Google Pixel 5 Motherboard Replacement
  1. Google Pixel 5 Motherboard Replacement, Eject the SIM card tray: crwdns2935265:01crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Google Pixel 5 Motherboard Replacement, Eject the SIM card tray: crwdns2935265:01crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Google Pixel 5 Motherboard Replacement, Eject the SIM card tray: crwdns2935265:01crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Insert a SIM eject tool, bit, or straightened paper clip into the SIM card tray hole.
    • The SIM card tray is located on the left edge of the phone near the bottom.
    • Press firmly to eject the SIM card tray.
    • Remove the SIM card tray.
    What if a sim tray stack in side the phone what can we do ?
    Njoka - crwdns2934203:0crwdne2934203:0
  2. Google Pixel 5 Motherboard Replacement, Heat the bottom edge of the screen: crwdns2935265:02crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Heat an iOpener and apply it to the bottom edge of the screen for one minute.
    • A hair dryer, heat gun, or hot plate may also be used, but be careful not to overheat the phone—the display and internal battery are both susceptible to heat damage.
    It would be helpful to know for how long ally the heated pad
    Yuri Deglin - crwdns2934203:0crwdne2934203:0
    Agreed, my friend from the past.
    Albert Einstein -
    If you click on the "iOpener" link, it tells you to heat it up for 30 seconds, and if you're using a microwave with a carousel, make sure it moves freely.
    Azurina Schalk-Smith - crwdns2934203:0crwdne2934203:0
    How long do you think it would take with a hair dryer?
    Gen L. - crwdns2934203:0crwdne2934203:0
    Don't have a microwave, so I boiled the kettle, left the iOpener in for 5 minutes and it was a good temperature to go. Doesn't need to be that hot to be effective
    Rick - crwdns2934203:0crwdne2934203:0
    i damaged my digitizer using a hair dryer ugh
    marco - crwdns2934203:0crwdne2934203:0
  3. Google Pixel 5 Motherboard Replacement, Screen removal information: crwdns2935265:03crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Google Pixel 5 Motherboard Replacement, Screen removal information: crwdns2935265:03crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Google Pixel 5 Motherboard Replacement, Screen removal information: crwdns2935265:03crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • While you're waiting for the adhesive to loosen, take note of the following:
    • Screen seam: This seam separates the screen from the rest of the phone. Do not pry at this seam.
    • Bezel seam: This is where the plastic bezel designed to protect the screen meets the frame. It's held in place by plastic clips. This is where you should pry.
    Please remove the image of the pick in the bottom of the phone in Step 2. This led me to place a pick there BEFORE step 5 which damaged my digitizer. Now I have to replace the entire screen as a result.
    Alternatively, add the image from step 5 with the suction cup in place, or just draw an arrow digitally to the seam you're referring to in step 2. Or call "Step 2" "Important Note" instead of a step.
    David Smith - crwdns2934203:0crwdne2934203:0
    Wow, I'm glad I read this first. I too assumed this step was about inserting the pick, but wasn't sure because it wasn't clearly written that way.
    Agreed with the "important note" idea, along with combining this with step 5 where the context is actually relevant.
    Marco Carag -
    Just made this same mistake and the photo is still there... there goes another $180...
    Carlos Moreno - crwdns2934203:0crwdne2934203:0
  4. Google Pixel 5 Motherboard Replacement, Anti-Clamp instructions: crwdns2935265:04crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Google Pixel 5 Motherboard Replacement, Anti-Clamp instructions: crwdns2935265:04crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Google Pixel 5 Motherboard Replacement, Anti-Clamp instructions: crwdns2935265:04crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    Clampy - Anti-Clamp
    $24.95
    • The next two steps demonstrate the Anti-Clamp, a tool we designed to make the opening procedure easier. If you aren't using the Anti-Clamp, skip down two steps for an alternate method.
    • For complete instructions on how to use the Anti-Clamp, check out this guide.
    • Pull the blue handle towards the hinge to disengage opening mode.
    • Position the suction cups near the bottom edge of the screen—one on the front, and one on the back.
    • Push down on the cups to apply suction to the desired area.
    • If you find that the surface of your device is too slippery for the Anti-Clamp to hold onto, you can use packing tape to create a grippier surface.
  5. Google Pixel 5 Motherboard Replacement: crwdns2935265:05crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Google Pixel 5 Motherboard Replacement: crwdns2935265:05crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Google Pixel 5 Motherboard Replacement: crwdns2935265:05crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Push the blue handle away from the hinge to engage opening mode.
    • Turn the handle clockwise until you see the cups start to stretch.
    • Make sure the suction cups remain aligned to each other. If they begin to slip out of alignment, loosen the suction cups slightly and realign the arms.
    • Wait one minute to give the adhesive a chance to release and present an opening gap.
    • Insert an opening pick under the screen and its bezel frame when the Anti-Clamp creates a large enough gap.
    • If the Anti-Clamp doesn't create a sufficient gap, apply more heat to the area and rotate the handle clockwise half a turn.
    • Don't crank more than a half a turn at a time, and wait one minute between turns. Let the Anti-Clamp and time do the work for you.
    • Skip the next step.
  6. Google Pixel 5 Motherboard Replacement, Insert an opening pick: crwdns2935265:06crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Google Pixel 5 Motherboard Replacement, Insert an opening pick: crwdns2935265:06crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Google Pixel 5 Motherboard Replacement, Insert an opening pick: crwdns2935265:06crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Apply a suction cup to the screen, as close to the heated edge as possible.
    • If your screen is badly cracked, follow this guide to tape over the cracked screen. If all else fails, you can superglue the suction cup to the broken screen.
    • Pull up on the suction cup with strong, steady force to create a gap.
    • Depending on the age of your device, this may be difficult. If you have trouble, apply more heat and try again.
    • Insert the opening pick into the gap.
    "Insert the opening pick into the gap." NOT the gap under the glass, the second gap... If not you will probably break your screen, at least I did. Especially important if your pixel 5 shipped with the screen gap :(
    Alex Beaven (Nevbox) - crwdns2934203:0crwdne2934203:0
  7. Google Pixel 5 Motherboard Replacement, Slice the bottom adhesive: crwdns2935265:07crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Google Pixel 5 Motherboard Replacement, Slice the bottom adhesive: crwdns2935265:07crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Google Pixel 5 Motherboard Replacement, Slice the bottom adhesive: crwdns2935265:07crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Slide the opening pick back and forth along the bottom of the screen to slice the adhesive.
    • Leave the pick inserted in the bottom right corner to prevent the adhesive from re-sealing.
  8. Google Pixel 5 Motherboard Replacement, Heat the left edge of the screen: crwdns2935265:08crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Apply a heated iOpener to the left edge of the screen for one minute.
  9. Google Pixel 5 Motherboard Replacement: crwdns2935265:09crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Google Pixel 5 Motherboard Replacement: crwdns2935265:09crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Google Pixel 5 Motherboard Replacement: crwdns2935265:09crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Insert another opening pick into the bottom left corner of the screen.
    • Slide the opening pick around the left corner.
    • Do not insert the pick more than 1/4 inch (6 mm) or you may damage the screen's flex cable located in the middle of the left edge.
    • Continue to slide the pick up towards the front camera to slice the adhesive on the left edge of the screen.
    • Leave the pick inserted to prevent the adhesive from re-sealing.
    I suggest placing an orientation sticker on the screen so you don't lose track of where that delicate ribbon cable is. I gently bent one, immediately after doing a successful one, resulting in a costly screen replacement. It's important to know that it's incredibly delicate.
    Edward McClung - crwdns2934203:0crwdne2934203:0
    I bent one of the picks at the end up 90 degrees with the tweezers to a depth of 3/16" and it worked beautifully. Left it on that side to remember where it was important.
    James Bennett - crwdns2934203:0crwdne2934203:0
  10. Google Pixel 5 Motherboard Replacement: crwdns2935265:010crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Google Pixel 5 Motherboard Replacement: crwdns2935265:010crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Google Pixel 5 Motherboard Replacement: crwdns2935265:010crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Insert another opening pick into the top left corner of the screen.
    • Slide the pick around the front camera and across the top edge of the phone.
    • If the adhesive is difficult to slice, apply heat to the area for one minute and try again.
    • Slide the pick to the top right corner of the phone and leave the pick inserted.
  11. Google Pixel 5 Motherboard Replacement: crwdns2935265:011crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Google Pixel 5 Motherboard Replacement: crwdns2935265:011crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Google Pixel 5 Motherboard Replacement: crwdns2935265:011crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Insert an opening pick into the bottom right corner of the screen.
    • Slide the pick up to the top right corner to slice the last edge of adhesive.
    • You may need to run an opening pick around the edges again to ensure all the adhesive is cut. It is applied the thickest on the four corners.
  12. Google Pixel 5 Motherboard Replacement, Open up the screen: crwdns2935265:012crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Google Pixel 5 Motherboard Replacement, Open up the screen: crwdns2935265:012crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Use the opening pick from the top left corner to lift up the left edge of the screen a few millimeters. This will keep the clips from snapping back down into the case.
    • Lift up on the right side of the screen and open up the phone like a book.
    • Do not open the screen more than 90 degrees to prevent damaging the screen flex cable.
  13. Google Pixel 5 Motherboard Replacement, Disconnect the screen: crwdns2935265:013crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Google Pixel 5 Motherboard Replacement, Disconnect the screen: crwdns2935265:013crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Use tweezers to grip the screen connector cover securing the screen flex cable.
    • Push the clip in towards the connector to unlatch it.
    I found it easier to use the spudger here rather than the tweezers (which have sharp ends that could damage something if you happen to slip).
    tristanwaddington - crwdns2934203:0crwdne2934203:0
    some 5a models will have a screw instead of clip , here's a photo https://imgur.com/a/9dZG5pQ
    Daniel Gonzales - crwdns2934203:0crwdne2934203:0
    You commented on the guide for the Pixel 5, not the 5a: Google Pixel 5a
    Pixel -
    I just fought with this part using the tweezers for several attempts, and then with the spudger it came right out when I applied force towards the center of the left edge.
    Michael Gundlach - crwdns2934203:0crwdne2934203:0
  14. Google Pixel 5 Motherboard Replacement: crwdns2935265:014crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Google Pixel 5 Motherboard Replacement: crwdns2935265:014crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Remove the screen connector cover.
    • Make sure to keep this component to reinstall it during reassembly.
  15. Google Pixel 5 Motherboard Replacement: crwdns2935265:015crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Google Pixel 5 Motherboard Replacement: crwdns2935265:015crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Use the tip of the spudger to pry up and disconnect the screen flex cable.
    • To re-attach press connectors like this one, carefully align and press down on one side until it clicks into place, then repeat on the other side. Do not press down on the middle. If the connector is misaligned, the pins can bend, causing permanent damage
    The curved ends of the blue iFixit Opening Tool helped me reseat the connector when installing the new screen.
    Jesus no wonder the Chinese factory workers kill themselves, this thing is brutal
    Holy Moly - crwdns2934203:0crwdne2934203:0
    So hard to get this thing reseated to test the screen, even before putting the adheasive round the phone edge to finish the job. What made it particularly hard was that the flex cable on mine seemed very short compared to video's i've seen online.
    Jake Boddington - crwdns2934203:0crwdne2934203:0
    Reattaching this press connector was the worst! By the time I had done all the steps below and then in reverse, I was ready to be DONE. Be careful, patient and gentle.
    I too wanted to test my screen before the final adhesives and when I finally got the connection done and tested my screen, I HATED that I had to undo the connection to attached the adhesive.
    If using the Pixel 5 display adhesive that comes in the battery repair kit, there are actually two sets of blue protective covers. One that helps align the adhesive to the frame. Once that is removed, there is a very thin blue cover on the adhesive itself - that does split in two pieces. So, all this said, I could have attached the adhesive before testing the screen and would have been able to leave the adhesive strip with the blue protective cover in place if I needed to make any adjustments before sealing the screen to the frame.
    Kristi Hvidbjerg - crwdns2934203:0crwdne2934203:0
    So I was reassembling everything after changing the battery.
    Now my only step left is to reconnect the display. However by doing so and trying to turn it on the screen doesn't work... I feel the haptics, but the display is no longer responsive. Please help.
    Paolo Cunanan - crwdns2934203:0crwdne2934203:0
  16. Google Pixel 5 Motherboard Replacement, Screen information: crwdns2935265:016crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • The back of the Pixel's screen is very fragile. Even a small scratch or dent can damage the screen.
    • To prevent damaging your screen or replacement screen:
    • When handling your screen, grip it by its edges.
    • When placing the screen on your work area, make sure nothing is touching the bottom of the screen. Consider placing it on a soft, lint-free cloth.
  17. Google Pixel 5 Motherboard Replacement, Remove the screen: crwdns2935265:017crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Google Pixel 5 Motherboard Replacement, Remove the screen: crwdns2935265:017crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Remove the screen.
    • Use tweezers to pick off the remaining adhesive on the case.
    • If you use isopropyl alcohol to clean the adhesive off the display, be sure to not let it splash onto any unintended components, as this can weaken their adhesive bond.
    • If you replaced the screen, check the screen's front-facing camera hole and remove any protective liners covering it.
    • If your replacement screen's display cable is held down by tape, remove the tape before installation.
    • If you are using a custom-cut adhesive, follow this guide to correctly apply new screen adhesive.
    • If you are using Tesa tape to reattach the screen, follow this guide.
    • During the boot-up process after reassembly, the screen will go through a calibration sequence. Do not touch the screen during this process, as it could result in improper touch calibration and create touch issues.
    Where from we can buy the screen. Thanks
    Ajay Sharma - crwdns2934203:0crwdne2934203:0
    After reconnecting the screen, is it necessary to remove a screen protector (if installed) for the a proper screen calibration?
    Maxx - crwdns2934203:0crwdne2934203:0
    Yes. Remove the screen protector when installing the screen.
    Marcel McKenzie -
    Remaining adhesive - very little actually pulled up in strips, most had to be gently scraped up. The 90% alcohol was a must to help soften the adhesive that remained. I did not get all of it off.
    The custom cut adhesive guide was very helpful. I did use the iOpener to heat up the edges after I installed the screen to help create the best seal. I believe this also helped deal with the old adhesive I hadn't been able to remove and allowed for a secure, tight fit of my screen to the frame.
    The screen is great and the instructions were mostly clear. However, I missed the part in the instructions that said "If you replaced the screen, check the screen's front-facing camera hole and remove any protective liners covering it.". I only just now noticed that.. so maybe make it bold or something?
    kevin - crwdns2934203:0crwdne2934203:0
  18. Google Pixel 5 Motherboard Replacement, Remove the graphite tape: crwdns2935265:018crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Google Pixel 5 Motherboard Replacement, Remove the graphite tape: crwdns2935265:018crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Google Pixel 5 Motherboard Replacement, Remove the graphite tape: crwdns2935265:018crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Use tweezers to lift up the graphite tape until you are able to grip it with your fingers.
    • Take care not to puncture or bend the battery with your tool—a punctured or bent battery may leak dangerous chemicals or cause a thermal event.
    • Peel off the graphite tape.
    On reassembly, I missed the graphite tape installation. Will this be an issue?
    Gene Harriman - crwdns2934203:0crwdne2934203:0
    I believe graphite tape is used for heat dissipation to help keep the phone cool and not overheat so I would say it's an important component. If you can reinstall then do as heat will affect the operation of the device and impact the battery and internal components.
    Marcel McKenzie -
    Luckily the kit came with graphite tape replacement as I accidentally tore through mine when using the sharp tweezers. Here I recommend using the crocodile tweezers as these aren't as sharp and have a bigger surface area to grip.
    Marcel McKenzie - crwdns2934203:0crwdne2934203:0
    If you're dumb like me you won't find the crocodile tweezers until you look under the tools tray. I slid my tray out of its box right onto the work surface, so I never noticed the tweezers underneath.
  19. Google Pixel 5 Motherboard Replacement: crwdns2935265:019crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Google Pixel 5 Motherboard Replacement: crwdns2935265:019crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Use tweezers to peel off the graphite pad covering the charging plate cover.
    • If you are able to keep the graphite pad in good condition, you may reapply it during reassembly.
    Would have been much more helpful to start off by saying to be careful removing this piece so you can reuse.
    Also would have been helpful to say that the kit comes with a new one, so don't worry about saving it.
    lupa - crwdns2934203:0crwdne2934203:0
    I found the sharp tweezers accidentally cut through the graphite tape and graphite pad. Use the crododile tweezers instead of the pointed ones to avoid ripping the tape.
    To clarify what lupa said: the kit does in fact come with a new graphite pad for the charging plate cover. It took me a while to find it, finally found it underneath my parts tray on the table somehow so it may slide around inside the shipping box.
    I forgot to put back the graphite thermal pad when reassembling it. Now it is all glued back together and it is working like a charm. Should I worry? 🤔
    Ivan Penkov - crwdns2934203:0crwdne2934203:0
  20. Google Pixel 5 Motherboard Replacement, Remove the charging plate cover: crwdns2935265:020crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    Magnetic Project Mat
    $17.96
    • Use a T3 Torx driver to remove the two 4.6 mm-long screws securing the charging plate cover to the midframe.
  21. Google Pixel 5 Motherboard Replacement: crwdns2935265:021crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Google Pixel 5 Motherboard Replacement: crwdns2935265:021crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Use tweezers to remove the charging plate cover.
    Using the repair part tray to hold stuff that's needed later worked well for me
  22. Google Pixel 5 Motherboard Replacement: crwdns2935265:022crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Use a T3 Torx driver to remove the eight 4.6 mm-long screws securing the midframe.
  23. Google Pixel 5 Motherboard Replacement, Remove the midframe: crwdns2935265:023crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Google Pixel 5 Motherboard Replacement, Remove the midframe: crwdns2935265:023crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Google Pixel 5 Motherboard Replacement, Remove the midframe: crwdns2935265:023crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Use tweezers to lift up the right side of the midframe.
    • Remove the midframe.
    • The spacer at the top of the phone is likely to fall out when you remove the midframe. Remember to save this spacer for reassembly. See pictures in the motherboard replacement guide.
    Removing the midframe may cause a metal-foam spacer above the light sensor to pop out. After placing in the midframe on re-assembly, you can use the tweezers to squeeze the spacer back in between the midframe and the metal divider near the top of the phone.
    Dumpy Sheep - crwdns2934203:0crwdne2934203:0
    There is a picture of this spacer at https://www.ifixit.com/Guide/Google+Pixe.... To replace it, first replace the midframe. Then, before screwing the midframe back down, use the tweezers to pinch the space together, compressing the foam in the middle, and slide it into place.
    soren - crwdns2934203:0crwdne2934203:0
    In step 21 (and step 23) the photo showing the spacer shows the cover over the rear camera and apparently the camera itself removed. But this is not required and nor is it instructed in this guide. Confusing for photo to not match what I'm looking at.
    Gregg Lee - crwdns2934203:0crwdne2934203:0
    FYI My model Pixel 5 SKU: GA01316-UK does not have a spacer.
    I was very careful and looking specifically for this when removing the screen however it is just an empty cavity with nothing there. I guess it differs based on different PIxel 5 models?
    Marcel McKenzie -
  24. Google Pixel 5 Motherboard Replacement, Disconnect the battery: crwdns2935265:024crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Google Pixel 5 Motherboard Replacement, Disconnect the battery: crwdns2935265:024crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Use the pointed end of the spudger to pry the battery connector straight up and disconnect it from the motherboard.
  25. Google Pixel 5 Motherboard Replacement, Remove the shouldered screw: crwdns2935265:025crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Use a T3 Torx driver to remove the 4.1 mm shouldered screw.
  26. Google Pixel 5 Motherboard Replacement, Disconnect the rear cameras: crwdns2935265:026crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Google Pixel 5 Motherboard Replacement, Disconnect the rear cameras: crwdns2935265:026crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Google Pixel 5 Motherboard Replacement, Disconnect the rear cameras: crwdns2935265:026crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Use the spudger to disconnect the two rear camera press connectors from the motherboard.
    • Use your finger to hold down the rear camera assembly and prevent bending the motherboard.
  27. Google Pixel 5 Motherboard Replacement, Remove the rear cameras: crwdns2935265:027crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Google Pixel 5 Motherboard Replacement, Remove the rear cameras: crwdns2935265:027crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Google Pixel 5 Motherboard Replacement, Remove the rear cameras: crwdns2935265:027crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Use tweezers to lift up on the rear camera assembly to remove it from its housing.
    • If your replacement camera module has a plastic spacer, be sure to remove it before you install the module.
    • Make sure the lens surface is smudge and dust free before you install the camera assembly.
  28. Google Pixel 5 Motherboard Replacement, Remove adhesive pull tabs: crwdns2935265:028crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Google Pixel 5 Motherboard Replacement, Remove adhesive pull tabs: crwdns2935265:028crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Google Pixel 5 Motherboard Replacement, Remove adhesive pull tabs: crwdns2935265:028crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Use blunt nose tweezers to grip the black adhesive pull tab located on the top right edge of the battery. Lift the pull tab with the tweezers until you are able to grip it with your fingers.
    • Pull on the pull tab with a slow, steady force at a shallow angle to prevent the pull tab from snapping in the middle.
    • Try to keep the adhesive strips flat and unwrinkled during this procedure; twisted or wrinkled strips will stick together and break instead of pulling out cleanly.
    • If the adhesive becomes hard to pull, you can roll it around a spudger and continue pulling.
    • If the pull tab breaks prematurely, use tweezers to retrieve the remaining length of adhesive and continue pulling.
    • If you are unable to retrieve it, move on to the next step.
    I found what helped the best, was after grabbing the tab wrapping it around the tip of the spudger, and rolling slowly away, holding it as close as possible to where the tab was. Before I did that since you're pulling so much at once it easily snapped in half. Luckily I could grab a tiny bit of the strip. After wrapping it around the spudger, it no longer broke. The whole strip came off in one piece. Both pieces are complete horizontal pieces and are along the entire width of the battery, from the side you're pulling to the other side of the battery. There's quite a bit there especially since it stretches during this process. You'll feel it suddenly basically give away. ******
    It is very much like the adhesive strips you use to hang items on the wall. When you're removing the hook, you pull at a low angle on that tab and it stretches until it comes off clean. Pull too high and you peel paint. A similar process here, keep it low and roll it slowly on the spudger. It will come away cleanly.
    Jesse - crwdns2934203:0crwdne2934203:0
    Pull very slowly. Once there is enough out to grip with fingers use your fingers . The tweezers concentrated the load in a small contact area with hard edges. more likely to start a tear. Easier to control pull as well. As the tab comes out keep regripping closer to the battery. That takes the load off the part of tab that has already been stretched thin and weakened.
    "Shallow" is not a very helpful descriptor for the angle, nor do any of the pictures demonstrate what they meant.
    Instead of pulling straight up, try pulling as parallel to your work surface as possible. It's like removing Command hooks.
    As expected the pull tabs snapped.
    This tab also snapped on me. I was pulling up not out. I agree that pulling almost parallel to the work surface is best. Slow and steady.
    Snapped on me too. Worth saying that
    1. It's not worth going all out for a "Shallow" angle if the tape will get caught on any other fixings on the phone. Keep it shallow within reason
    2. Take your time! Pull slowly - when you've pulled a little bit, hold and regrab the tape closer to the battery with your other hand and pull slowly again. Keep doing this rather than doing one long continuous pull
    It is worth getting this right, using the slow-wrap-around-the-spudger approach, because if you get the whole strip out in this step and step 24, the battery lifts right out in step 27. Go veeery slowly, roll around the spudger tip so that the adhesive rolls under the spudger instead of over (to keep the shallow angle), and keep as parallel to the work surface as possible without rubbing hard on the edge of the phone. You'll hear squeaking sounds and that's OK. If you see the tape getting narrow it may be about to snap -- roll the spudger up close and pull gently to keep going.
    Do the roll it on the spudger thing. My strip was coming very slowly, so I put the hairdryer to it while pulling and the strip immediately snapped, so for this step heat does not help So I took some drugstore 91% isopropyl and used one of my kids little paint brushes, dipped the bush in so it was about to drip then pushed that under the battery, quite a few times. I eventually go the battery out, although it's probably ruined (but I was putting in a new one anyway).
    donpb - crwdns2934203:0crwdne2934203:0
  29. Google Pixel 5 Motherboard Replacement: crwdns2935265:029crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Google Pixel 5 Motherboard Replacement: crwdns2935265:029crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Google Pixel 5 Motherboard Replacement: crwdns2935265:029crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Use the same process to remove the pull tab located at the bottom left edge of the battery.
    • If this tab breaks prematurely and you are not able to retrieve it with tweezers, move on to the next step.
    I had to fish around for this tab. It was not as easy to find as the last.
    Same. At first I thought it was a different compenent alltogether however that didn't help as it snapped when pulling anyway!
    Marcel McKenzie -
    Both tabs are hard to find. The first one snapped, this one I made sure to grip as close to the battery after I successfully pulled a small piece and by not pulling up but pulling away from the battery toward the edge of the frame. Because the tape stretches so much, I probably stretched and then grabbed the tape close to the battery 5 or 6 times. It eventually came off without breaking.
    Same comment as on step 23: if you get this right, step 27 is free.
  30. Google Pixel 5 Motherboard Replacement, Loosen the adhesive: crwdns2935265:030crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Google Pixel 5 Motherboard Replacement, Loosen the adhesive: crwdns2935265:030crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • If any of the adhesive strips broke off underneath the battery and could not be retrieved, apply a few drops of high concentration (over 90%) isopropyl alcohol into the opening of the affected tab.
    This is a frustrating step since I bought the kit thinking I had everything I needed. I don't keep 90% isopropyl alcohol on hand (71% is effective as a disinfectant, where as 90% is not).
    For those who also do not have 90% on hand, I was able to just gently lift the battery out without the alcohol and the graphite under the battery remained in perfect condition and did not tear at all.
    Agree. The fix kit supplies only 70% IPA so I had to buy some on Amazon. The pulltabs snapped in the previous step and the dropper provided in the kit is rather "imprecise". Kept prying at the edges got it off for me but so far this is the hardest step as it's hard to know how much force to remove the battery and risk damaging another component.
    Marcel McKenzie -
  31. Google Pixel 5 Motherboard Replacement: crwdns2935265:031crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Google Pixel 5 Motherboard Replacement: crwdns2935265:031crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Tilt the phone so that the alcohol flows towards the remaining adhesive.
    • Wait one minute for the adhesive to soften, then proceed to the next step.
    If you're like me, I ended up having a random piece fall out of the phone that I had no idea where it went. After searching I gave up and left it out. However, after looking at the second photo in this step, the one with it tilted fully towards the camera, I found it. Between the index and thumb in the photo, directly in the center of the phone is a thick gray bar. Just to the right of it is a loose piece that might fall out for you. It looks like two thin pieces of metal that sandwich some insulation. You will also notice two tiny tabs bent at an angle on each end only on one side. If that piece does fall out, that's where it goes. Just match the tab angles with this photo and location. I, unfortunately, don't have that piece anymore and am not willing to break through that display adhesive to put it back anyways.
    FYI My model Pixel 5 SKU: GA01316-UK does not have this spacer at all.
    Marcel McKenzie -
  32. Google Pixel 5 Motherboard Replacement, Remove the battery: crwdns2935265:032crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Google Pixel 5 Motherboard Replacement, Remove the battery: crwdns2935265:032crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    Plastic Cards
    $2.99
    • Insert an opening pick into the gap long the left side of the battery.
    • Use the opening pick to slice the remaining adhesive at the top and bottom of the battery.
    • Avoid scraping the two flex cables under the battery with your opening pick.
    • This may be difficult as the adhesive is strategically located between the cables and the battery tray. A possible solution is to cut a plastic card to fit between the flex cables and battery tray edge.
    • Do not bend the battery.
    • Avoid the earpiece contact pins located near the top left corner of the battery as you pry up with your opening pick.
    • If you cannot pry the battery up, add a few more drops of isopropyl alcohol to the adhesive. A plastic card can also be helpful during this process.
    This was, by far, the hardest step for me. Pay very much attention to that link "strategically located". It tells you exactly where the toughest adhesive is. I had to use a lot of isopropyl alcohol, a lot of waiting for the adhesive to dissolve, and the thin spudger on only the top and bottom of the battery to pry it out. I did not use the pick.
    I don't think it's worth applying adhesive when putting the battery back in.
    Absolutely agree. More isopropyl alcohol, a lot of waiting is the key.
    Artem Chepurnyi - crwdns2934203:0crwdne2934203:0
    I would recommend applying a little adhesive to the new battery. I didn't apply any and my battery rattles a bit. I wish I had put a small amount of tape in just to keep it in place.
    Elliot - crwdns2934203:0crwdne2934203:0
    Watch how far you push in. The thin cable for the finger print sensor is at the back I snapped it pushing into the glue.
    Kevin McDonagh - crwdns2934203:0crwdne2934203:0
    Try to not use alcohol. Or at least use just a tiny bit without tilting the phone too much. While it worked for me, it leaked into my primary camera lens. Wide camera is okay fortunately, so I can still take photos for important things, and I hope in the next few days alcohol will evaporate. I also tried to put the iOpener on the camera to increase the pressure and move the alcohol to the edges. It kinda worked but photos are still a no go, too blurred
    Emanuele Luciani - crwdns2934203:0crwdne2934203:0
    Just to update who may read this, alcohol fully evaporated after 1 day. I've been very lucky 😅!
    Emanuele Luciani -
    Be aware that if the battery has already been replaced, the aftermarket battery may be adhered over the fingerprint reader cable. I forgot that I already replaced the battery so I was expecting all the adhesive to be to be above the cable, so I pried on the battery too hard and the adhesive ripped the cable. Using more alcohol seems to have been the right move.
    Stephen Smith - crwdns2934203:0crwdne2934203:0
    For me, trying to pull on the adhesive pull tabs went nowhere - they broke off immediately, so essentially the full adhesive strips where still in place behind the battery. Here's what did work:
    I used lots of isopropyl alcohol, dropping in where both of the pull tabs are, and tilting the phone in the appropriate direction to allow the alcohol to flow down the length of the each strip. I did this several times -- several drops of alcohol, tilt, wait, repeat.
    Next, I stuck the blue pick in where the diagram shows to, and got a little bit of leverage. The battery was still not budging at this point, but I left the pick wedged in there and walked away for an hour. When I came back, the battery had lifted up thanks to the weakened adhesive and pressure from the pick. All I had to do was lift the battery out the rest of the way, it came without a struggle.
    Dane B - crwdns2934203:0crwdne2934203:0
  33. Google Pixel 5 Motherboard Replacement: crwdns2935265:033crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Google Pixel 5 Motherboard Replacement: crwdns2935265:033crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Do not reuse the battery if it has been deformed or damaged, as doing so is a potential safety hazard. Replace it with a new battery.
    • Remove your old battery.
    Step 28 battery replacement guide. This is the battery replacement guide - for bad batteries. So why does it say "Do not reuse the battery if it has been deformed or damaged, as doing so is a potential safety hazard. Replace it with a new battery." This must have been copied from a different guide, that does not involve battery replacement.
    Great! You did it and removed the battery... now what? Doing the steps in reverse is easier said than done.
    To put it back together I recommend watching Google Pixel 5 Battery Replacement from 5:46 onwards. This video as an accompaniment in general to this guide I found super helpful as it's an actual video of this repair.
    Seeing someone actually perform this exact repair in realtime is very helpful as well as some techniques not mentioned in this guide.
    I performed a screen and battery replacement with the help of this video so I really recommend watching it.
    Could be because these steps are used in other repairs where the battery is still fine?
    Bubba Mustafa -
    The youtube link is helpful - thank you! Frustrating that the guide doesn't go through the reverse steps more explicitly, especially considering the adhesives need to be relaid.
    With these adhesives that come as part of the kit, make sure to keep the blue coverings face-up, then press all over before attempting to pull the blue coverings. This is especially fiddly when laying the final adhesive for the screen. Whilst pulling off the blue covering here, I went especially slowly and followed with the spudger to keep the adhesive down if it was coming up with the blue covering. Note: it's worth placing the adhesive before cliping in the screen connector unless you want to test the screen first (as per the youtube vid)
    There are also two small adhesive plastic "spacer strips" at the top and bottom of the battery that should be peeled off and installed on the replacement battery, they help hold the battery in the center of the compartment. the bottom one has a "D" cross-section to it while the top is flat and more like a rub strip. They did not come on the replacement battery and aren't mentioned anywhere.
    John Tremper - crwdns2934203:0crwdne2934203:0
    PSA: When reconnection the screen (the little lego bracket) be freaking careful. I've connected brackets like these multiple times on other devices but here these pins are so f fragile. I bend the left top pins (3 of them) without noticing and was freaking out if I bricked my phone.
    Fortunately, I could bend them back but I was in a lot of pain till I reassembled it.
    Luke - crwdns2934203:0crwdne2934203:0
  34. Google Pixel 5 Motherboard Replacement, Disconnect the press connectors: crwdns2935265:034crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Google Pixel 5 Motherboard Replacement, Disconnect the press connectors: crwdns2935265:034crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Google Pixel 5 Motherboard Replacement, Disconnect the press connectors: crwdns2935265:034crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Use the pointed end of a spudger to disconnect the two press connectors by lifting them straight up from the motherboard.
  35. Google Pixel 5 Motherboard Replacement, Remove the motherboard screws: crwdns2935265:035crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Use a T3 Torx driver to remove the two 2.9 mm screws securing the motherboard to the rear case.
  36. Google Pixel 5 Motherboard Replacement, Bend the flex cable out of the way: crwdns2935265:036crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Google Pixel 5 Motherboard Replacement, Bend the flex cable out of the way: crwdns2935265:036crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Google Pixel 5 Motherboard Replacement, Bend the flex cable out of the way: crwdns2935265:036crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Use a spudger to gently fold the flex cable covering the rear case press connector out of the way.
  37. Google Pixel 5 Motherboard Replacement, Disconnect the press connector: crwdns2935265:037crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Google Pixel 5 Motherboard Replacement, Disconnect the press connector: crwdns2935265:037crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Use the spudger to disconnect the rear case press connector.
  38. Google Pixel 5 Motherboard Replacement, Remove the motherboard: crwdns2935265:038crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Google Pixel 5 Motherboard Replacement, Remove the motherboard: crwdns2935265:038crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Insert the pointed end of the spudger into the screw holes near the front facing camera.
    • Push the motherboard down towards the bottom of the phone, then lift up to free the top of the motherboard from the rear case.
  39. Google Pixel 5 Motherboard Replacement: crwdns2935265:039crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Google Pixel 5 Motherboard Replacement: crwdns2935265:039crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Google Pixel 5 Motherboard Replacement: crwdns2935265:039crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Use your fingers to pull the motherboard up towards the top of the rear case to free the charging port.
    • Do not bend or twist the motherboard.
    • If the motherboard gets caught on the case, use a spudger to go around the edges and loosen it up.
    • Remove the motherboard.
  40. Google Pixel 5 Motherboard Replacement: crwdns2935265:040crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Google Pixel 5 Motherboard Replacement: crwdns2935265:040crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • After removing the motherboard, the top spacer will usually fall out. To replace it, reposition the midframe without screwing it down. Grasp the spacer with the tweezers and compress the interior foam to squeeze it into position. Then screw the midframe into place.
    • Grip the spacer by the body and not by the delicate end tabs.
Repair didn’t go as planned? Try some basic troubleshooting, or ask our Answers community for help.
Robert Boyd
crwdns2935283:002/01/21crwdne2935283:0
30.477 crwdns2915208:0crwdne2915208:0
crwdns2935297:094crwdne2935297:0
Good day. Please tell me, what is the size of the vibration motor for the pixel 5? I can't find the type of vibro motor anywhere.
Андрей Тарасенко - crwdns2934203:0crwdne2934203:0
Mr. Boyd, where exactly is the proximity sensor inside the Pixel 5 phone?
J. Goodenough - crwdns2934203:0crwdne2934203:0
Any idea on model number for power IC in pixel 5? The technician is saying its Qualcomm PM8996 or PMI 8996 001 Power Management IC. Can somebody please help with my dead pixel 5 please!
Avichal Verma - crwdns2934203:0crwdne2934203:0
Is the pixel 5 motherboard available for purchase?
What about the front camera and or camera module/board.
My cameras are not working and I already replaced the rear cameras to no avail.
Reginald Poyau - crwdns2934203:0crwdne2934203:0
crwdns2936751:024crwdne2936751:0 14
crwdns2936753:07crwdne2936753:0 74
crwdns2936753:030crwdne2936753:0 265
crwdns2942667:0crwdne2942667:0 20,339
