near the flat cable connected from the phone the finger pad. Lift the main board plate (shield) up SLOWLY from the camera side to the other end as the plate is wedged in place.
    what adhesive is recommended? thanks
    darren - crwdns2934203:0crwdne2934203:0
    Hi darren,
    pre-cut adhesive would be the best solution if you can source it. Otherwise a two-sided adhesive tape or carefully used E6000 adhesive glue will be your friend.
    Tobias Isakeit -
  5. Huawei P10 Lite Display Assembly with Frame Replacement, Battery Disconnection: crwdns2935265:05crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Huawei P10 Lite Display Assembly with Frame Replacement, Battery Disconnection: crwdns2935265:05crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Huawei P10 Lite Display Assembly with Frame Replacement, Battery Disconnection: crwdns2935265:05crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Remove the Phillips screw holding the battery connector plate in place.
    • Remove the battery connector plate.
    • Use the flat end of a spudger to disconnect the battery flex cable.
    Very gently lift the silver connecter that was under the battery connecter plate and is at the end of the orange battery cable with the flat end of the spudger as indicated.
  6. Huawei P10 Lite Display Assembly with Frame Replacement, Battery: crwdns2935265:06crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Huawei P10 Lite Display Assembly with Frame Replacement, Battery: crwdns2935265:06crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Use an iOpener to loosen the adhesive beneath the battery.
    • Insert a spudger between the battery and the mid frame to create a gap.
    • Be careful not to puncture or crease the battery.
    • Insert an opening pick or use the spuder in the gap to cut the adhesive beneath the battery.
    • There are flex cables running under the battery. Don't damage them with your tools.
    Ohne eine Erwärmung des Klebers ist die Entfernung des Akkus wirklich sehr hakelig und zeitintensiv!
    Marcel Tischer - crwdns2934203:0crwdne2934203:0
    You must heat the battery two or more times with the iOpener in order to remove it because if you don’t (and even if you do) the battery will certainly bend. So the battery removal has to be done delicately. Lift each corner a very tad bit and the sides to finally lift out as shown.
    This step takes at least 15-20 minutes.
    Battery easily torn. The kit should include a battery as it’s VERY delicate and would be saved if you have the replacement battery.
    Ich habe es mit Zahnseide recht gut hinbekommen! Habe die Seide oben angelegt um gut unter den Akku zu kommen und habe mit Wärme und hin- und herbewegen der Seide den Akku ohne verbiegen gelöst bekommen. Hat auch ein paar Minuten gedauert, aber hat sich gelohnt!
    Sash - crwdns2934203:0crwdne2934203:0
    Is it possible to soften the adhesive using isopropyl alcohol?
    Michele Matteoni - crwdns2934203:0crwdne2934203:0
    Hi Michele,
    yes, the use of isopropyl alcohol is a common technique when removing a battery in a smartphone. Especially when the adhesive is very strong. Try to apply the alcohol to every corner of the battery and let it penetrate the adhesive for several minutes. Start the prying procedure with the spudger afterwards. In case the adhesive isn’t loose enough you can reapply isopropyl alcohol any time during the removal. Keep in mind, that there’s a gap in the midframe for the display flex cable. It can happen that the isopropyl alcohol runs trough that gap and loosens the adhesive of the display as well. When the display adhesive gets loose you’ll need replacement adhesive for the display. To avoid that, apply as less alcohol as possible at a time and take especially care during prying to avoid damage to the flex cables underneath the battery. The adhesive of the cables will get loose as well.
    The battery was very hard to remove. Please note: it is glued everywhere around the ribbon cables at the bottom. The battery is not glued with little strips like the back cover. The spudger and the blue cutting triangles were not very strong and the plastic tip bent upon removal of the battery. I eventually got the battery out with a metallic spatula. Be careful not to rip the shining lining of the battery while cutting the adhesive. I don’t know how people get the battery out without bending it, also every YT video I watched had - slightly - bent batteries. The glue is so strong snd sticky I did not need to apply new adhesive strips.
    anya__savina - crwdns2934203:0crwdne2934203:0
    If you are operating on aged ones:
    The Old double sided tape doesn’t really much care about the heat from the iOpener.
    Use a metal spudger (round edges) instead but use it with care. Slowly and evenly lift the battery and go around it in a circle. Stay close to the edges to not damage cables under the battery (seen in step 7). Start pushing closer towards the middle only when you can see the cables yet and are sure not to damage them.
    If this still doesn’t bring you closer to lifting the battery safely:
    Two Options:
    1. Try to use some small drops of adhesive remover . Best to use not to much is use Q-Tips or Cotton Swabs to evenly apply the remover through a little crack under the battery.
    2. Use unwaxed dental floss push it under the battery. Then gently move it upwards with a pulling-side-to-side motion. To accelerate the process you can also use ***adhesive remover***. The dental floss will soak it up (only works with unwaxed dental floss) and assure that it will only be where it’s needed.
    Doron Karaman - crwdns2934203:0crwdne2934203:0
  7. Huawei P10 Lite Display Assembly with Frame Replacement: crwdns2935265:07crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Huawei P10 Lite Display Assembly with Frame Replacement: crwdns2935265:07crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    Tesa 61395 Tape
    $5.99
    • Use a spudger to cut the rest of the adhesive and lever the battery out of the phone.
    • Remove the battery.
    • When reassembling your phone replace old adhesive with double-sided tape or pre-cut adhesive strips.
    • Never reinstall a battery that has been bent or damaged during removal.
    Merci pour ce tuto absolument parfait.
    IKO - crwdns2934203:0crwdne2934203:0
  8. Huawei P10 Lite Display Assembly with Frame Replacement, SIM Card Tray: crwdns2935265:08crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Huawei P10 Lite Display Assembly with Frame Replacement, SIM Card Tray: crwdns2935265:08crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Use a SIM card removal bit or tool and push it into the small hole in the SIM card tray.
    • Remove the SIM card tray.
  9. Huawei P10 Lite Display Assembly with Frame Replacement, Display Assembly with Frame: crwdns2935265:09crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Huawei P10 Lite Display Assembly with Frame Replacement, Display Assembly with Frame: crwdns2935265:09crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Remove the two Phillips screws.
    • Remove the display flex cable bracket with tweezers.
  10. Huawei P10 Lite Display Assembly with Frame Replacement: crwdns2935265:010crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Huawei P10 Lite Display Assembly with Frame Replacement: crwdns2935265:010crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Use a spudger to disconnect the headphone jack flex cable.
    • Altough the headphone jack is not glued to the mid frame it is a little bit tucked in its bracket. Be careful not to damage it during the removal.
    • Remove the headphone jack.
    Wiggle the black rubber cover off a little in order to see how to lift out.
  11. Huawei P10 Lite Display Assembly with Frame Replacement: crwdns2935265:011crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Huawei P10 Lite Display Assembly with Frame Replacement: crwdns2935265:011crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Use a spudger to disconnect the rear camera flex cable.
    • Remove the rear camera.
  12. Huawei P10 Lite Display Assembly with Frame Replacement: crwdns2935265:012crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Huawei P10 Lite Display Assembly with Frame Replacement: crwdns2935265:012crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Huawei P10 Lite Display Assembly with Frame Replacement: crwdns2935265:012crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Use a spudger to disconnect the volume and power button, the display and the main flex cable.
  13. Huawei P10 Lite Display Assembly with Frame Replacement: crwdns2935265:013crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Huawei P10 Lite Display Assembly with Frame Replacement: crwdns2935265:013crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Huawei P10 Lite Display Assembly with Frame Replacement: crwdns2935265:013crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Unplug the antenna cable with tweezers.
    • The solder joints of some antenna cables might be weak so be careful not to break it out of the motherboard.
    • Use an opening pick to pry out the motherboard until you can get a good grip.
    • The front camera is still attached to the motherboard. Don't damage it during the motherboard removal.
    • Remove the motherboard.
    • On the back of the motherboard there are thermal pads (pink rubber-like gobs) for heat dissipation. If these thermal pads broke or are too dried out you might need to apply new thermal pads on the new display assembly or the motherboard.
    The instructions did not say to remove the sim tray or the screw holding the motherboard down that is in the bottomcenter of the mother board. Unless these are removed first, the motherboard cannot be removed.
    ronald - crwdns2934203:0crwdne2934203:0
    Thanks ronald for your input. The missing steps and actions have been added and edited.
    Tobias Isakeit -
  14. Huawei P10 Lite Display Assembly with Frame Replacement: crwdns2935265:014crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Huawei P10 Lite Display Assembly with Frame Replacement: crwdns2935265:014crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Remove the earpiece speaker with tweezers.
    • Use tweezers to remove the plastic cover of the volume and power button flex cable.
  15. Huawei P10 Lite Display Assembly with Frame Replacement: crwdns2935265:015crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Huawei P10 Lite Display Assembly with Frame Replacement: crwdns2935265:015crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Use an opening pick to cut the adhesive between the volume and power button flex cable and the mid frame.
    • The volume and power button flex cable is a little bit sticky and hard to remove. It can rip easily during the removal. You can use an iOpener to loosen the adhesive a little bit.
    • Carefully remove the volume and power button flex cable with tweezers.
  16. Huawei P10 Lite Display Assembly with Frame Replacement: crwdns2935265:016crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the eight Phillips #00 screws securing the loudspeaker.
    The seventh black screw nearest the silver screw has smaller crosshairs then the others so the screwdriver bit furnished is slightly too large and will damage the screw if you insist. Better to find a smaller one from an eyeglasses repair kit.
    Die achte, silberne Schraube unten rechts muss nicht gelöst werden, um die Lautsprechereinheit herauszunehmen!
    TeeLittle - crwdns2934203:0crwdne2934203:0
  17. Huawei P10 Lite Display Assembly with Frame Replacement: crwdns2935265:017crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Huawei P10 Lite Display Assembly with Frame Replacement: crwdns2935265:017crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Insert an opening pick under the loudspeaker unit and lever it up until you can get a good grip.
    • Remove the loudspeaker.
    Pry up in both corners to remove.
  18. Huawei P10 Lite Display Assembly with Frame Replacement: crwdns2935265:018crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Huawei P10 Lite Display Assembly with Frame Replacement: crwdns2935265:018crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Huawei P10 Lite Display Assembly with Frame Replacement: crwdns2935265:018crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    Tesa 61395 Tape
    $5.99
    • Use the flat end of a spudger to disconnect the interconnect cable and remove it.
    • Use tweezers to disconnect the antenna cable and remove it.
    • Remove the charging board with tweezers.
    • If you're having trouble whilst removing the charging board you can use an iOpener to loosen the adhesive beneath it.
    • Before reassembly check your new part for any components that might need to be transferred from the old one. Also check if new thermal pads (pink rubber-like gobs) need to be applied.
    My connector to the antenna cable had been pulled up and even trying to remove it carefully was to no avail so the connecter broke from the green strip. Might be best to go to next step and slightly lift up the entire assembly if yours is like mine was.
crwdns2935229:012crwdne2935229:0
crwdns2935283:011/23/16crwdne2935283:0
235,693 crwdns2915208:0crwdne2915208:0
crwdns2935297:0682crwdne2935297:0
Staff
crwdns2931471:0119crwdne2931471:0
crwdns2935297:021,044crwdne2935297:0
Hello!
Thanks for the assembly guide! My phones display glass was broken, and I bought new display with frame (since the frame might have been bent), and this guide proved to be helpful. Though, I ought to mention that you did not show how the upper left metal cover for display port was removed (not that I needed it).
However, I think I slightly damaged the main cord between upper and lower motherboards, the orange one, when I was removing the battery. I can still recharge my phone and listen to music through loudspeaker, but I can not hear or be heard when I am having a phone call with someone. I can use hands-free with a microphone to get around the problem, but I wanted to ask that is it possible for the damaged cord to cause this problem, or could it be something else? I would imagine that I should at least hear the other person even if the cord is slightly damaged.
- Jesse
Jesse Hettula - crwdns2934203:0crwdne2934203:0
Hello Jesse
It could be, that cable sends data from the top to the bottom. The micro of the calls is the lower one, so the information could not reach the top if that part is damaged. Look at step 17, in that small plate is the microphone, it could be covered by dirt or not embedded in its hole. But the headset does not depend on that cable, could it have misplaced the headset? Look at step 13, if it is reversed, it will not work.
Oscar -
Hello all!
As we continue getting more and more boards with the same problem, I’d like to point out that you should be very careful when disconnecting the antenna cable. The soldering quality is probably not the best, and this may lead to the antenna cable coming out of the board along with the connector to which it is connected.. This is not so critical, but you will have to do some jewelry work to solder the detached connector.
iliazt - crwdns2934203:0crwdne2934203:0
Thank you for the good guide which helped us to save my son’s phone!
P.S.: I recommend buying the spare parts here - I had ordered the first display on ebay (this was before my brother recommended ifixit to me) and it was broken. The parts from ifixit came in perfect quality.
Stefan Krokowski - crwdns2934203:0crwdne2934203:0
crwdns2936753:030crwdne2936753:0 39
crwdns2942667:0crwdne2942667:0 13,804
