Fairphone 3 Speaker Module Replacement
Adriana Zwink
crwdns2944107:0crwdnd2944107:0Adriana Zwinkcrwdnd2944107:0crwdnd2944107:0crwdnd2944107:03crwdnd2944107:0crwdne2944107:0
crwdns2944111:0Ndz 20, 2022crwdne2944111:0
10 - 20 crwdns2931279:0crwdne2931279:0
crwdns2937799:0crwdne2937799:0
crwdns2942287:0crwdne2942287:0
Use this guide to replace the speaker module in your Fairphone 3.
crwdns2944105:0crwdne2944105:0
  1. Fairphone 3 Speaker Module Replacement, Back Cover: crwdns2935265:01crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Fairphone 3 Speaker Module Replacement, Back Cover: crwdns2935265:01crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Power off your phone before beginning disassembly.
    • Insert a thumbnail, or a prying tool like a spudger, into the notch at the bottom right of the back cover.
    • Pry the back cover up to start separating its plastic clips.
  2. Fairphone 3 Speaker Module Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Fairphone 3 Speaker Module Replacement: crwdns2935265:02crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Fairphone 3 Speaker Module Replacement: crwdns2935265:02crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Slide around the bottom right corner of the back cover to loosen the lower plastic clips.
    • Lift the back cover to release the rest of the plastic clips and remove it.
    • To reinstall the back cover press it firmly into place until you hear a snap from the plastic clips to form a seamless connection with the rear side of the phone.
  3. Fairphone 3 Speaker Module Replacement, Battery: crwdns2935265:03crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Fairphone 3 Speaker Module Replacement, Battery: crwdns2935265:03crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Use a fingernail or a prying tool at the marked notch to lever the battery out of its recess.
    • Lever the battery up until you can get a good grip.
  4. Fairphone 3 Speaker Module Replacement: crwdns2935265:04crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Fairphone 3 Speaker Module Replacement: crwdns2935265:04crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Lift the battery out of its recess and remove it.
  5. Fairphone 3 Speaker Module Replacement, Display Assembly: crwdns2935265:05crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Whenever a Phillips #00 screw is mentioned you can also unfasten it with a size #0 bit/screwdriver.
    • Remove the thirteen Phillips #00 screws (4 mm length).
    Attention : pour dévisser les deux vis du haut il est nécessaire d’avoir un tournevis assez fin, certains tournevis #0 seront trop gros et risquent de marquer les bords du trou, voire la caméra.
    pichel - crwdns2934203:0crwdne2934203:0
    I used the knife edge (on my suiss knife) and it worked fine. Of course, be very very carful not to damage the screws. In one hole I had to "sacrifice" a little bit plastic since the hole was a little bit too narrow for the knife.
    Evaf70 - crwdns2934203:0crwdne2934203:0
    no opening pick supplied with phone or part, it seems, and no picture of where to insert it
    Jean Anne Campbell Leith - crwdns2934203:0crwdne2934203:0
    1 von 13 Schrauben kommt nicht aus. Und eine weitere ist wohl jetzt am Kreuzschlitz abgenutzt weil sie schwer raus ging bzw. weil der Schraubenzieher durchdrehte.
    Timm Cebulla - crwdns2934203:0crwdne2934203:0
  6. Fairphone 3 Speaker Module Replacement: crwdns2935265:06crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Fairphone 3 Speaker Module Replacement: crwdns2935265:06crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Fairphone 3 Speaker Module Replacement: crwdns2935265:06crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Make sure to insert the opening pick between the midframe and the display module and not into the small gap next to the screen. Otherwise you're going to pry up the screen instead of the whole display module.
    • Insert an opening pick between the midframe and the display module on the right edge of the phone.
    • Slide the opening pick down to the bottom right corner to pry open the plastic clamps of the display module.
    Hello. I do not have an opening pick; one was not provided with the telephone or the camera module. How am I supposed to install the item if I have not been either provided with, or informed of the requirement for, a necessary tool? This makes it extremely difficult for a customer to make their own installations or repairs. Also, I do not have a spudger, and I had to look up what a spudger is. These are not everyday items found in most people’s toolboxes, so I feel that they should be provided, or a warning should be given when buying items (such as the camera module) which will require additional tools to install.
    Helen Pearson - crwdns2934203:0crwdne2934203:0
    Hi, you are right, there should be a hint to buy those tools. Maybe you have a guitar pick or a very thin spatula or putty knife. It is better to not use metal, to not damage the frame, but if you have no other tool this may help.
    Fabian Gugger -
    Attention de bien insérer sur la rainure la plus à l'extérieur, vous allez sinon decoller le joint fixant l'écran à proprement parler au reste du module.
    Si ça vous arrive, vous le saurez en voyant que la partie décollée est toujours reliée par une nappe à la partie inférieure de l'écran. Pas de panique, appliquez quelques points de colle par dessus le joint d'origine et recommencez la procédure, cette fois dans la bonne rainure (et la procédure devrait vous paraître beaucoup plus simple ;) )
    Geoffrey Fernandez - crwdns2934203:0crwdne2934203:0
    Punaise, moi cette partie de mon écran se décolle toute seule. Juste un tout petit peu, par le haut. Vous me conseillez de le décoller plus pour pouvoir y mettre de la colle ?? Quelle colle serait le mieux ? (pas envie d’acheter un écran vu que le mien fonctionne très bien quand même)
    Lucy sann -
    Hello, I got frustrated when I didn’t find any opening pick. I’m not a guitarr player either ;-) , so I took a old credit card instead. It worked fine! I got a spudger when I bought the FP3.
    Anyway, these tools are not common in most households, so they should be provided or at least they should be hinted that they are needed.
    Mattias Ahlstedt - crwdns2934203:0crwdne2934203:0
    Hey, I cut the edge off a stiff plastic packaging and inserted it. It was itself too wobbly, but widened the gap enough so I could insert the edge of a credit card which worked just fine.
    Corinna Fischer - crwdns2934203:0crwdne2934203:0
    Ich hatte kein Plektrum habe es mit einer Chip-Karte probiert, das ging auch.
    Britta Hammer - crwdns2934203:0crwdne2934203:0
    If you have somewhat long nails you don't need a special tool to begin opening it. Following the frame afterwards is easy with a plain screwdriver.
    Carlos Izquierdo - crwdns2934203:0crwdne2934203:0
  7. Fairphone 3 Speaker Module Replacement: crwdns2935265:07crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Fairphone 3 Speaker Module Replacement: crwdns2935265:07crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Slide the opening pick around the bottom right corner and use it to disengage the plastic clamps at the bottom of the display module.
    Hallo
    nachdem mein Handy ausversehen runtergefallen ist, war das Display dunkel; ein/aus half nichts, akku raus/rein auch nicht. Es gab Brumgeräusche wie beim Starten wenn ich Start gedrückt habe, das Display blieb dunkel. Ich konnte das Display mit etwas mühe(ungeübt) ausbauen und wieder einbauen. Danach ging es wieder; Danke euch hier für die Anleitung. So ein Plektrum habe ich leider nicht mehr, ich glaub es war eines dabei. Ich habe mir mit einem kleinen Plastiklöffel geholfen, der ist jetzt mein Star :-)
    Timo Strauß - crwdns2934203:0crwdne2934203:0
    Sehr gut! Viel Spaß mit deinem Fairphone!
    Fabian Neidhardt -
  8. Fairphone 3 Speaker Module Replacement: crwdns2935265:08crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Fairphone 3 Speaker Module Replacement: crwdns2935265:08crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Slide the opening pick along the left side to pry the display module up.
    • The display module should pop out of the midframe during this process. In case it doesn’t, check for remaining clamps you might have missed.
  9. Fairphone 3 Speaker Module Replacement: crwdns2935265:09crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Fairphone 3 Speaker Module Replacement: crwdns2935265:09crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Remove the display assembly.
    • To reinstall the display-module press it into place on all sides until you can hear a snap from the plastic clamps to make sure it sits flush with the frame.
    • If you install a new display: The new display module comes with a white plastic cover held by 2 screws over the processor and the connectors. This needs to be taken off.
    The new display module comes with a white plastic cover held by 2 screws over the processor and the connectors. This needs to be taken off!
    Joe - crwdns2934203:0crwdne2934203:0
    ATTENTION !l’écran neuf comprend un cache plastique qui tient avec 2 vis ! pour monter le nouvel écran il faut dévisser les vis et enlever le cache plastique
    Félix Béranger - crwdns2934203:0crwdne2934203:0
    Die weiße Plastikabdeckung an dem neuen Modul muss vor dem Einbau noch gelöst werden (2 Schrauben).
    Christian Schmidt - crwdns2934203:0crwdne2934203:0
    Vielen Dank für die kleinschrittige Anleitung, dir mir als Reparaturmuffel geholfen hat, mein Handy wieder zu aktivieren. Hintergrund: nach einem Sturz war das Display total verpixelt. Durch aus- und Einbau des Displays wurden die durch den Sturz gelockerten Kontakte wieder neu verbunden und - siehe da - es funktioniert wieder alles wie am ersten Tag! Da bin ich froh, daß ich mich für ein fairphone entschieden habe.
    Technikmuffel - crwdns2934203:0crwdne2934203:0
    Sehr gut! Weiter viel Spaß mit deinem Fairphone!
    Fabian Neidhardt -
    Nach dem Zusammenbau kommt kein Ton mehr heraus. Woran kann das liegen?
    Willi Koschutjak - crwdns2934203:0crwdne2934203:0
  10. Fairphone 3 Speaker Module Replacement, Bottom Module: crwdns2935265:010crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the four 4.1mm-longPhillips #00 screws.
  11. Fairphone 3 Speaker Module Replacement: crwdns2935265:011crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Fairphone 3 Speaker Module Replacement: crwdns2935265:011crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Use a spudger to pry up and disconnect the bottom module connecting cable.
  12. Fairphone 3 Speaker Module Replacement: crwdns2935265:012crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Fairphone 3 Speaker Module Replacement: crwdns2935265:012crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Use your fingers to remove the bottom module.
    Attention, la nappe s'est débranchée du « mauvais » côté (c'est-à-dire, du reste de l'appareil) lorsque j'ai effectué l'opération.
    Il faut alors la reconnecter correctement, ce qui est un peu galère.
    Yannek - crwdns2934203:0crwdne2934203:0
    Hi,
    When I detached the bottom module, on the little "tongue"on the tight side I found a plastic tape and I was wondering if it was normal or if I had to remove it.
    Could you tell me please?
    Anne Duval - crwdns2934203:0crwdne2934203:0
    Bonjour,
    avez vous pu remplacer votre partie basse ? Et où l'aviez vous achetée? Je vous remercie. Cathie
    Catsilou -
  13. Fairphone 3 Speaker Module Replacement, Speaker Module: crwdns2935265:013crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the 4.1mm-long Phillips #00 screw.
  14. Fairphone 3 Speaker Module Replacement: crwdns2935265:014crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Fairphone 3 Speaker Module Replacement: crwdns2935265:014crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Use your fingers to remove the speaker module.
Information on what to do with the old module can be found on the FairPhone support page and in the FairPhone forum.
crwdns2947821:0crwdne2947821:0
crwdns2947823:0crwdne2947823:0
Adriana Zwink
crwdns2935283:012/18/19crwdne2935283:0
58.704 crwdns2915208:0crwdne2915208:0
crwdns2935297:0167crwdne2935297:0
Staff
crwdns2931471:0119crwdne2931471:0
crwdns2935297:021.683crwdne2935297:0
Super einfach, danke für die tollen Bilder.
Ich hab dies nur gemacht um das Phone mal wieder von Staub zu befreien, vor allem bei den Lautsprecheröffnungen hat sich einiges angesammelt.
Fabian Gugger - crwdns2934203:0crwdne2934203:0
Ein “Frühjahrsputz” ist bei diesem Gerät tatsächlich eine Option :)
Tobias Isakeit -
crwdns2936753:030crwdne2936753:0 60
crwdns2942667:0crwdne2942667:0 4,809
