How to Test Speakers and Wires
crwdns2942287:0crwdne2942287:0This guide uses a 9 volt battery and a digital multimeter to test the functionality of the speakers and the wires.
Speaker Testing Option 1: Connect a 9 Volt battery to the leads of the speaker, positive lead to positive battery end and negative lead to negative battery end.
Speaker Testing Option 2: This option requires the use of a digital multimeter that has a continuity setting.
This setting is typically found under the resistance setting but may have its own setting as shown in the picture.
To test the continuity of the wires themselves and both ends of a single wire and test the continuity.
Connect each end of the single wire to the positive and negative leads of the multimeter. If there is an unbroken circuit through the speaker there will be a continuous tone output from the multimeter and/or the meter will not read "OL" (open).
Connect both ends of the speaker to the positive and negative leads of the multimeter. If there is an unbroken circuit through the speaker there will be a continuous tone output from the multimeter and/or the meter will not read "OL" (open).
Capacitor Testing: This will require a digital multimeter with a capacitance testing option.
Connect the positive lead of the multimeter to the positive lead of the capacitor, and vice versa for the negative. If the capacitor is functioning the multimeter will give a reading that is similar to the ratings given on the capacitor casing.
crwdns2935229:017crwdne2935229:0
Would you carry out the same procedure for Beat Solo headphones? The right side works ok, there is no sound from the left side. There is continuity throughout the left circuit.
Would this be the same procedure for Beat Solo headphones? There is no sound from the left earpiece but sound from the right side. There is continuity throughout the left side circuit. The connecting cable is also fully serviceable.
what if your speaker is from the late 1920s and has 4 wires?
Thank you, found the problem with my subwoofer and managed to fix it with this info.
C'è un errore all inizio del servizio i poli sono tutti positivi ????????!!!!!!
C'è un errore nel test condensatore ....
I poli sono tutti positivi??????!!!!!!
Veel beter om dit met een 1.5V batterij te doen ipv 9V.
Eric - crwdns2934203:0crwdne2934203:0
