Google Pixel 8a Screen Replacement
  1. Google Pixel 8a Screen Replacement, Prepare your Pixel for disassembly: crwdns2935265:01crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Google Pixel 8a Screen Replacement, Prepare your Pixel for disassembly: crwdns2935265:01crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Google Pixel 8a Screen Replacement, Prepare your Pixel for disassembly: crwdns2935265:01crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Let your Pixel's battery drain below 25% before starting this repair. A charged lithium‑ion battery may catch fire if damaged.
    • Unplug all cables from your phone.
    • Completely power off your phone.
    • Press the power and volume up buttons at the same time to bring up the shutdown menu.
    Mein Bildschirm ist schwarz - das Smartphone reagiert jedoch. Wie kann ich es ausschalten wenn ich kein Bild nicht sehe?
    Ulises - crwdns2934203:0crwdne2934203:0
    Press the power and volume up button, and imagine where the power off button will be on the screen. Touch area and wait a couple of minutes. Then call or text your phone to see it any notifications or ringing would indicate eithers it's on or off. You can also try to use find my device from the web to see if you can ping or find the phone if it's on you will find it, if off it will not ring.
    Dave Hom -
    My phone is cracked to the point where no image is shown, nor is touch registered. How can I safely power off the phone before replacing the screen?
    Jayden Hua - crwdns2934203:0crwdne2934203:0
    Let it run out of battery, then change your screen. Plug the phone back onto the charger at the point where you need to confirm your repair before sealing it with adhesive.
    Dave Hom -
  2. Google Pixel 8a Screen Replacement, Tape over any cracks: crwdns2935265:02crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Google Pixel 8a Screen Replacement, Tape over any cracks: crwdns2935265:02crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Glass shards can complicate disassembly—or worse, cause injury. If your phone has a cracked screen, follow these steps:
    • Apply overlapping strips of packing tape to the cracked glass until the whole screen is covered—this will allow the suction cup to stick to the screen.
    • Only cover the glass itself—don't stick any tape to the frame.
    • Consider wearing safety glasses to protect your eyes from any glass shaken free during the repair.
    If the glass is broken, the suction cup will not adhere.
    Justin Santa Barbara - crwdns2934203:0crwdne2934203:0
  3. Google Pixel 8a Screen Replacement, Soften the top edge adhesive: crwdns2935265:03crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • The screen is strongly adhered to the frame, has no clips, and resists flexing. It requires significant heat to soften the adhesive underneath.
    • Use a hair dryer, heat gun, or hot plate to heat the top edge of the screen until it's almost too hot to touch.
    • Be careful not to overheat the phone—the battery and plastic components are susceptible to heat damage. Stop heating if the frame becomes too hot to touch.
  4. Google Pixel 8a Screen Replacement, Insert your tool under the screen: crwdns2935265:04crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Google Pixel 8a Screen Replacement, Insert your tool under the screen: crwdns2935265:04crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Apply a suction handle to the center of the top edge of the screen.
  5. Google Pixel 8a Screen Replacement: crwdns2935265:05crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Google Pixel 8a Screen Replacement: crwdns2935265:05crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Google Pixel 8a Screen Replacement: crwdns2935265:05crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    Jimmy
    $7.95
    • Inserting your tool is very difficult. Be patient and reheat the screen at any point if it feels stuck.
    • Don't insert your tool deeper than 2 mm, as you risk damaging the front-facing camera.
    • Insert the tip of a Jimmy into the left side of the earpiece speaker cutout.
    • If you don't have a Jimmy, you can use another small metal tool. Make sure it's thin and rigid.
    • Pull up on the suction handle with a strong, steady force.
    • Firmly press the Jimmy into the cutout and lower it until the tip slides under the glass.
  6. Google Pixel 8a Screen Replacement: crwdns2935265:06crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Google Pixel 8a Screen Replacement: crwdns2935265:06crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Google Pixel 8a Screen Replacement: crwdns2935265:06crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Insert the tip of an opening pick under the screen and remove the Jimmy.
  7. Google Pixel 8a Screen Replacement, Separate the screen adhesive: crwdns2935265:07crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Google Pixel 8a Screen Replacement, Separate the screen adhesive: crwdns2935265:07crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Google Pixel 8a Screen Replacement, Separate the screen adhesive: crwdns2935265:07crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Don't insert your pick deeper than 2 mm, as you might damage the front-facing camera.
    • Slide your pick back and forth across the top edge of the screen to separate the adhesive.
  8. Google Pixel 8a Screen Replacement: crwdns2935265:08crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Google Pixel 8a Screen Replacement: crwdns2935265:08crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Google Pixel 8a Screen Replacement: crwdns2935265:08crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Don't insert your pick deeper than 3 mm, as you might damage your phone's internal components.
    • For a visual reference, you can measure 3 mm from the tip and mark your pick with a permanent marker.
    • Continue sliding your pick around the perimeter of the phone to separate the remaining adhesive.
    Könnt ihr am Plektrum abschnitte für die Millimeter direkt draufdrucken?
    Lukas Schmidt - crwdns2934203:0crwdne2934203:0
    Hier wurde einen Schritt vergessen. Es gibt noch Klebstoff unten mittig unter der Bildschirm. Diese muss auch vorsichtig abgemacht werden. Mein Bildschirm hat sich delaminiert beim Abbau.
    dsavio93 - crwdns2934203:0crwdne2934203:0
  9. Google Pixel 8a Screen Replacement: crwdns2935265:09crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Google Pixel 8a Screen Replacement: crwdns2935265:09crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Google Pixel 8a Screen Replacement: crwdns2935265:09crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Swing the right edge of the screen open (like turning the page of a book) and lay it over the left edge of the frame.
    • Be careful not to strain the screen cable.
  10. Google Pixel 8a Screen Replacement, Disconnect the screen: crwdns2935265:010crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Google Pixel 8a Screen Replacement, Disconnect the screen: crwdns2935265:010crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Move the flap of graphite film away from the screen connector.
  11. Google Pixel 8a Screen Replacement: crwdns2935265:011crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Google Pixel 8a Screen Replacement: crwdns2935265:011crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Google Pixel 8a Screen Replacement: crwdns2935265:011crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Hold one hand above the display bracket when prying it up, as the bracket can easily eject.
    • Use the tip of one arm of your angled tweezers to pry up the top edge of the display cable bracket from the center of the logic board.
    • Be very careful not to damage the board under the bracket's socket. Only insert your tweezers just enough to pry up the bracket.
    • Remove the bracket.
  12. Google Pixel 8a Screen Replacement: crwdns2935265:012crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Google Pixel 8a Screen Replacement: crwdns2935265:012crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Insert the tip of a spudger or a clean fingernail under the top edge of the display cable press connector and pry straight up to disconnect it.
    • To reconnect a press connector, align it over the socket and gently press down on one side until it clicks into place, then press down on the other side. It might take a few tries to align the connector.
  13. Google Pixel 8a Screen Replacement: crwdns2935265:013crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Google Pixel 8a Screen Replacement: crwdns2935265:013crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Use tweezers or your fingers to pull the screen cable out from under its lip on the edge of the frame.
  14. Google Pixel 8a Screen Replacement: crwdns2935265:014crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Google Pixel 8a Screen Replacement: crwdns2935265:014crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Remove the screen.
    • The back of the Pixel's screen is very fragile. Even a small scratch or dent can damage the screen.
    • To prevent damaging your screen or replacement screen:
    • When handling your screen, grip it by its edges.
    • When placing the screen on your work area, make sure nothing is touching the bottom of the screen. Consider placing it on a soft, lint-free cloth.
  15. Google Pixel 8a Screen Replacement: crwdns2935265:015crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Google Pixel 8a Screen Replacement: crwdns2935265:015crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Google Pixel 8a Screen Replacement: crwdns2935265:015crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • The remaining steps show how to install your replacement screen.
    • Make sure the front sensor gasket (located just below the front camera) is properly aligned and fully over the sensor.
    • If it's not, reposition it over the front sensor with the smaller cutout toward the top.
  16. Google Pixel 8a Screen Replacement, Prepare the frame for reassembly: crwdns2935265:016crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Google Pixel 8a Screen Replacement, Prepare the frame for reassembly: crwdns2935265:016crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • The underside of the battery is exposed through a small cutout in the frame—be careful not to damage it with your tool.
    • Use tweezers and a spudger to scrape up and remove any remaining pieces of adhesive below the battery cutout.
  17. Google Pixel 8a Screen Replacement: crwdns2935265:017crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Google Pixel 8a Screen Replacement: crwdns2935265:017crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • If any screen adhesive bits remain on the perimeter of the frame, use a spudger and tweezers to scrape up and remove them.
  18. Google Pixel 8a Screen Replacement: crwdns2935265:018crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Google Pixel 8a Screen Replacement: crwdns2935265:018crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • If you're reusing your original screen, use a spudger and tweezers to scrape up and remove the old adhesive from the perimeter of the screen.
  19. Google Pixel 8a Screen Replacement: crwdns2935265:019crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Google Pixel 8a Screen Replacement: crwdns2935265:019crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    Microfiber Cleaning Cloths
    $3.99
    • Use a pipette or syringe to apply a few drops of highly-concentrated isopropyl alcohol (over 90%) to the perimeter of the frame and the area below the battery cutout.
    • Wipe the residue away using a lint-free or microfiber cloth.
  20. Google Pixel 8a Screen Replacement, Apply new adhesives: crwdns2935265:020crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Google Pixel 8a Screen Replacement, Apply new adhesives: crwdns2935265:020crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Peel the rectangular display enclosure adhesive from its large liner.
    • Apply the adhesive to the frame in the same location as the old adhesive, just below the battery cutout.
    • Use the white line on the frame to help align the right edge.
    • Use your fingers to press down and secure the adhesive to the frame—don't remove the top liner yet.
    I bought a screen only as I had to replace a second time. This adhesive was not included in my delivery.
    Uwe Wolfram - crwdns2934203:0crwdne2934203:0
  21. Google Pixel 8a Screen Replacement: crwdns2935265:021crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Google Pixel 8a Screen Replacement: crwdns2935265:021crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • If your screen already comes with adhesive pre-installed, remove its liner and skip down six steps to continue reassembly.
    • Before removing any liners from the screen adhesive, hold it over the frame to make sure it's oriented correctly. Use the camera cutout on the top edge to line it up correctly.
    • The blue liner should be facing up, with the larger, clear liner on the bottom.
    It's probably just me, but the large blue sheet looks very similar to other blue protective sheets covering the adhesive. I think it should be stated earlier that it is only the black edge which is the adhesive.
    Or remove these steps into a link and make the newer screens with adhesive the main instruction
    David Loader - crwdns2934203:0crwdne2934203:0
  22. Google Pixel 8a Screen Replacement: crwdns2935265:022crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Peel down the top half of the larger liner (closest to the camera cutout) to expose the adhesive—don't remove the whole liner yet.
  23. Google Pixel 8a Screen Replacement: crwdns2935265:023crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Google Pixel 8a Screen Replacement: crwdns2935265:023crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Google Pixel 8a Screen Replacement: crwdns2935265:023crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Take your time aligning the adhesive with the frame—it's very sticky and can't be moved after you apply it.
    • Keep the larger liner folded towards the bottom of the phone during this step.
    • Lay the exposed top edge of the adhesive onto the frame, using the lip to help align it.
    • Once the top edge is properly aligned, gently press down to secure it in place.
  24. Google Pixel 8a Screen Replacement: crwdns2935265:024crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Google Pixel 8a Screen Replacement: crwdns2935265:024crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Google Pixel 8a Screen Replacement: crwdns2935265:024crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Slowly lay the rest of the adhesive onto the frame, peeling away the large liner as you go.
  25. Google Pixel 8a Screen Replacement: crwdns2935265:025crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Google Pixel 8a Screen Replacement: crwdns2935265:025crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Google Pixel 8a Screen Replacement: crwdns2935265:025crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Use the flat end of your spudger to press along the perimeter of the adhesive and secure it to the frame.
  26. Google Pixel 8a Screen Replacement: crwdns2935265:026crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Google Pixel 8a Screen Replacement: crwdns2935265:026crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Google Pixel 8a Screen Replacement: crwdns2935265:026crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Grab the pull tab in the center of the left edge and slowly peel and remove the liner.
    • If the adhesive starts to peel up with the liner, check that you’ve pushed all of it into place with your spudger. If it continues to peel up, hold it down with the point of your spudger as you go.
  27. Google Pixel 8a Screen Replacement, Reattach the screen: crwdns2935265:027crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Google Pixel 8a Screen Replacement, Reattach the screen: crwdns2935265:027crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Apply a suction handle to the left side of the replacement screen, with the handle facing left.
    • Prop up your screen on the left side of the frame.
    • If you don't have a suction handle, prop up the phone against a sturdy object, such as a heavy box or thick book.
  28. Google Pixel 8a Screen Replacement: crwdns2935265:028crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Connect the screen cable by aligning it over the socket and pressing on one side until it clicks into place before fully pressing it down.
    • Now is a good time to test your phone before sealing it up. Power it on and check that it works. Power it back down before you continue reassembly.
    My screen shows the google animation bootup in very tinted yellow and dim/dark. Then the time appears for less than a second and the screen goes completely black. Did I get a defective part?
    John - crwdns2934203:0crwdne2934203:0
    Hi, I hope somebody will be able to give some help. My screen wouldnt turn on after insterting my new screen connector, can anyone give me some advice on where i went wrong?
    Jimmy Lau - crwdns2934203:0crwdne2934203:0
    It really should be stressed here to be extremely careful!
    There is almost no feedback through your fingers or tools whether the cable is in the correct position before pressing down.
    100% this was the hardest/nerve-wracking part of the job
    I can feel the click on what I believe is the alignment of the connector but unfortunately my screen won't cut on and show anything to me 😭
    Kayla C - crwdns2934203:0crwdne2934203:0
    I too have the same problem. My new screen won't light up at all. The previous screen at least used to show some flickering. It was not cracked. My phone has water damage. I wanted to switch the old screen back but now I cannot as there is no way to turn off the phone. The new screen is not working and since I had to recharge the battery a little bit to test it, I now again have to wait for the battery to drain and the phone to auto-shut.
    Abhijeet D - crwdns2934203:0crwdne2934203:0
  29. Google Pixel 8a Screen Replacement: crwdns2935265:029crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Google Pixel 8a Screen Replacement: crwdns2935265:029crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Hook the bottom edge of the bracket into its slot on the logic board and press down firmly on the top to snap the bracket back into place.
    • If your display cable bracket is bent and doesn't fit, replace it with a new one.
  30. Google Pixel 8a Screen Replacement, Remove the liners: crwdns2935265:030crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove any liners from the front camera housing on the top edge of the screen.
  31. Google Pixel 8a Screen Replacement: crwdns2935265:031crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Google Pixel 8a Screen Replacement: crwdns2935265:031crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Google Pixel 8a Screen Replacement: crwdns2935265:031crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Peel and remove the blue liner from the square adhesive on the frame, just below the battery cutout.
  32. Google Pixel 8a Screen Replacement: crwdns2935265:032crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Google Pixel 8a Screen Replacement: crwdns2935265:032crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Google Pixel 8a Screen Replacement: crwdns2935265:032crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Use the pull tabs on the left edge to peel and remove the remaining perimeter adhesive liner.
  33. Google Pixel 8a Screen Replacement, Secure the new screen: crwdns2935265:033crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Google Pixel 8a Screen Replacement, Secure the new screen: crwdns2935265:033crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Google Pixel 8a Screen Replacement, Secure the new screen: crwdns2935265:033crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Hold the screen just above the frame by the suction handle.
    • Use a spudger to fold the flap of graphite film back over the screen cable.
    • Press the screen into place.
  34. Google Pixel 8a Screen Replacement: crwdns2935265:034crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Google Pixel 8a Screen Replacement: crwdns2935265:034crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Google Pixel 8a Screen Replacement: crwdns2935265:034crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Remove the suction handle.
    • For a better seal, lightly warm the screen with a heated iOpener, hair dryer, heat gun, or hot plate before pressing around the perimeter.
    • Firmly press around the perimeter of the screen to secure it to the frame.
To calibrate the display’s fingerprint reader, use Google’s Pixel Update and Software Repair tool.
To run a diagnostics test with the built-in Pixel Diagnostic tool, click here.
crwdns2935229:041crwdne2935229:0
Spencer Day
crwdns2935283:009/14/22crwdne2935283:0
119,439 crwdns2915208:0crwdne2915208:0
crwdns2935297:0838crwdne2935297:0
Staff
crwdns2931471:0119crwdne2931471:0
crwdns2935297:021,980crwdne2935297:0
crwdns2947412:023crwdne2947412:0
so where is the replacement screens??
lsdfkgjlsdfjkl - crwdns2934203:0crwdne2934203:0
You can purchase a new screen from iFixit here.
Spencer Day -
Great step by step guide, it took a little time but was well worth it with my busted screen!
Kabel - crwdns2934203:0crwdne2934203:0
I think my screen was defective. It shows the boot up animation extremely yellowed out and dim/dark. Then it shows my lockscreen with the time for less than a second and goes complete black. I can still make my phone vibrate with the buttons, and do a reset to get the boot up animation again. It's just so frustrating because I really needed this to work and did so much of the hard work to get to the final steps, to find out... that the replacement screen is defective!!!!
Hi John. I'm sorry to hear you're having issues with the replacement screen—that's very frustrating after taking the time to do the repair. My first thought is that the screen connector may not be fully seated (this connector in particular can be quite tricky to reconnect). If that's not the case, you can contact our customer support (support@ifixit.com) about a defective screen.
Spencer Day -
I've contacted support and they have yet to get back to me. I will be initiating a return. I don't think I would have attempted this repair again, taking the screen off was far far more difficult than it's worth. I'd take it to a repair shop.
John -
Excellent support and great company. I had a problem with the fingerprint sensor, which after starting it up indicated that it was faulty. I requested a replacement and everything went great. Thanks!
Carles Gomez - crwdns2934203:0crwdne2934203:0
You should add the part to recalibrate the fingerprint (pixelrepair.withgoogle.com/udfps) in your tutorial.
Bruno Spolidorio - crwdns2934203:0crwdne2934203:0
Thank you so much! As a first time screen repairer, it wasn't clear to me how deep I should insert the jimmy in the earpiece cutout. The screen assembly is much thinner than I imagined. Also, the screen was badly cracked so removal was overall messy. In the end I figured it out and after that it was all smooth sailing, but some additional clarifying notes in that section might be useful :)
Marco Baggio - crwdns2934203:0crwdne2934203:0
That's exactly what happened to me. I was super frustrated with their manual. to be honest, i'm not sure I'd choose this option again.
Tal Givati -
Did this as my first screen repair. Thanks heaps Spencer.
The only feedback I would suggest for this manual is how to handle massively cracked edges. Non cracked edges separated easily, but the blue pick looses its way when it gets to the cracked edges - I had a few - and for my first screen repair I was stuck.
I did end up applying some heat, and using the tweezers to carefully pry the screen away from the phone by grabbing the backing of the screen where it was stable. This worked. Most of the glass complied with the tweezers/heat method. The left over glass stuck to the frame was easy to remove with the spudger. Please let me know if there was a better way to do this.
The pixel 8a I have cost me $679 on special from JB-HifI. A local repairer quote me $700 - $800 to fix the screen - but I had to commit to a $99 diagnostic fee first.
Much much cheaper to fix it myself.
Thanks again!
Julius Csepregi - crwdns2934203:0crwdne2934203:0
Attempting this repair with the full ifixit kit has been a disaster. First off, the guide is not fit for purpose - if you have any cracks that run to the edge of the screen it is impossible to proceed past them with undoing the glue rim. Trying to just shatters the glass further. Also the suction cup is useless, does not adhere at all, even when using the tape as described. Now I have a completely broken phone screen that I cannot even use to recover the data (I should have backed up, but seemed like an easy enough repair for someone who has already had experience with these) and then I have an unused new screen i have no use for as I cannot repair this phone anymore. Urgh... 1/10 !!
Maciej Jabłoński - crwdns2934203:0crwdne2934203:0
A few days after the repair I wanted to put on a protective glass. I applied more then usual pressure on the screen and now my screen has a white stripe top to bottom and it does not react properly to my touch. Any idea as to what happened or how to fix it? Helpp!
Vielen Dank - Der Displaytausch hat perfekt funktioniert.
Die Werkzeuge im Set sind super und nichts fehlt. Selbst als Neuling hat in knapp zwei Stunden alles funktioniert.
ABER VORSICHT: Das Google update und repair tool hat einen schwerwiegenden Fehler. Die Software arbeitet nicht mit der aktuellsten Androidversion zusammen. Das wäre nicht so schlimm, wenn man im Fast-Modus nicht in einer Boot-Schleife landen würde!
Nach einer verzweifelten Stunde mit dutzenden Fehlversuchen habe ich aufgegeben. Das war mein Glück. Nach einer halben Stunde Inaktivität beendet sich der Fastmodus selber.....
Dirk Kwee - crwdns2934203:0crwdne2934203:0
Great tutorial. The worst part is removing the damaged old screen. Patience and persistent even heating is a must. Thanks for this guide.
AssyMcGee - crwdns2934203:0crwdne2934203:0
Very comprehensive & helpful guide 💘
Simon Felix Conrad - crwdns2934203:0crwdne2934203:0
Well done. How great the senTence serves well.
tyledge9211 - crwdns2934203:0crwdne2934203:0
I bought a genuine Google screen from iFixit and found that using this guide and a bit of common sense, I was able to successfully install the new screen. Unfortunately, when I tested the front facing camera, I found that the image was blurred. I removed the film cover from the front camera housing, so it's not that. The camera seems to be sitting perfectly in the camera housing so I'm not attributing it to that either. Any suggestions?
Julian - crwdns2934203:0crwdne2934203:0
What if you just need to replace the outer glass, not the entire "screen" as shown here? Do you have steps for separating & replacing just the outer glass?
Jeff Bihlman - crwdns2934203:0crwdne2934203:0
I purchased the kit and followed the guide. Everything went smoothly except the point for recalibrating the fingerprint sensor:
The tool by google claimed that the software on my device is newer than the version the service tool supports. So it suggests to use another service tool to install an old image. The tool did not succeed after several retries to install an older software image. So at the moment I'm stuck with a working phone without fingerprint sensor.
ifixit is not to blame for this, rather google in servicing it's support tools so badly. If you want to claim proper repairability you need also to keep the necessary software tools up to date
Matthias Schuh - crwdns2934203:0crwdne2934203:0
If your screen is severely cracked like mind was, you'll find removing the screen to be a bit difficult, as the screen will come off in pieces. Just go slow. I found liberal use of my wife's hair dryer to be very effective.
This guide does not mention that the screen/fingerprint sensor needs to be recalibrated when the new screen is installed. I would suggest adding another step (or even just a final note) with a link to recalibrating the screen.
How to Calibrate the Fingerprint Sensor in your Google Pixel Phone
David M - crwdns2934203:0crwdne2934203:0
I ordered the kit from ifixit, and it came with their iOpener for heating up the device, but the directions don't mention using it for loosening the glue. I'm wondering if it'll get hot enough or if I'll need to try with a hair dryer.
Castor Fu - crwdns2934203:0crwdne2934203:0
Hi @castorfu! Just to confirm, are you using the Pixel 8a Screen Fix Kit? It shouldn't come with an iOpener. You should use a hairy dryer, as you're right in assuming the iOpener most likely won't be able to soften the adhesive enough.
Spencer Day -
crwdns2936751:024crwdne2936751:0 126
crwdns2936753:07crwdne2936753:0 796
crwdns2936753:030crwdne2936753:0 3,460
crwdns2942667:0crwdne2942667:0 32,712
