Use this guide to open your Logitech G Pro X Superlight wireless gaming mouse.
Opening your mouse gives you access to clean its internals, troubleshoot mechanical problems, or replace a part.
Slide your mouse's power switch down so it's in the OFF position.
Unplug all cables from your mouse.
Flip the mouse over so the feet are facing up.
Heat an iOpener and lay it on the mouse feet for one minute to heat the adhesive.
Carefully slide the point of a spudger under the circular foot, making sure it goes under both the foot and its adhesive pad.
Gently slide the spudger farther under the foot and lift until you can grab it with your fingers.
Peel up and remove the foot.
If the rubber layer separated from its adhesive pad, use the same process to remove the pad.
Repeat the last three steps to remove the remaining feet.
Use a spudger to carefully scrape up and remove any remaining adhesive bits.
Use isopropyl alcohol and a microfiber cloth to thoroughly clean all adhesive residue from the foot recesses. Allow the surface to completely dry.
Remove the feet from their backing and firmly press them into place.
Use a Phillips screwdriver to remove the six 4.5 mm‑long screws securing the bottom shell.
Gently pull the top and bottom shells apart.
Set your mouse down with the bottom shell on the workspace and the top shell flipped over the right edge.
Use an object such as a small box or stack of books to prop up the top shell so you can access the cables without straining them.
Use the point of a spudger to lift the locking flap on the top shell ZIF connector.
Use tweezers to gently pull the cable straight out of its socket.
Flip the top shell onto the mouse and let it rest so it's partially hanging over the left side, giving you access to the battery connector on the right edge.
Insert each arm of a pair of angled tweezers into the top of the cutouts on the right edge of the battery connector—the tweezers should curve upward.
Gently press the tweezers in and up to push the connector out of its socket enough that you can get a firm grip with your tweezers.
Use tweezers to grip the battery connector and pull it straight up and out of its socket.
Remove the top shell from the bottom shell.
Hey there, thanks for detailed description.
I was a bit hard with the step below and broke the locking flap of the connector( What is the part number for the connector so I can purchase the donor?
