Follow this guide to replace the battery on a Sony DualShock 4 CHU-ZCT2U Playstation controller.
This guide will also work for the older CHU-ZCT1U model controller but be sure to order the JDM-030 battery, which has a different sized connector. You can check which model controller you have by referencing the sticker on the rear panel.
If your battery is swollen, take appropriate precautions.
Use a Phillips screwdriver to remove the four 6.4 mm-long screws from the rear panel.
Insert an opening tool into the crease where the front and rear panel meet, starting from the outside edge of either handle.
Gently pry the rear panel off of the front panel until they become partially separated.
easy, but quite brute way of opening the rear panel without the opening tool: https://www.youtube.com/watch?v=wYybiBBL...
watch the opening from the back part only, then return here.
That worked but a couple clips broke in the process. Beware for people trying this method.
There are 4 tab clips total, 2 at the top corners (very easy to break) and 2 at the bottom near the ports. The screws will keep it together even if they do break but be careful if you don’t want to break them.
Fungi -
I've written a guide to help others find the clips and unlatch them.
Hi Richard,
Thanks for writing this up! I'm going to link your guide into the step.
Use the opening tool to separate the panels by releasing the plastic clips around the perimeter of the controller.
I've written a guide to help others find and unlatch these clips
Lift the rear panel directly away from the controller.
crwdns2935267:0crwdne2935267:0Tweezers$4.99
Use your fingers to gently pull the ribbon cable straight out of its connector on the motherboard.
I'm struggling getting the ribbon to connect back in. Why might that be?
Use a pair of tweezers to pull the battery's power connector straight up from the motherboard.
crwdns2935229:044crwdne2935229:0
For this DualShock 4 CHU-ZCT2U Battery Replacement, shouldn’t the battery model be JDM-040 and not JDM-030 for this controller. I ordered the battery listed but the connector was too large. So I believe this needs to be edited to match accordingly to avoid confusion and incorrect orders. Thanks!
Good catch! I just pulled apart the ZCT1U and ZCT2U models and you are right. I will fix this in the guide. Thank you!
Can perhaps someone tell me what exact connector does the original battery use ?
Just bought and the connector does not fit for the newer gen controllers. Dissapointing
Is there a conclusion to this? I force charged two batteries from two controllers (which died within the same day) in a known good controller (which has the larger battery connector which can accommodate the smaller ones) each for about three hours (~470mA/h) until they each showed a measured 4ish volts dry test. Once plugged back in neither worked either with the ps button or usb physical connect but funny each will “share” by holding the PS+Share button for a while, idk how to have it actually pair with my station any more. Even after using the reset button on the back. Haaaalp :). I’ll likely figure it out before someone responds to this but for the sake of anyone who can’t troubleshoot please post any answer if you have one, kThanksXO
I purchased the recommended JDM-040 replacement battery for my CUH-ZCT2U controller (before reading these comments) and it does NOT work as a replacement. The connector is wrong, and the pin holes are too small.
Regarding those asking if the JDM-030 battery works, the connector is also wrong. I can confirm, though, that the JDM-030 is the correct replacement battery for the CUH-ZCT1U controller.
A driver size recommendation would be nice. I tried several and found that a size 2.5 Phillips worked nicely
Justin Vander Ziel - crwdns2934203:0crwdne2934203:0
