Google Stadia Controller Thumbstick Replacement
  1. Google Stadia Controller Thumbstick Replacement, Loosen the screw cover adhesive: crwdns2935265:01crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Apply a heated iOpener to the rear side of the Stadia controller where the screw cover is located to loosen the adhesive underneath. Apply the iOpener for at least two minutes.
  2. Google Stadia Controller Thumbstick Replacement, Insert an opening pick: crwdns2935265:02crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Google Stadia Controller Thumbstick Replacement, Insert an opening pick: crwdns2935265:02crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Insert the tip of an opening pick into the gap between the plastic screw cover and the rear case of the controller.
  3. Google Stadia Controller Thumbstick Replacement, Remove the screw cover: crwdns2935265:03crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Google Stadia Controller Thumbstick Replacement, Remove the screw cover: crwdns2935265:03crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Google Stadia Controller Thumbstick Replacement, Remove the screw cover: crwdns2935265:03crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Slide the opening pick along the screw cover to slice the adhesive.
    • Use a pair of tweezers or your fingers to remove the screw cover.
    • You might want to replace the screw cover adhesive during reassembly. Apply a bit of high-concentration isopropyl alcohol (>90%) to a Q-tip or use a cleaning pad to gently remove the leftover adhesive on the rear cover of the controller before installing new adhesive.
  4. Google Stadia Controller Thumbstick Replacement, Unfasten the rear case screw: crwdns2935265:04crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Use a Torx T8 screwdriver to remove the 9.6 mm-long screw securing the rear case.
  5. Google Stadia Controller Thumbstick Replacement, Disassembly information: crwdns2935265:05crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Google Stadia Controller Thumbstick Replacement, Disassembly information: crwdns2935265:05crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • The front cover assembly of the Stadia controller is held in place by various tight plastic clamps. They are very hard to open and snap back in place easily.
    • The opening procedure requires some force, however, try to avoid damaging your controller case along the way.
  6. Google Stadia Controller Thumbstick Replacement, Pry open the stadia controller: crwdns2935265:06crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Google Stadia Controller Thumbstick Replacement, Pry open the stadia controller: crwdns2935265:06crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Google Stadia Controller Thumbstick Replacement, Pry open the stadia controller: crwdns2935265:06crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Insert a Jimmy into the gap between the front and back cover assembly at the inside of the left controller handle.
    • To make sure you insert the Jimmy at the correct position where the clamps are located, you can use this photo.
    • Tilt the Jimmy upwards and push it into the gap between the covers at the same time to pry open the plastic clamp. You should hear a clack noise once the clamp pops open.
    • Once the clamp is completely open, the gap between the two controller covers should be about 2-3 mm wide.
  7. Google Stadia Controller Thumbstick Replacement, Insert an opening pick: crwdns2935265:07crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Google Stadia Controller Thumbstick Replacement, Insert an opening pick: crwdns2935265:07crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Insert an opening pick in a steep angle into the gap you created to prevent the first clamp from popping back into its closed position.
  8. Google Stadia Controller Thumbstick Replacement, Pry open the Stadia controller: crwdns2935265:08crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Google Stadia Controller Thumbstick Replacement, Pry open the Stadia controller: crwdns2935265:08crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Google Stadia Controller Thumbstick Replacement, Pry open the Stadia controller: crwdns2935265:08crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Insert a Jimmy into the gap between the front and back cover assembly at the outside of the left bottom end of the controller handle.
    • Repeat the previous opening procedure to open the three plastic clamps at the outside of the left controller handle.
  9. Google Stadia Controller Thumbstick Replacement: crwdns2935265:09crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Google Stadia Controller Thumbstick Replacement: crwdns2935265:09crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Google Stadia Controller Thumbstick Replacement: crwdns2935265:09crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Insert a Jimmy into the gap between the front and back cover assembly between the left shoulder button and the charging port at the top edge of the Stadia controller.
    • Repeat the previous procedure at the clamp between the right shoulder button and the charging port.
  10. Google Stadia Controller Thumbstick Replacement: crwdns2935265:010crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Google Stadia Controller Thumbstick Replacement: crwdns2935265:010crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Google Stadia Controller Thumbstick Replacement: crwdns2935265:010crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Insert a Jimmy into the gap between the front and back cover assembly at the right edge of the right controller handle.
    • Repeat the previous opening procedure to open the three plastic clamps at the outside of the right controller handle.
  11. Google Stadia Controller Thumbstick Replacement: crwdns2935265:011crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Google Stadia Controller Thumbstick Replacement: crwdns2935265:011crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Insert a Jimmy into the gap between the front and back cover assembly at the inside of the right controller handle.
    • Repeat the previous opening procedure to open plastic clamps at the inside of the left controller handle.
  12. Google Stadia Controller Thumbstick Replacement: crwdns2935265:012crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Google Stadia Controller Thumbstick Replacement: crwdns2935265:012crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Google Stadia Controller Thumbstick Replacement: crwdns2935265:012crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Insert a Jimmy into the gap between the front and back cover assembly at the bottom edge of the Stadia controller right to the headphone jack.
    • Repeat the previous procedure at the clamp left to the headphone jack.
    • Do not try to remove the front cover assembly all the way yet. It's still connected to the rear cover assembly.
  13. Google Stadia Controller Thumbstick Replacement, Unfold the front cover assembly: crwdns2935265:013crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Google Stadia Controller Thumbstick Replacement, Unfold the front cover assembly: crwdns2935265:013crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Google Stadia Controller Thumbstick Replacement, Unfold the front cover assembly: crwdns2935265:013crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Avoid straining the front cover assembly cable during this step.
    • Carefully lift the front cover assembly and fold it to the left side of the Google Stadia controller.
  14. Google Stadia Controller Thumbstick Replacement, Remove the right thumbstick: crwdns2935265:014crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Google Stadia Controller Thumbstick Replacement, Remove the right thumbstick: crwdns2935265:014crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Use your fingers to remove the right thumbstick by pulling it upwards and off the right joystick.
  15. Google Stadia Controller Thumbstick Replacement, Remove the left thumbstick: crwdns2935265:015crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Google Stadia Controller Thumbstick Replacement, Remove the left thumbstick: crwdns2935265:015crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Use your fingers to remove the left thumbstick by pulling it upwards and off the left joystick.
Dominik Schnabelrauch
crwdns2935283:011/23/16crwdne2935283:0
235,812 crwdns2915208:0crwdne2915208:0
crwdns2935297:0682crwdne2935297:0
Staff
crwdns2931471:0120crwdne2931471:0
crwdns2935297:021,122crwdne2935297:0
crwdns2936753:07crwdne2936753:0 19
crwdns2936753:030crwdne2936753:0 76
crwdns2942667:0crwdne2942667:0 2,560
