Galaxy S20 USB-C Charging Port and Daughterboard Replacement
  1. Galaxy S20 USB-C Charging Port and Daughterboard Replacement, Heat the bottom edge: crwdns2935265:01crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Unplug and power off your phone before you begin.
    • Heat an iOpener and apply it to the back cover's bottom edge for two minutes.
    • A hair dryer, heat gun, or hot plate may also be used, but be careful not to overheat the phone—the display and internal battery are both susceptible to heat damage.
    Found that using the iOpener did not provide enough heat to weaken the adhesive, went with a hairdryer instead. Make sure to never keep the hairdryer still, and apply heat on high for 30 seconds to 1 minute per side did the job for me. iOpener just did not get hot enough
    Phil R - crwdns2934203:0crwdne2934203:0
  2. Galaxy S20 USB-C Charging Port and Daughterboard Replacement, Separate the bottom edge adhesive: crwdns2935265:02crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Galaxy S20 USB-C Charging Port and Daughterboard Replacement, Separate the bottom edge adhesive: crwdns2935265:02crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Galaxy S20 USB-C Charging Port and Daughterboard Replacement, Separate the bottom edge adhesive: crwdns2935265:02crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Apply a suction cup to the back of the phone, as close to the center of the bottom edge as possible.
    • If your display is badly cracked, covering it with a layer of clear packing tape may allow the suction cup to adhere. Alternatively, very strong tape may be used instead of the suction cup. If all else fails, you can superglue the suction cup to the broken screen.
    • Pull on the suction cup with strong, steady force to create a gap between the back cover and the frame.
    • Insert the point of an opening pick into the gap.
    • Due to tight tolerances, this may take multiple attempts of reheating with the iOpener and separating with the suction cup before you get it right.
    • If you are having trouble creating a gap, apply more heat to the edge and try again.
    • Do not apply excessive force with the pick, or you risk cracking the back cover glass.
    I have found it easier to use an iFlex on the camera side to get in enough to get an opening pick in. Then work the pick towards either end slowly and down the ends, making sure it’s warm to the point of being almost to hot to hold. Slow, gentle pressure t open it like a clam ;)
    Stow - crwdns2934203:0crwdne2934203:0
    While pulling on the back glass with the suction cup, I found it helpful to use something like the opener tool to press down on the frame. Made it easy to pull open even with the iOpener.
    Ryan Sammons - crwdns2934203:0crwdne2934203:0
  3. Galaxy S20 USB-C Charging Port and Daughterboard Replacement: crwdns2935265:03crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Galaxy S20 USB-C Charging Port and Daughterboard Replacement: crwdns2935265:03crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Galaxy S20 USB-C Charging Port and Daughterboard Replacement: crwdns2935265:03crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Slide the pick back and forth along the bottom edge to slice through the adhesive.
    • Do not attempt to cut the adhesive near the corners of the phone where the glass is curved or you risk cracking the glass panel.
    • Leave your opening pick in the seam to prevent the adhesive from resealing.
  4. Galaxy S20 USB-C Charging Port and Daughterboard Replacement, Heat the left edge: crwdns2935265:04crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Apply a heated iOpener to the left edge of the back cover for two minutes.
  5. Galaxy S20 USB-C Charging Port and Daughterboard Replacement, Separate the left edge adhesive: crwdns2935265:05crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Galaxy S20 USB-C Charging Port and Daughterboard Replacement, Separate the left edge adhesive: crwdns2935265:05crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Galaxy S20 USB-C Charging Port and Daughterboard Replacement, Separate the left edge adhesive: crwdns2935265:05crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Apply a suction cup to the back of the phone, as close to the center of the left edge as possible.
    • As the glass on this edge is curved, you won't be able to insert this pick very far. As long as the very tip of the pick is underneath the glass's edge, you will be able to proceed.
    • Due to tight tolerances, this may take multiple attempts.
    • You can try also applying a few drops of high concentration (over 90%) isopropyl alcohol into the seam to help loosen the adhesive.
  6. Galaxy S20 USB-C Charging Port and Daughterboard Replacement: crwdns2935265:06crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Galaxy S20 USB-C Charging Port and Daughterboard Replacement: crwdns2935265:06crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Once the pick is underneath the glass's edge, tilt it downward and insert it further to fully separate the back cover's adhesive.
  7. Galaxy S20 USB-C Charging Port and Daughterboard Replacement: crwdns2935265:07crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Galaxy S20 USB-C Charging Port and Daughterboard Replacement: crwdns2935265:07crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Galaxy S20 USB-C Charging Port and Daughterboard Replacement: crwdns2935265:07crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Slide the pick all along the left edge of the phone to separate the back cover's adhesive.
    • Take care when sliding across the ridge in the frame surrounding the volume and power buttons—the cutout in the glass may make it more prone to cracking.
    • Leave your pick under the left edge of the glass near the top left corner to prevent the adhesive from resealing.
  8. Galaxy S20 USB-C Charging Port and Daughterboard Replacement, Heat the right edge: crwdns2935265:08crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Apply a heated iOpener to the right edge of the back cover for two minutes.
  9. Galaxy S20 USB-C Charging Port and Daughterboard Replacement, Separate the right edge adhesive: crwdns2935265:09crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Galaxy S20 USB-C Charging Port and Daughterboard Replacement, Separate the right edge adhesive: crwdns2935265:09crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Galaxy S20 USB-C Charging Port and Daughterboard Replacement, Separate the right edge adhesive: crwdns2935265:09crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Apply a suction cup to the back of the phone, as close to the center of the right edge as possible.
    • Like with the previous edge, you will need to tilt the opening pick downward to fully insert it underneath the back cover.
  10. Galaxy S20 USB-C Charging Port and Daughterboard Replacement: crwdns2935265:010crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Galaxy S20 USB-C Charging Port and Daughterboard Replacement: crwdns2935265:010crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Galaxy S20 USB-C Charging Port and Daughterboard Replacement: crwdns2935265:010crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Slide the pick all along the right edge of the phone to separate the back cover's adhesive.
    • Leave your pick under the right edge of the glass near the top of the device to prevent the adhesive from resealing.
    • As you do this, the back cover may release one or both of the other picks and allow them to fall free. If this occurs, set the pick(s) aside as the bottom edge shouldn't reseal from this point onward.
  11. Galaxy S20 USB-C Charging Port and Daughterboard Replacement, Heat the top edge: crwdns2935265:011crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Apply a heated iOpener to the top edge of the back cover for two minutes.
  12. Galaxy S20 USB-C Charging Port and Daughterboard Replacement, Separate the top edge adhesive: crwdns2935265:012crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Galaxy S20 USB-C Charging Port and Daughterboard Replacement, Separate the top edge adhesive: crwdns2935265:012crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Galaxy S20 USB-C Charging Port and Daughterboard Replacement, Separate the top edge adhesive: crwdns2935265:012crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • The glass near the corners of the back cover is curved and very susceptible to cracking. Be gentle during this step to prevent damaging your back cover.
    • Gradually slide the pick from the right edge of the device around the top right corner.
    • Continue slicing along the top edge all the way to the top left corner to fully separate the back cover adhesive.
    • If the slicing becomes difficult at any point, stop and reapply heat before continuing.
  13. Galaxy S20 USB-C Charging Port and Daughterboard Replacement, Remove the back cover: crwdns2935265:013crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Galaxy S20 USB-C Charging Port and Daughterboard Replacement, Remove the back cover: crwdns2935265:013crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Lift the back cover slowly. Use opening picks to slice any remaining adhesive.
    • Remove the back cover.
    • During reassembly:
    • This is a good point to power on your phone and test all functions before sealing it up. Be sure to power your phone back down completely before you continue working.
    • Remove any adhesive chunks with a pair of tweezers or your fingers. Apply heat if you're having trouble separating the adhesive.
    • If you're using custom-cut adhesives, follow this guide.
    • If you're using double-sided tape, follow this guide.
  14. Galaxy S20 USB-C Charging Port and Daughterboard Replacement, Disconnect the wireless charging coil: crwdns2935265:014crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Galaxy S20 USB-C Charging Port and Daughterboard Replacement, Disconnect the wireless charging coil: crwdns2935265:014crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Use a spudger to pry up and disconnect the wireless charging coil's press connector on the motherboard.
    Since mine didn't have it, I believe the non-Verizon models don't have this connector (it appears the connector is a part of the motherboard bracket). If you don't have this, you can skip to the next step safely.
  15. Galaxy S20 USB-C Charging Port and Daughterboard Replacement, Unfasten the motherboard bracket: crwdns2935265:015crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Galaxy S20 USB-C Charging Port and Daughterboard Replacement, Unfasten the motherboard bracket: crwdns2935265:015crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    Magnetic Project Mat
    $19.95
    • Use a Phillips #00 screwdriver to remove the five 4 mm-long screws securing the motherboard bracket.
  16. Galaxy S20 USB-C Charging Port and Daughterboard Replacement, Unclip the motherboard bracket: crwdns2935265:016crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Galaxy S20 USB-C Charging Port and Daughterboard Replacement, Unclip the motherboard bracket: crwdns2935265:016crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Use a pair of blunt-nose tweezers to gently pull up and unclip the motherboard bracket from the plastic midframe.
    • Do not completely remove the bracket yet, as its still attached to the wireless charging coil.
  17. Galaxy S20 USB-C Charging Port and Daughterboard Replacement, Unfasten the loudspeaker: crwdns2935265:017crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Galaxy S20 USB-C Charging Port and Daughterboard Replacement, Unfasten the loudspeaker: crwdns2935265:017crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Use a Phillips #00 screwdriver to remove the five 4 mm-long screws securing the loudspeaker and lower midframe.
  18. Galaxy S20 USB-C Charging Port and Daughterboard Replacement, Disconnect the loudspeaker: crwdns2935265:018crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Galaxy S20 USB-C Charging Port and Daughterboard Replacement, Disconnect the loudspeaker: crwdns2935265:018crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Insert the point of a spudger into the notch in the top left corner of the midframe and pry up to release the clips holding it in place.
  19. Galaxy S20 USB-C Charging Port and Daughterboard Replacement, Remove the wireless charging coil: crwdns2935265:019crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Galaxy S20 USB-C Charging Port and Daughterboard Replacement, Remove the wireless charging coil: crwdns2935265:019crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Remove the wireless charging coil.
  20. Galaxy S20 USB-C Charging Port and Daughterboard Replacement, Disconnect the battery: crwdns2935265:020crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Galaxy S20 USB-C Charging Port and Daughterboard Replacement, Disconnect the battery: crwdns2935265:020crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Use a spudger to pry up and disconnect the battery's press connector on the motherboard.
  21. Galaxy S20 USB-C Charging Port and Daughterboard Replacement, Disconnect the flex cables: crwdns2935265:021crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Galaxy S20 USB-C Charging Port and Daughterboard Replacement, Disconnect the flex cables: crwdns2935265:021crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Galaxy S20 USB-C Charging Port and Daughterboard Replacement, Disconnect the flex cables: crwdns2935265:021crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Use a spudger to pry up and disconnect the primary and secondary flex cables from the motherboard.
  22. Galaxy S20 USB-C Charging Port and Daughterboard Replacement: crwdns2935265:022crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Galaxy S20 USB-C Charging Port and Daughterboard Replacement: crwdns2935265:022crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Galaxy S20 USB-C Charging Port and Daughterboard Replacement: crwdns2935265:022crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Use a spudger to pry up and disconnect the primary and secondary flex cables from the daughterboard near the bottom of the device.
    • To re-attach press connectors like this one, carefully align and press down on one side until it clicks into place, then repeat on the other side. Do not press down on the middle. If the connector is misaligned, the pins can bend, causing permanent damage.
  23. Galaxy S20 USB-C Charging Port and Daughterboard Replacement, Remove the flex cables: crwdns2935265:023crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Galaxy S20 USB-C Charging Port and Daughterboard Replacement, Remove the flex cables: crwdns2935265:023crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Galaxy S20 USB-C Charging Port and Daughterboard Replacement, Remove the flex cables: crwdns2935265:023crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Remove the primary and secondary flex cables.
    • Set the cables aside. You'll reuse them during reassembly.
  24. Galaxy S20 USB-C Charging Port and Daughterboard Replacement, Unfasten the daughterboard: crwdns2935265:024crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Galaxy S20 USB-C Charging Port and Daughterboard Replacement, Unfasten the daughterboard: crwdns2935265:024crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Use a Phillips #00 screwdriver to remove the three 3.4 mm-long screws securing the USB-C port and daughterboard.
  25. Galaxy S20 USB-C Charging Port and Daughterboard Replacement, Remove the daughterboard: crwdns2935265:025crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Galaxy S20 USB-C Charging Port and Daughterboard Replacement, Remove the daughterboard: crwdns2935265:025crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Galaxy S20 USB-C Charging Port and Daughterboard Replacement, Remove the daughterboard: crwdns2935265:025crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Insert the pointed end of a spudger under the left edge of the daughterboard and pry up to release it from its recess.
    • Use a pair of tweezers to pull the daughterboard up and away from the bottom of the device and remove it.
crwdns2935229:05crwdne2935229:0
Alex Diaz-Kokaisl
crwdns2935283:001/16/22crwdne2935283:0
169,220 crwdns2915208:0crwdne2915208:0
crwdns2935297:0769crwdne2935297:0
Staff
crwdns2931471:0119crwdne2931471:0
crwdns2935297:021,541crwdne2935297:0
Does this charging port work for the s20 Ultra as well?
Daniel Henry - crwdns2934203:0crwdne2934203:0
crwdns2936751:024crwdne2936751:0 13
crwdns2936753:07crwdne2936753:0 66
crwdns2936753:030crwdne2936753:0 275
crwdns2942667:0crwdne2942667:0 16,207
