Galaxy S23 Ultra Screen Replacement
  1. Galaxy S23 Ultra Screen Replacement, Safety precautions: crwdns2935265:01crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Let your phone's battery drain below 25% before starting this repair. A charged lithium‑ion battery may catch fire if damaged.
    • Unplug all cables from your phone and completely power it down.
  2. Galaxy S23 Ultra Screen Replacement, Heat the right edge: crwdns2935265:02crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Heat an iOpener and apply it to the right edge of the back cover for two minutes.
    • A hair dryer, heat gun, or hot plate may also be used, but be careful not to overheat the phone—the display and internal battery are susceptible to heat damage.
  3. Galaxy S23 Ultra Screen Replacement, Adhesive information: crwdns2935265:03crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Galaxy S23 Ultra Screen Replacement, Adhesive information: crwdns2935265:03crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • While you wait for the adhesive to soften, note the following:
    • There's adhesive securing the back cover around the perimeter of the frame.
    • The adhesive is strongest in the bottom right and top left corners.
  4. Galaxy S23 Ultra Screen Replacement, Insert an opening pick: crwdns2935265:04crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Galaxy S23 Ultra Screen Replacement, Insert an opening pick: crwdns2935265:04crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Galaxy S23 Ultra Screen Replacement, Insert an opening pick: crwdns2935265:04crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Apply a suction handle to the back cover, as close to the center of the right edge as possible.
    • Pull up on the suction handle with strong, steady force to create a gap between the cover and the frame.
    • If you have trouble creating a gap, apply more heat to further soften the adhesive. Follow the iOpener instructions to avoid overheating.
    • Insert an opening pick into the gap.
  5. Galaxy S23 Ultra Screen Replacement, Separate the right adhesive: crwdns2935265:05crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Galaxy S23 Ultra Screen Replacement, Separate the right adhesive: crwdns2935265:05crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Galaxy S23 Ultra Screen Replacement, Separate the right adhesive: crwdns2935265:05crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Slide the pick back and forth along the right edge to separate the adhesive.
    • Leave the pick inserted near the bottom right corner to prevent the adhesive from resealing.
  6. Galaxy S23 Ultra Screen Replacement, Heat the bottom edge: crwdns2935265:06crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Apply a heated iOpener to the bottom edge of the back cover for two minutes.
  7. Galaxy S23 Ultra Screen Replacement, Separate the corner adhesive: crwdns2935265:07crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Galaxy S23 Ultra Screen Replacement, Separate the corner adhesive: crwdns2935265:07crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Galaxy S23 Ultra Screen Replacement, Separate the corner adhesive: crwdns2935265:07crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Insert a second opening pick at the bottom right corner.
    • Angle the pick upward to match the curved edge and rotate it around the bottom right corner.
    • Be careful while working around the corners, as the glass is very fragile here. Work slowly to avoid cracking the glass.
  8. Galaxy S23 Ultra Screen Replacement, Separate the bottom adhesive: crwdns2935265:08crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Galaxy S23 Ultra Screen Replacement, Separate the bottom adhesive: crwdns2935265:08crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Slide your opening pick to the bottom left corner to separate the adhesive.
    • Leave the pick in the bottom left corner to prevent the adhesive from resealing.
  9. Galaxy S23 Ultra Screen Replacement, Heat the left edge: crwdns2935265:09crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Apply a heated iOpener to the left edge of the back cover for two minutes.
  10. Galaxy S23 Ultra Screen Replacement, Separate the corner adhesive: crwdns2935265:010crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Galaxy S23 Ultra Screen Replacement, Separate the corner adhesive: crwdns2935265:010crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Galaxy S23 Ultra Screen Replacement, Separate the corner adhesive: crwdns2935265:010crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Insert a third opening pick at the bottom left corner.
    • Angle the pick upward to match the curved edge and rotate it around the bottom left corner.
  11. Galaxy S23 Ultra Screen Replacement, Separate the left adhesive: crwdns2935265:011crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Galaxy S23 Ultra Screen Replacement, Separate the left adhesive: crwdns2935265:011crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Galaxy S23 Ultra Screen Replacement, Separate the left adhesive: crwdns2935265:011crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Slide your opening pick along the left edge to separate the adhesive, stopping when you reach the power button.
    • Only insert the pick up to 5 mm, as you may damage the antenna flex cable or the power button cable.
    • Leave the pick in the left edge to prevent the adhesive from resealing.
  12. Galaxy S23 Ultra Screen Replacement, Heat the top edge: crwdns2935265:012crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Heat an iOpener and apply it to the top edge of the back cover for two minutes.
  13. Galaxy S23 Ultra Screen Replacement, Separate the corner adhesive: crwdns2935265:013crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Galaxy S23 Ultra Screen Replacement, Separate the corner adhesive: crwdns2935265:013crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Galaxy S23 Ultra Screen Replacement, Separate the corner adhesive: crwdns2935265:013crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Insert an opening pick in the gap at the top right edge.
    • Angle the pick upward to match the curved edge and rotate it around the top right corner.
  14. Galaxy S23 Ultra Screen Replacement, Separate the top adhesive: crwdns2935265:014crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Galaxy S23 Ultra Screen Replacement, Separate the top adhesive: crwdns2935265:014crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Slide the pick to the top left corner to separate the adhesive.
    • Only insert the pick up to 4 mm, as you may damage the cameras or sensors.
    • Leave the pick in to prevent the adhesive from resealing.
  15. Galaxy S23 Ultra Screen Replacement, Separate the corner adhesive: crwdns2935265:015crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Galaxy S23 Ultra Screen Replacement, Separate the corner adhesive: crwdns2935265:015crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Insert an opening pick in the gap at the top left edge.
    • Only insert the pick up to 4 mm, as you may damage the cameras.
    • Angle the pick upward to match the curved edge and rotate it around the top left corner.
  16. Galaxy S23 Ultra Screen Replacement, Separate the remaining adhesive: crwdns2935265:016crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Galaxy S23 Ultra Screen Replacement, Separate the remaining adhesive: crwdns2935265:016crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Slide the pick toward the bottom camera to separate through the remaining adhesive, stopping before you reach the power button.
  17. Galaxy S23 Ultra Screen Replacement, Remove the back cover: crwdns2935265:017crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Galaxy S23 Ultra Screen Replacement, Remove the back cover: crwdns2935265:017crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Galaxy S23 Ultra Screen Replacement, Remove the back cover: crwdns2935265:017crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Grab and remove the back cover.
    • If your cover is still sticking to the frame, slide an opening pick around the perimeter until the cover completely separates.
    • During reassembly:
    • This is a good point to power on your phone and test all functions before sealing it up. Be sure to power your phone back down completely before you continue working.
    • Remove any adhesive chunks with a pair of tweezers or your fingers. Apply heat if you're having trouble separating the adhesive.
    • If you're using custom-cut adhesives, follow this guide.
    • If you're using double-sided tape, follow this guide.
  18. Galaxy S23 Ultra Screen Replacement, Disconnect the NFC antenna and charging coil: crwdns2935265:018crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Galaxy S23 Ultra Screen Replacement, Disconnect the NFC antenna and charging coil: crwdns2935265:018crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Galaxy S23 Ultra Screen Replacement, Disconnect the NFC antenna and charging coil: crwdns2935265:018crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Use the pointed end of a spudger to pry up and disconnect the NFC antenna press connector from the motherboard.
    • Repeat for the wireless charging coil press connector.
    • To re-attach press connectors, carefully align and press down on one side until it clicks into place, then repeat on the other side. Don't press down on the middle. If the connector is misaligned, the pins can bend and cause permanent damage.
  19. Galaxy S23 Ultra Screen Replacement, Separate the coil adhesive: crwdns2935265:019crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Galaxy S23 Ultra Screen Replacement, Separate the coil adhesive: crwdns2935265:019crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Galaxy S23 Ultra Screen Replacement, Separate the coil adhesive: crwdns2935265:019crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • The wireless charging coil is lightly adhered to the battery.
    • Insert an opening pick between the right edge of the wireless charging coil and the battery.
    • Slide the pick along the right edge to separate the adhesive.
  20. Galaxy S23 Ultra Screen Replacement: crwdns2935265:020crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Galaxy S23 Ultra Screen Replacement: crwdns2935265:020crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Insert an opening pick between the top edge of the wireless charging coil and the frame.
    • Slide the pick toward the right edge to separate the remaining adhesive.
  21. Galaxy S23 Ultra Screen Replacement, Unfasten the NFC antenna and charging coil: crwdns2935265:021crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Use a Phillips screwdriver to remove the five 3.5 mm-long screws securing the NFC antenna and charging coil.
  22. Galaxy S23 Ultra Screen Replacement, Unfasten the loudspeaker: crwdns2935265:022crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Use a Phillips screwdriver to remove the six 3.5 mm screws securing the loudspeaker.
  23. Galaxy S23 Ultra Screen Replacement, Unclip the loudspeaker: crwdns2935265:023crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Galaxy S23 Ultra Screen Replacement, Unclip the loudspeaker: crwdns2935265:023crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Insert the pointed end of your spudger between the upper right corner of the loudspeaker and the frame.
    • Pry up to unclip the loudspeaker from the frame.
    • Don't pry against the battery. Use protrusions in the frame for leverage.
    • During reassembly, press around the perimeter of the loudspeaker to clip it to the frame.
  24. Galaxy S23 Ultra Screen Replacement, Remove the charging coil and loudspeaker assembly: crwdns2935265:024crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Galaxy S23 Ultra Screen Replacement, Remove the charging coil and loudspeaker assembly: crwdns2935265:024crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Galaxy S23 Ultra Screen Replacement, Remove the charging coil and loudspeaker assembly: crwdns2935265:024crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Grab and remove the NFC, wireless charging coil, and loudspeaker from the frame.
  25. Galaxy S23 Ultra Screen Replacement, Disconnect the battery: crwdns2935265:025crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Galaxy S23 Ultra Screen Replacement, Disconnect the battery: crwdns2935265:025crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Use your spudger to pry up and disconnect the battery press connector.
  26. Galaxy S23 Ultra Screen Replacement, Disconnect the interconnect cables: crwdns2935265:026crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Galaxy S23 Ultra Screen Replacement, Disconnect the interconnect cables: crwdns2935265:026crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Galaxy S23 Ultra Screen Replacement, Disconnect the interconnect cables: crwdns2935265:026crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Use your spudger to pry up and disconnect the secondary interconnect cable press connector from the motherboard.
    • Repeat for the primary interconnect cable.
  27. Galaxy S23 Ultra Screen Replacement: crwdns2935265:027crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Galaxy S23 Ultra Screen Replacement: crwdns2935265:027crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Galaxy S23 Ultra Screen Replacement: crwdns2935265:027crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Use your spudger to pry up and disconnect the secondary interconnect cable press connector from the charging board.
  28. Galaxy S23 Ultra Screen Replacement, Remove the interconnect cables: crwdns2935265:028crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Galaxy S23 Ultra Screen Replacement, Remove the interconnect cables: crwdns2935265:028crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Grab and remove the interconnect cables from the frame.
  29. Galaxy S23 Ultra Screen Replacement, Disconnect the earpiece speaker: crwdns2935265:029crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Galaxy S23 Ultra Screen Replacement, Disconnect the earpiece speaker: crwdns2935265:029crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Use the point of your spudger to pry up and disconnect the earpiece speaker press connector.
  30. Galaxy S23 Ultra Screen Replacement, Unfasten the motherboard cover: crwdns2935265:030crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Use a Phillips screwdriver to remove the five 3.5 mm-long screws securing the motherboard cover.
  31. Galaxy S23 Ultra Screen Replacement, Remove the motherboard cover: crwdns2935265:031crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Galaxy S23 Ultra Screen Replacement, Remove the motherboard cover: crwdns2935265:031crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Galaxy S23 Ultra Screen Replacement, Remove the motherboard cover: crwdns2935265:031crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Insert the point of your spudger between the bottom right corner of the motherboard cover and the frame.
    • Pry up on the cover to unclip it from the frame.
    • Remove the motherboard cover.
    • During reassembly, press down on the cover to secure its clips to the frame.
  32. Galaxy S23 Ultra Screen Replacement, Disconnect the front-facing camera: crwdns2935265:032crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Galaxy S23 Ultra Screen Replacement, Disconnect the front-facing camera: crwdns2935265:032crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Use the point of your spudger to pry up and disconnect the front-facing camera press connector.
  33. Galaxy S23 Ultra Screen Replacement, Disconnect the fingerprint reader: crwdns2935265:033crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Galaxy S23 Ultra Screen Replacement, Disconnect the fingerprint reader: crwdns2935265:033crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Use your spudger to pry up and disconnect the fingerprint reader press connector.
  34. Galaxy S23 Ultra Screen Replacement, Disconnect the screen: crwdns2935265:034crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Galaxy S23 Ultra Screen Replacement, Disconnect the screen: crwdns2935265:034crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Use the point of your spudger to pry up and disconnect the screen press connector from the motherboard.
  35. Galaxy S23 Ultra Screen Replacement: crwdns2935265:035crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Galaxy S23 Ultra Screen Replacement: crwdns2935265:035crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Use the point of your spudger to pry up and disconnect the screen press connector from the display cutout near the bottom of the phone.
  36. Galaxy S23 Ultra Screen Replacement, Remove the screen cable: crwdns2935265:036crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Grab and remove the screen cable from the frame.
  37. Galaxy S23 Ultra Screen Replacement, Disconnect the right 5G mmWave antenna: crwdns2935265:037crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Galaxy S23 Ultra Screen Replacement, Disconnect the right 5G mmWave antenna: crwdns2935265:037crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Use the point of your spudger to pry up and disconnect the right 5G mmWave antenna press connector.
  38. Galaxy S23 Ultra Screen Replacement, Disconnect the stylus: crwdns2935265:038crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Galaxy S23 Ultra Screen Replacement, Disconnect the stylus: crwdns2935265:038crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Use the point of your spudger to pry up and disconnect the stylus press connector.
  39. Galaxy S23 Ultra Screen Replacement, Disconnect the left 5G mmWave antenna: crwdns2935265:039crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Galaxy S23 Ultra Screen Replacement, Disconnect the left 5G mmWave antenna: crwdns2935265:039crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Use the point of your spudger to pry up and disconnect the left 5G mmWave antenna press connector.
  40. Galaxy S23 Ultra Screen Replacement, Unfasten the motherboard: crwdns2935265:040crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Use your Phillips screwdriver to remove the single 4 mm-long screw securing the motherboard.
  41. Galaxy S23 Ultra Screen Replacement, Remove the motherboard: crwdns2935265:041crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Galaxy S23 Ultra Screen Replacement, Remove the motherboard: crwdns2935265:041crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Galaxy S23 Ultra Screen Replacement, Remove the motherboard: crwdns2935265:041crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Insert the point of your spudger between the top left of the motherboard and the frame.
    • Pry the motherboard up until you can grab it with your fingers.
    • Grab the motherboard and remove it from the frame.
    • Be careful not to snag any loose cables.
    • During reassembly, make sure the cables are above the motherboard when reinserting it.
  42. Galaxy S23 Ultra Screen Replacement, Put the back cover on: crwdns2935265:042crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Galaxy S23 Ultra Screen Replacement, Put the back cover on: crwdns2935265:042crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Galaxy S23 Ultra Screen Replacement, Put the back cover on: crwdns2935265:042crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Place the back cover back on the frame to protect the battery and your phone's internals from damage.
    • Flip your phone over so the screen is facing up.
  43. Galaxy S23 Ultra Screen Replacement, Heat the screen's top edge: crwdns2935265:043crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Use a hair dryer or heat gun to heat the top edge of the screen just until it's hot to the touch.
    • Be careful not to heat the phone any hotter than this—the battery is susceptible to heat damage.
  44. Galaxy S23 Ultra Screen Replacement: crwdns2935265:044crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • If your screen is badly cracked, lay overlapping strips of packing tape over the glass to protect yourself and make disassembly easier.
    • Make sure there's a smooth area near the top edge big enough for a suction cup to stick to.
  45. Galaxy S23 Ultra Screen Replacement, Apply a suction handle: crwdns2935265:045crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Galaxy S23 Ultra Screen Replacement, Apply a suction handle: crwdns2935265:045crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Apply a suction handle to the center of the screen's top edge, as close to the edge as possible.
  46. Galaxy S23 Ultra Screen Replacement, Tool and safety information: crwdns2935265:046crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Galaxy S23 Ultra Screen Replacement, Tool and safety information: crwdns2935265:046crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Galaxy S23 Ultra Screen Replacement, Tool and safety information: crwdns2935265:046crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    iFlex Opening Tool
    $11.99
    • The gap between the front glass and frame is extremely small. You'll need a thin, rigid tool such as an iFlex to create the initial gap.
    • The display panel and display glass will remove separately—although destructive, this is the best method. The display glass will usually lift away from the strongly-adhered panel first.
    • Take the following safety precautions while removing the front glass during the next few steps:
    • Don't grip the iFlex or similar metal tools by the edges—they're very sharp.
    • The front glass can shatter and throw shards of glass around your workspace. Consider wearing gloves and safety glasses to protect yourself.
  47. Galaxy S23 Ultra Screen Replacement, Insert an iFlex: crwdns2935265:047crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Galaxy S23 Ultra Screen Replacement, Insert an iFlex: crwdns2935265:047crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Galaxy S23 Ultra Screen Replacement, Insert an iFlex: crwdns2935265:047crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Insert the iFlex at a downward angle into the earpiece speaker gap between the top edge of the front glass and frame.
  48. Galaxy S23 Ultra Screen Replacement: crwdns2935265:048crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Galaxy S23 Ultra Screen Replacement: crwdns2935265:048crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Lift the suction handle with strong, steady force and lower the iFlex so it slides under the front glass, between the glass and the display panel. A large portion of the front glass may separate—that's fine. You may see the tip of the iFlex under the glass.
    • The iFlex only needs to be inserted just enough to separate the front glass and create an initial gap. If inserted too far, it may damage the front-facing camera.
  49. Galaxy S23 Ultra Screen Replacement, Replace the iFlex with an opening pick: crwdns2935265:049crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Galaxy S23 Ultra Screen Replacement, Replace the iFlex with an opening pick: crwdns2935265:049crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Galaxy S23 Ultra Screen Replacement, Replace the iFlex with an opening pick: crwdns2935265:049crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Insert the tip of an opening pick under the front glass and remove the iFlex.
  50. Galaxy S23 Ultra Screen Replacement, Separate the front glass: crwdns2935265:050crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Galaxy S23 Ultra Screen Replacement, Separate the front glass: crwdns2935265:050crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Galaxy S23 Ultra Screen Replacement, Separate the front glass: crwdns2935265:050crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Slide the opening pick around the perimeter of the back glass to separate the adhesive securing it to the display panel.
    • If you're having trouble, use a hair dryer or heat gun to heat the edges.
  51. Galaxy S23 Ultra Screen Replacement: crwdns2935265:051crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Galaxy S23 Ultra Screen Replacement: crwdns2935265:051crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Lift and remove the front glass.
  52. Galaxy S23 Ultra Screen Replacement, Separate the display panel: crwdns2935265:052crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Galaxy S23 Ultra Screen Replacement, Separate the display panel: crwdns2935265:052crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Galaxy S23 Ultra Screen Replacement, Separate the display panel: crwdns2935265:052crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Slide an opening pick under the bottom corner of the display panel and lift to separate the adhesive.
    • This adhesive is very strong. If you're having trouble separating it, use a hair dryer or heat gun to heat the display panel and soften the adhesive.
  53. Galaxy S23 Ultra Screen Replacement: crwdns2935265:053crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Galaxy S23 Ultra Screen Replacement: crwdns2935265:053crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Galaxy S23 Ultra Screen Replacement: crwdns2935265:053crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Continue sliding your opening pick under the perimeter of the display panel to separate the remaining adhesive.
  54. Galaxy S23 Ultra Screen Replacement, Remove the display panel: crwdns2935265:054crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Galaxy S23 Ultra Screen Replacement, Remove the display panel: crwdns2935265:054crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Galaxy S23 Ultra Screen Replacement, Remove the display panel: crwdns2935265:054crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Slowly peel up the display panel, making sure you thread the cable near the top left corner through its cutout in the frame.
    • If you're having trouble, go back around the perimeter of the screen with an opening pick and separate any adhesive you may have missed.
  55. Galaxy S23 Ultra Screen Replacement: crwdns2935265:055crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • You're left with the screen panel and front glass.
  56. Galaxy S23 Ultra Screen Replacement, Remove all of the old screen adhesive: crwdns2935265:056crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Galaxy S23 Ultra Screen Replacement, Remove all of the old screen adhesive: crwdns2935265:056crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Galaxy S23 Ultra Screen Replacement, Remove all of the old screen adhesive: crwdns2935265:056crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Check the bottom half of the frame for pieces of thin plastic left behind by the screen.
    • Use a spudger and tweezers to scrape up and remove the plastic.
  57. Galaxy S23 Ultra Screen Replacement: crwdns2935265:057crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Galaxy S23 Ultra Screen Replacement: crwdns2935265:057crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Galaxy S23 Ultra Screen Replacement: crwdns2935265:057crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • In order for your new screen to adhere properly, you'll need to thoroughly remove all of the old screen adhesive and its residue.
    • Use a spudger to scrape up and remove all of the old screen adhesive from the perimeter of the frame.
    • Once all of the old adhesive is removed, use high concentration (>90%) isopropyl alcohol and a microfiber cloth to remove any remaining adhesive residue.
    • Allow the alcohol to dry completely before continuing.
  58. Galaxy S23 Ultra Screen Replacement, Apply the main adhesive: crwdns2935265:058crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Galaxy S23 Ultra Screen Replacement, Apply the main adhesive: crwdns2935265:058crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Before applying the larger piece of replacement adhesive, it's helpful to see how it will be oriented.
    • There's a second, smaller piece of adhesive that'll be applied later on.
    • Hold the adhesive so the clear liner is on the bottom and test-fit it against the frame to find the proper orientation.
  59. Galaxy S23 Ultra Screen Replacement: crwdns2935265:059crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Peel down the top half of the larger, clear liner to expose the adhesive—don't remove the whole liner yet.
  60. Galaxy S23 Ultra Screen Replacement: crwdns2935265:060crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Galaxy S23 Ultra Screen Replacement: crwdns2935265:060crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Galaxy S23 Ultra Screen Replacement: crwdns2935265:060crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Take your time aligning the adhesive with the frame—it's very sticky and can't be moved after it's applied.
    • Keep the larger, clear liner folded towards the bottom of the phone during this step.
    • Carefully place the top edge of the adhesive onto the frame.
    • Once the top edge is aligned and applied, slowly lay the rest of the adhesive onto the frame, peeling the clear liner down and away as you go.
  61. Galaxy S23 Ultra Screen Replacement: crwdns2935265:061crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Galaxy S23 Ultra Screen Replacement: crwdns2935265:061crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Galaxy S23 Ultra Screen Replacement: crwdns2935265:061crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Use your fingers to firmly press the adhesive into place on the frame.
    • Use the flat end of a spudger to further secure the adhesive.
  62. Galaxy S23 Ultra Screen Replacement, Apply the smaller piece of adhesive: crwdns2935265:062crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Galaxy S23 Ultra Screen Replacement, Apply the smaller piece of adhesive: crwdns2935265:062crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Peel off the larger, more rigid clear‑liner on the second piece of adhesive.
    • With the adhesive's remaining liners facing up, carefully lay the adhesive into place along the bottom edge of the frame.
  63. Galaxy S23 Ultra Screen Replacement: crwdns2935265:063crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Galaxy S23 Ultra Screen Replacement: crwdns2935265:063crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Use the point of a spudger to firmly press along the entire piece of adhesive to secure it to the frame.
  64. Galaxy S23 Ultra Screen Replacement, Remove the liners: crwdns2935265:064crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Galaxy S23 Ultra Screen Replacement, Remove the liners: crwdns2935265:064crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Galaxy S23 Ultra Screen Replacement, Remove the liners: crwdns2935265:064crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Remove the two remaining liners (one clear, one green) from the small, bottom‑edge adhesive.
    • If any of the adhesive starts to peel up with the liner, gently lay it back on the frame and use the flat end of a spudger to secure it.
  65. Galaxy S23 Ultra Screen Replacement: crwdns2935265:065crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Galaxy S23 Ultra Screen Replacement: crwdns2935265:065crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Galaxy S23 Ultra Screen Replacement: crwdns2935265:065crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Use the pull tab in the top right corner to peel and remove the remaining liner from the main adhesive.
  66. Galaxy S23 Ultra Screen Replacement, Secure the new screen: crwdns2935265:066crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Galaxy S23 Ultra Screen Replacement, Secure the new screen: crwdns2935265:066crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Galaxy S23 Ultra Screen Replacement, Secure the new screen: crwdns2935265:066crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Carefully check the underside of your replacement screen for any liners or tabs and remove them.
    • Thread the screen cable through its cutout near the top left corner of the frame and lay the screen into place.
    • Press firmly around the perimeter of the screen to secure it.
To reassemble your device, follow these instructions in reverse order starting with this step.
crwdns2935229:05crwdne2935229:0
Spencer Day
crwdns2935283:009/14/22crwdne2935283:0
117,207 crwdns2915208:0crwdne2915208:0
crwdns2935297:0837crwdne2935297:0
Staff
crwdns2931471:0120crwdne2931471:0
crwdns2935297:020,898crwdne2935297:0
where the hell is the screen for purchase, dingus?
JustaRoan - crwdns2934203:0crwdne2934203:0
🤣🤣🤣🤣🤣🤣🤣 Good point. I would not deal with this though. Not worth 250$ +tx for samsung to do it, or trade in on next phone
David Kaleky -
reparieren lohnt sich gar nicht das kaputte Handy kostet sagen wir roundabout 250 dann kostet das kaputte Display mit den kleben und so 300 irgendwas also sagen wir sind wir bei 500 wenn ich jetzt einen referbisch-gerät kaufe kostet das auch an die 500 und ich habe keine Arbeitszeit reingesteckt also ich dachte man würde dabei billiger wegkommen beim Reparieren aber anscheinend nicht
Dennis Witt - crwdns2934203:0crwdne2934203:0
crwdns2936751:024crwdne2936751:0 108
crwdns2936753:07crwdne2936753:0 659
crwdns2936753:030crwdne2936753:0 3,625
crwdns2942667:0crwdne2942667:0 28,356
