How to Perform a Battery Cycle Reset
  1. How to Perform a Battery Cycle Reset, Download the app: crwdns2935265:01crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 How to Perform a Battery Cycle Reset, Download the app: crwdns2935265:01crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 How to Perform a Battery Cycle Reset, Download the app: crwdns2935265:01crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Download the Self Repair Assistant app (2.0.12)here.
    • You may be prompted with a "File might be harmful" warning. If so, select "Download anyway."
    • Open the "My Files" app.
    • Navigate to the "Installation files" tab on the left side of the screen.
    The Self Repair Assistant is now working on one ui 6.1
    Jayson Chua - crwdns2934203:0crwdne2934203:0
    Make sure to set your phone date to year 2022 before using this app version. If you don't, it will not work and ask you to download the latest version.
    Do not use the latest version of this app as it will ask for Samsung-made battery serial number (really Samsung. copying Apple for this is anti-consumer).
    Peter Chang - crwdns2934203:0crwdne2934203:0
  2. How to Perform a Battery Cycle Reset, Install the app: crwdns2935265:02crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 How to Perform a Battery Cycle Reset, Install the app: crwdns2935265:02crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Select the app on the right side of the screen.
    • If the app doesn't show up on this panel, skip to the next step.
    • Select "Install" to confirm the app's installation.
    • Skip the next two steps.
  3. How to Perform a Battery Cycle Reset, Rename the app: crwdns2935265:03crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 How to Perform a Battery Cycle Reset, Rename the app: crwdns2935265:03crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 How to Perform a Battery Cycle Reset, Rename the app: crwdns2935265:03crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • If your app didn't show up on the "Installation files" tab, follow the next two steps to rename the file.
    • Navigate to the "Downloads" tab on the left side of the screen.
    • Long press the download file until an orange checkmark appears to the left of it.
    • Navigate to the bottom of the screen and select the "More" option.
  4. How to Perform a Battery Cycle Reset: crwdns2935265:04crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 How to Perform a Battery Cycle Reset: crwdns2935265:04crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 How to Perform a Battery Cycle Reset: crwdns2935265:04crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Select the "Rename" option.
    • Delete the .jar at the end of the app's name.
    • Your file should now appear in the "Installation files" tab.
    Su s20 con one ui 5.1 viene fuori il messaggio di aggiornare l app
    _matti_ - crwdns2934203:0crwdne2934203:0
  5. How to Perform a Battery Cycle Reset, Open the Galaxy Cal app: crwdns2935265:05crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 How to Perform a Battery Cycle Reset, Open the Galaxy Cal app: crwdns2935265:05crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Select the Galaxy Cal app.
    Bei meinem S20 FE 5G kommt beim Starten der App die Meldung:
    This Model is NOT Supported
    Gibt es sonst noch eine Möglichkeit?
    DasMarki _ - crwdns2934203:0crwdne2934203:0
    Says galaxy s20fe is not supported?
    Leroy Henkeman - crwdns2934203:0crwdne2934203:0
    I want FE support as I have an S20 FE 5G.
    Evan Mcgeehan - crwdns2934203:0crwdne2934203:0
    It doesn't work on galaxy s20 with one ui 5.1
    On my S9 it installs but the window of the app closes instantly after opening.
    Rbn Vn Drn - crwdns2934203:0crwdne2934203:0
  6. How to Perform a Battery Cycle Reset, Agree to the terms and conditions: crwdns2935265:06crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Select "Agree" to accept the Terms and Conditions.
  7. How to Perform a Battery Cycle Reset, Select the procedure: crwdns2935265:07crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 How to Perform a Battery Cycle Reset, Select the procedure: crwdns2935265:07crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Select the "Battery" icon.
    • Select "Calibrate" to continue.
    • If you want to perform a fingerprint sensor calibration instead, follow this guide.
  8. How to Perform a Battery Cycle Reset: crwdns2935265:08crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 How to Perform a Battery Cycle Reset: crwdns2935265:08crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 How to Perform a Battery Cycle Reset: crwdns2935265:08crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Select the "Start" button.
    • Select the "Start" button again.
    • Select "Ok" to finalize the battery cycle reset.
    • Wait until the battery cycle reset finishes.
    • You may need to reset your device for battery cycle reset to apply.
crwdns2935229:013crwdne2935229:0
Alex Diaz-Kokaisl
crwdns2935283:001/16/22crwdne2935283:0
164 438 crwdns2915208:0crwdne2915208:0
crwdns2935297:0769crwdne2935297:0
Staff
crwdns2935297:019 716crwdne2935297:0
crwdns2947412:033crwdne2947412:0
Thanks for catching that! I fixed the link in the introduction.
Arthur Shi -
I installed the galaxy cal app on an S20 and when opening the app I get a message to try again after getting new version
Pierre-Luc Thibeault - crwdns2934203:0crwdne2934203:0
I have the same. Do you know how to fix this now?
Melanie Herget -
simply change your phone date between 2021 and 2022.
mightnire -
When opening the app it says model not supported .I'm using a galaxy-s20-fe
Sankt Florian - crwdns2934203:0crwdne2934203:0
me too. cant find in store either
Chad Paul -
Set your phone date between 2021 to 2022
蓝泽希 -
Please update the newest version
kramyeu - crwdns2934203:0crwdne2934203:0
Hello again, when the prompt show there yoy should get new version just simple change the date back in past
Good catch! I changed it to Sept 30 2022 and then the app started.
Oscar de León -
I installed the galaxy cal app on an S20, Android 13 too and when opening the app I get a message to try again after getting new version.
Tried on 3 devices, same result :(
Holger Dahlke - crwdns2934203:0crwdne2934203:0
Resetting the date was the right clue, thx :)
Holger Dahlke -
I have the same question that the application shows it needs updating before opening it. Version is SM-G9860, Oneui5.1
James Zhao - crwdns2934203:0crwdne2934203:0
note20 ultra show : This model is NOT supported! could you add note20 to this tool?
Fixxx - crwdns2934203:0crwdne2934203:0
I hope to see an increase in compatibility for the Note20 series.
Kaiming Zhang (土豆丝) - crwdns2934203:0crwdne2934203:0
Can you please add support for the fe series devices because I have an s20 fe 5g and need to replace my battery.
Would be nice to have, but not possible. As the Prolog says:
Diese Vorgehensweise funktioniert nur auf dem S20, S21, S22 und TabS7+ Modellen. Sie gilt nicht für Fan Edition (FE) Modelle. Diese Anleitung wird aktualisiert, sobald Samsung weitere Modelle hinzufügt.
"... Not suitable for the Fan Edition (FE) Modells. ..."
BenZ78 -
Can you please add s23 series support for in the future as I have an S23 Ultra. Also for those of you who have the "try again after getting new version" error just change your device's date to Oct. 1st 2022 or earlier.
No need to change the phones date just update the app after installing using the galaxy store.
Chris - crwdns2934203:0crwdne2934203:0
Does it work with a S20+ too?
Daniel - crwdns2934203:0crwdne2934203:0
Hallo,
danke für Euren Tipp.
Ich habe diese Version für mein S22 plus heruntergeladen und installiert. Nach dem Start der App, wollte die App aktualisiert werden. Habe ich gemacht und jetzt will die App eine Seriennummer meines Akkus. Version 2.0.10
Kann ich das irgend wie auslesen lassen?
Mfg
dachs1 - crwdns2934203:0crwdne2934203:0
Is there a compatible version for the Samsung S10E?
Elia Capecci - crwdns2934203:0crwdne2934203:0
Did you try the latest version 2.0.12 from the Samsungparts link in step 1 in the unverified but updated version of this guide?
Evan Mcgeehan -
Hi all. Why doesn't the program support Samsung 20FE? Is there a way to reset the charge counter?
Андрей Александров - crwdns2934203:0crwdne2934203:0
Hallo
Leider sagt die app das ei e Verwendung auf dem s21fe nicht möglich ist. Gibt es dafür Lösungsansätze?
benbaschke - crwdns2934203:0crwdne2934203:0
Use the latest version 2.0.12 in the unverified version of this guide. I tested it on devices in Samsung's Remote Test Lab and it should work for your S21FE.
Verwenden Sie die neueste Version 2.0.12 in der nicht verifizierten Version dieses Handbuchs. Ich habe es auf Geräten im Remote Test Lab von Samsung getestet und es sollte für Ihr S21FE funktionieren.
Evan Mcgeehan -
Change phone date to 2021
jackyang0320 -
when i start the calibration, the apps shows that need a serial or qr of the battery, how can i get it?
juandavidflexia - crwdns2934203:0crwdne2934203:0
at the back of the battery there is QR code or at the front I am not so sure which one to use. there is also serial number beside the QR code at the back
Ray Floyd Cabrera -
Hallo, can i use it for my galaxy S21 5G ?
Johann Gottlieb - crwdns2934203:0crwdne2934203:0
Yes I've tested it on that model in Samsung's Remote Test Lab on their developer website and it works.
Evan Mcgeehan -
crwdns2936751:024crwdne2936751:0 92
crwdns2936753:07crwdne2936753:0 755
crwdns2936753:030crwdne2936753:0 3,446
crwdns2942667:0crwdne2942667:0 78,685
