If your Asus ROG G752V has lost its ability to hold a charge, you most likely have a dead/faulty battery which would require replacement.
A functional battery provides power to your laptop. Eventually, the laptop battery will rapidly drain after going through a repeated amount of charge cycles. If you notice that your charged battery is draining more quickly than usual, consider calibrating your battery to determine an accurate charging capacity. If you continue to notice significant drops in battery percentage, you should replace your battery.
A punctured battery can cause a dangerous fire. If your battery is swollen, take appropriate precautions.
Before you begin to use this guide, make sure to power off your Asus ROG G752V completely and disconnect from any external power source.
crwdns2935267:0crwdne2935267:0Tweezers$4.99
Pick out all 11 rubber plugs off of the back cover with a pair of tweezers.
Using the Phillips #0 screwdriver, unscrew all twelve 5.2 mm screws on the back of the laptop.
In my case, the 4 screws alongside the touchpad are smaller than the others.
Pull up the rubber seal and the service cover will come off.
Using the Phillips #00 screwdriver, remove the six 5.2 mm screws under the service cover.
Using your hands, pull the optical drive out.
You will need a small safety pin or similar to release the CD drive tray so it can open. Look for a small hole and insert the pin into the hole and push, it should normally open the tray.
Once open, look for 3 small screws that are attached to the cover. These have to be removed so the cover can come off.
Use the iFixit Opening Tool to pry apart the back panel from the main body of the laptop.
Remove the hinge on the back of the laptop cover using the iFixit Opening Tool. The piece should pop off.
Slowly pull out the keyboard while lifting it about an inch.
Using an ESD safe tool, detach all 3 ribbon cables securing the keyboard to the laptop.
Do you do the same thing in Reverse lift the flap up place the ribbon down and then it's snaps?
I didn't need to disconnect the ribbons, just slide the keyboard forward a few inches for the following steps
Once the cables are detached, lift the keyboard about 2 inches up and remove it from the rest of the body.
Disconnect the battery cable from its motherboard socket by gently pulling it towards the left of the socket.
Remove two 5.8 mm screws holding the screen and the laptop located at the hinge.
Remove the screen.
In my case, 6 x M2.4x9,6mm screws near the center - indicated with X stamp - and 2 x M1,9x6,6mm screws, 1 on the left hand side and the other on the right hand side.
Mine same as Jonathan’s. Total of 8 screws to remove the screen
Same here, 8 screws. Also… must disconnect screen!
Remove the four 5.8 mm screws securing the battery to the laptop.
There are two different lengths of screw holding the battery. When putting it back together, the longer screws go to the rear of the computer.
Use your hands to remove the battery.
The second set of wires going to the battery (shown on the right side between the tech's thumb and forefinger) are attached to a strip glued to the back of the battery. I believe it is a temperature sensor of some kind. Carefully peel it off the old battery, being careful not to bend it and press it to onto the new battery. There are two holes in the sensor strip, on at the right in the corner, another at the left end in the center. On the battery, there are two very small, hard to see alignment points to fit into those holes.
For optimal performance, after completing this guide, calibrate your newly installed battery.
crwdns2935229:014crwdne2935229:0
crwdns2947412:010crwdne2947412:0
There is 2 connection. What is the smaller connection for? Thanks.
The second set of wires going to the battery (shown on the right side between the tech's thumb and forefinger in the picture at the step where you remove the battery) are attached to a strip glued to the back of the battery. I believe it is a temperature sensor of some kind. Carefully peel it off the old battery, being careful not to bend it and press it to onto the new battery. There are two holes in the sensor strip, on at the right in the corner, another at the left end in the center. On the battery, there are two very small, hard to see alignment points to fit into those holes.
I see where Rich C says it's part of an LED strip. I didn't look at it closely.
Greg S. -
God, alot of people looked at my team’s project. Sorry it’s a piece of crap.
I had to do it for my tech writing class, got a solid B on it.
Thanks for this write up, excellent job. As Mickey mentioned, there is a second connection, from the side of the existing battery. This is actually part of an LED strip that is secured to the battery with an adhesive strip. Some models have this glowing back panel. I used a filet knife to pop the LED panel off the old battery and then tack it on the new one.
My lap top bears no relation to this but it is a UK spec laptop so may differ. I will need to purchase a kit from iFixit before I embark on replacing the battery in my laptop
This was a lot easier than I anticipated. I want to thank you for your excellent writeup which was a lot better than the videos I have seen on YouTube.
Thanks to the Asus ROG G752V Battery Replacement tutorial, I have successfully replaced
you forgot one important detail betwen step 5 and step 6 - there are three screws beneath the optical drive, when you slide it out they need to be removed first before popping the case (you can see where they go on the left side of the image in step 14, along the outer edge of the empty optical drive bay)
otherwise, fantastic, very helpful
Amazing directions,
If I feel uneasy doing it myself, where would be a qualified place to have someone do it
My wifi connection quit working after I replaced the battery.
Before you put everything back together, check the antenna wires are connected to the wifi card. If you look at picture 14 in these instructions, the wifi card is located roughly under the guys thumb. There is a white and a black wire with snap on connectors about the size of a pinhead.
If you still aren't sure, Jeong has another excellent article at Asus ROG G752V Wireless Card Replacement.
