This guide provides clear, step-by-step instructions on how to safely remove and replace the battery in the HP iPAQ H3850.The HP iPAQ H3850 uses a rechargeable lithium-ion battery. Over time, the battery may lose its ability to hold a charge, making replacement necessary.
Common signs that your battery needs replacing include:
- Device fails to power on without being connected to a charger
- Rapid battery drain despite minimal use
- Battery does not charge to full capacity
- System warnings indicating battery issues
For more troubleshooting steps, visit the HP iPAQ H3850 Troubleshooting.
Safety
Swollen Batteries: If you notice a swollen or deformed battery, avoid puncturing or mishandling it, as this could pose a safety risk. What to Do With a Swollen Battery
Proper Disposal: Dispose of old batteries according to local electronic waste regulations—never discard batteries in regular household waste.
Place the device on a flat surface with the screen facing down.
Use a screwdriver to remove four screws from the back cover of the device.
Push and release the SD card on edge of the device.
Slide the SD card out.
Insert the end of a spudger between the front and back cover and slide it around the edge to release the clips holding them together.
Pry them two halves but don't pull them apart as it is still connected by a cable.
Place a spudger or opening tool under the connector's edge and pry straight up to disconnect the yellow cable from the motherboard.
Using an iOpener to heat the battery cover and loosen the adhesive holding the battery to the chassis.
Use plastic opening tool to remove battery from the back cover.
Once the old battery is removed, scrape off the old adhesive from the device backing with the prying tool.
To reassemble your device, follow these instructions in reverse order. Take your e-waste to an R2 or e-Stewards certified recycler.
Does anyone know where nowadays is it possible to get one of those batteries? I’ve been all over the internet and so far found zero… ?
HI @alexanderre! I have no idea if you're still looking for this battery or not, but if you are, post this question on the Answers forum. More eyes will see it there.
Hi @amber
Thanks for a hint, will do 🙏
