DualSense Controller v2 Microphone Replacement
  1. DualSense Controller v2 Microphone Replacement, Unclip the right end of the middle trim: crwdns2935265:01crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 DualSense Controller v2 Microphone Replacement, Unclip the right end of the middle trim: crwdns2935265:01crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Disconnect and power down your controller before you begin.
    • Insert an opening pick underneath the middle trim at the bottom-right corner of the controller to release the clips securing it to the case.
  2. DualSense Controller v2 Microphone Replacement, Unclip the lower-right edge of the middle trim: crwdns2935265:02crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 DualSense Controller v2 Microphone Replacement, Unclip the lower-right edge of the middle trim: crwdns2935265:02crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 DualSense Controller v2 Microphone Replacement, Unclip the lower-right edge of the middle trim: crwdns2935265:02crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Slide the opening pick along the lower-right edge of the middle trim to release the clips securing it to the case.
  3. DualSense Controller v2 Microphone Replacement, Unclip the left end of the middle trim: crwdns2935265:03crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 DualSense Controller v2 Microphone Replacement, Unclip the left end of the middle trim: crwdns2935265:03crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Insert an opening pick underneath the middle trim at the bottom-left corner of the controller to release the clips securing it to the case.
  4. DualSense Controller v2 Microphone Replacement, Unclip the lower-left edge of the middle trim: crwdns2935265:04crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 DualSense Controller v2 Microphone Replacement, Unclip the lower-left edge of the middle trim: crwdns2935265:04crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 DualSense Controller v2 Microphone Replacement, Unclip the lower-left edge of the middle trim: crwdns2935265:04crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Slide the opening pick along the lower-left edge of the middle trim to release the clips securing it to the case.
  5. DualSense Controller v2 Microphone Replacement, Remove the middle trim: crwdns2935265:05crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 DualSense Controller v2 Microphone Replacement, Remove the middle trim: crwdns2935265:05crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 DualSense Controller v2 Microphone Replacement, Remove the middle trim: crwdns2935265:05crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Use your fingers to lift up the bottom edge of the middle trim to release the remaining clips.
    • Lift the middle trim over the joysticks to remove it.
    • During reassembly, position the middle trim into place and press along all edges to engage the clips securing it to the controller.
  6. DualSense Controller v2 Microphone Replacement, Remove the L1 button: crwdns2935265:06crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 DualSense Controller v2 Microphone Replacement, Remove the L1 button: crwdns2935265:06crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 DualSense Controller v2 Microphone Replacement, Remove the L1 button: crwdns2935265:06crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Insert the flat end of your spudger into the gap above the L1 button.
    • Cover the button with your thumb to prevent it from ejecting across the room.
    • Pry the spudger upward to remove the L1 button.
  7. DualSense Controller v2 Microphone Replacement, Remove the R1 button: crwdns2935265:07crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 DualSense Controller v2 Microphone Replacement, Remove the R1 button: crwdns2935265:07crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 DualSense Controller v2 Microphone Replacement, Remove the R1 button: crwdns2935265:07crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Insert the flat end of your spudger into the gap above the R1 button.
    • Pry the spudger upward to remove the R1 button.
  8. DualSense Controller v2 Microphone Replacement, Remove the case screws: crwdns2935265:08crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Use a Phillips screwdriver to remove the two 6.5 mm screws securing the bottom corners of the lower case.
  9. DualSense Controller v2 Microphone Replacement: crwdns2935265:09crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Use a Phillips screwdriver to remove the two 6.5 mm screws behind the L1 and R1 buttons.
  10. DualSense Controller v2 Microphone Replacement, Unclip the rear case: crwdns2935265:010crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 DualSense Controller v2 Microphone Replacement, Unclip the rear case: crwdns2935265:010crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 DualSense Controller v2 Microphone Replacement, Unclip the rear case: crwdns2935265:010crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Use the pointed edge of a spudger to unclip the two clips on either side of the headset jack.
  11. DualSense Controller v2 Microphone Replacement, Remove the rear case: crwdns2935265:011crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 DualSense Controller v2 Microphone Replacement, Remove the rear case: crwdns2935265:011crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Use your hands to carefully pull the rear case off of the controller.
    • During reassembly, make sure the red and black vibration motor wires are not pinched between the front and rear case.
    You can´t just grab both ends and expect it to open flawlessly, first you gotta travel the spudger around the seam at the outer edges of the controller, there are multiples clips in that area, there a couple really hard to get out at the outer edges of the R1 and L1 buttons, for those you need to insert the spudger bending outwards the bottom piece of the controller (a fairly amount, like 1.5mm) and while bending outwards use the same inserted spudger to lever them apart carefully, the plastic will bend quite a bit so be very careful with the motion of the spudger.
    Yet again, that was my personal experience opening it up, try first as the guide says, if you feel the upper and bottom pieces glued around the R1 and L1, then try this.
    Carlos Santana - crwdns2934203:0crwdne2934203:0
    I had the same experience, the best way to reach these for me was to place the spunger from L1 R1 side whilst using a spunger to press outwards from the side like in Carlos's comment. Thank you Carlos I was struggling with this!
    Remco geuze -
    This did not work for me. Finally I just pulled the two parts apart at the bottom side, carefully twisting and manipulating until the parts clicked loose at the top side
    Gilian Mischker -
    This is the biggest hassle in the whole process. It seems that all controllers now come with those extra clips that other people mentioned here. I, however, didn't have the same success with their steps of running a spudger on the sides to undo the clip. Looking around, I found this Youtube video showing that you can undo the clips simply by twisting up from the bottom. Do it carefully because it pops off easily using this method - when I did, I used some force and the back just flew from my table.
    I found it easier like that and was able to continue the process.
    Rodrigo Castro - crwdns2934203:0crwdne2934203:0
    +1 to this. None of the suggestions worked well enough for me, but this video clip got this step done for me nearly instantly. note the position of the tech's fingers and thumbs - I copied that exactly and had no issue.
    Nathan K -
  12. DualSense Controller v2 Microphone Replacement, Remove the lower microphone: crwdns2935265:012crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 DualSense Controller v2 Microphone Replacement, Remove the lower microphone: crwdns2935265:012crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Use the pointed end of your spudger to lift the lower microphone out of its bracket next to the battery.
    • During reassembly, make sure the end of the microphone's ribbon cable is slotted into the bracket.
  13. DualSense Controller v2 Microphone Replacement: crwdns2935265:013crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 DualSense Controller v2 Microphone Replacement: crwdns2935265:013crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Use a pair of blunt-nose tweezers or your fingers to grip the lower microphone cable by its pull tab and disconnect it from the motherboard.
  14. DualSense Controller v2 Microphone Replacement, Remove the upper microphone: crwdns2935265:014crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 DualSense Controller v2 Microphone Replacement, Remove the upper microphone: crwdns2935265:014crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 DualSense Controller v2 Microphone Replacement, Remove the upper microphone: crwdns2935265:014crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Use the pointed end of your spudger to lift the upper microphone out of the front case.
    • During reassembly, make sure the upper microphone's ribbon cable is properly slotted and hooked into the front case.
  15. DualSense Controller v2 Microphone Replacement: crwdns2935265:015crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 DualSense Controller v2 Microphone Replacement: crwdns2935265:015crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Use a pair of blunt-nose tweezers or your fingers to grip the upper microphone cable by its pull tab and disconnect it from the motherboard.
    • Don't try to remove the microphone yet—it won't fit out this side of the front case.
  16. DualSense Controller v2 Microphone Replacement: crwdns2935265:016crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 DualSense Controller v2 Microphone Replacement: crwdns2935265:016crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Use a pair of tweezers or your fingers to remove the upper microphone through the top of the front case.
    • Don't force the cable if you encounter resistance. It may have snagged on the front case.
Sam Omiotek
crwdns2935283:002/25/19crwdne2935283:0
86,097 crwdns2915208:0crwdne2915208:0
crwdns2935297:0290crwdne2935297:0
Where do I buy a replacement microphone? I don’t trust eBay, AliBaba, or AliExpress.
Joey Hurewitz - crwdns2934203:0crwdne2934203:0
fixed my stick drift with this guide, though at the cost of having a “stuck” stick when I move it right, works fine; probably won’t stick back my kontrolfreeks they might wear the contact points faster Anyways other than that issue back to a perfect controller warning though as you can see lots of small intricate parts I recommends some stretching because personally my arms were shaking because I was working with small parts and didn’t want to damage anyhthing. Bellowed oaths and persistence later I succeeded.
Benjamin Roman - crwdns2934203:0crwdne2934203:0
crwdns2936751:024crwdne2936751:0 12
crwdns2936753:07crwdne2936753:0 55
crwdns2936753:030crwdne2936753:0 266
crwdns2942667:0crwdne2942667:0 2,421
