Classen Sod Cutter HSC18AHD 2018 Lower Drive Chain Replacement
  1. crwdns2944590:01crwdnd2944590:04crwdnd2944590:0crwdnd2944590:0crwdne2944590:0
    Classen Sod Cutter HSC18AHD 2018 Lower Drive Chain Replacement, Safety precautions: crwdns2935265:01crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Classen Sod Cutter HSC18AHD 2018 Lower Drive Chain Replacement, Safety precautions: crwdns2935265:01crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Make sure the engine is off and cool to the touch before you proceed.
  2. Classen Sod Cutter HSC18AHD 2018 Lower Drive Chain Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Place wheel chocks against the roller and rear wheel to prevent the machine from moving.
  3. Classen Sod Cutter HSC18AHD 2018 Lower Drive Chain Replacement: crwdns2935265:03crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Classen Sod Cutter HSC18AHD 2018 Lower Drive Chain Replacement: crwdns2935265:03crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Flip the gas shutoff switch next to the motor to the left into the off position.
  4. Classen Sod Cutter HSC18AHD 2018 Lower Drive Chain Replacement: crwdns2935265:04crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Classen Sod Cutter HSC18AHD 2018 Lower Drive Chain Replacement: crwdns2935265:04crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Grab the plastic housing at the end of the spark plug wire.
    • Pull firmly to disconnect the wire from the spark plug.
  5. Classen Sod Cutter HSC18AHD 2018 Lower Drive Chain Replacement, Unbolt the cutter blade: crwdns2935265:05crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Use a 1/2 inch socket to remove the three bolts securing the cutter blade on the left side of the machine.
    • You may need to use a 1/2 inch wrench in combination with the socket wrench to hold the nuts in place.
  6. Classen Sod Cutter HSC18AHD 2018 Lower Drive Chain Replacement: crwdns2935265:06crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Use a 1/2 inch socket to remove the three bolts securing the cutter blade on the right side of the machine.
  7. Classen Sod Cutter HSC18AHD 2018 Lower Drive Chain Replacement, Remove the cutter blade: crwdns2935265:07crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Classen Sod Cutter HSC18AHD 2018 Lower Drive Chain Replacement, Remove the cutter blade: crwdns2935265:07crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Classen Sod Cutter HSC18AHD 2018 Lower Drive Chain Replacement, Remove the cutter blade: crwdns2935265:07crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Slide the cutter blade out from under the machine to remove it.
    • Do not handle the blade from the cutting edge.
  8. crwdns2944590:08crwdnd2944590:010crwdnd2944590:0crwdnd2944590:0crwdne2944590:0
    Classen Sod Cutter HSC18AHD 2018 Lower Drive Chain Replacement, Remove the chain guard: crwdns2935265:08crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Use a 1/2 inch socket to remove the 130 mm-long bolt securing the chain guard.
  9. Classen Sod Cutter HSC18AHD 2018 Lower Drive Chain Replacement: crwdns2935265:09crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Carefully tilt the sod cutter on its side.
    • Use a 9/16 inch socket to remove the nut securing the chain guard.
  10. Classen Sod Cutter HSC18AHD 2018 Lower Drive Chain Replacement: crwdns2935265:010crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Classen Sod Cutter HSC18AHD 2018 Lower Drive Chain Replacement: crwdns2935265:010crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Classen Sod Cutter HSC18AHD 2018 Lower Drive Chain Replacement: crwdns2935265:010crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Remove the chain guard.
  11. Classen Sod Cutter HSC18AHD 2018 Lower Drive Chain Replacement, Remove the lower chain: crwdns2935265:011crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Classen Sod Cutter HSC18AHD 2018 Lower Drive Chain Replacement, Remove the lower chain: crwdns2935265:011crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Use a marker to mark the locations for each bearing before disassembly.
    • Reference these marks during reassembly to ensure the sprocket shaft is straight and the chain is not too loose.
  12. Classen Sod Cutter HSC18AHD 2018 Lower Drive Chain Replacement: crwdns2935265:012crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Classen Sod Cutter HSC18AHD 2018 Lower Drive Chain Replacement: crwdns2935265:012crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Loosen the four 1/2 inch bolts securing the sprocket shaft bearings until the sprocket shaft can freely move.
  13. Classen Sod Cutter HSC18AHD 2018 Lower Drive Chain Replacement: crwdns2935265:013crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Classen Sod Cutter HSC18AHD 2018 Lower Drive Chain Replacement: crwdns2935265:013crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Classen Sod Cutter HSC18AHD 2018 Lower Drive Chain Replacement: crwdns2935265:013crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Rotate the wheels to turn the chain until the master link is accessible.
    • Use a pair of pliers to unclip the master link retaining plate.
    • Note the direction the retaining plate is facing.
    • Remove the master link.
    • Make sure the new master link retaining plate is installed in the same direction. If installed backwards, the plate could come off during operation.
  14. Classen Sod Cutter HSC18AHD 2018 Lower Drive Chain Replacement: crwdns2935265:014crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the chain.
Sam Omiotek
crwdns2935283:002/25/19crwdne2935283:0
87.927 crwdns2915208:0crwdne2915208:0
crwdns2935297:0290crwdne2935297:0
crwdns2942667:0crwdne2942667:0 1,433
