Follow this guide to replace the outer shell of your HTC Vive Pro.
Power off and unplug your headset before you begin your repair.
Rotate the head strap forward as far as it will go.
Unplug the All-In-One Cable from your headset.
Remove the All-In-One Cable from the cable guides along the left side of the head strap.
Separate the top strap from itself where the velcro secures it.
Peel back the Velcro securing the rear of the top strap.
Feed the top strap out through the head strap to remove it.
Feed the top strap through the clip on the headset to fully remove it.
Peel off both front side foam pads to uncover the speaker wires.
Insert the pointed end of your spudger behind the square rubber spacer next to each headphone screw.
Gently pry the rubber spacers out of the head strap.
Use the pointed end of your spudger to pry up and disconnect both the left and right headphone speaker wires.
Use a T6 Torx screwdriver to remove the two 12.1 mm screws (one on each side) securing the head strap to the headset.
Use a T5 Torx screwdriver to remove the following screws securing the head strap to the headset:
Four 3.9 mm screws (two on each side)
Two 4.1 mm screws (one on each side)
Remove the two plastic spacers underneath the previously removed screws from the headset.
Thread the headphone speaker wires out through the ends of the head strap.
Use a T6 Torx screwdriver to remove the four 3.9 mm screws (two on top, two on bottom) securing the outer shell to the headset.
Insert an opening pick into the crease between the two halves of the outer shell.
Slide the opening pick through the crease to dislodge the clips securing it to the headset.
Continue sliding the opening pick through each crease until all clips have been dislodged.
Carefully slide each half of the outer shell off of the sensor array.
Repair didn’t go as planned? Try some basic troubleshooting, or ask our Valve Index Answers community for help.
