Use this guide to remove or replace a broken sensor assembly in your Apple Watch Ultra.
You’ll need replacement adhesive to reattach the screen when reassembling the device. Your device will function normally, but will most likely lose its IP6X (Ingress Protection) rating.
Take your watch off the charger and power it down.
Use a P5 Pentalobe driver to remove the four 2.2 mm‑long screws securing the sensor assembly.
Heat an iOpener and apply it to the sensor assembly for at least two minutes to loosen the adhesive underneath.
Insert an iFlex in the seam between the watch frame and the top edge of the sensor assembly to create a gap.
Carefully twist the iFlex to widen the gap.
Insert an opening pick into the gap you created.
Remove the iFlex.
Slide the opening pick around the top right corner of the sensor assembly and along the right edge to slice its adhesive.
Slide the opening pick around the bottom right corner and along the bottom edge to slice the rear assembly adhesive.
Slide the opening around the bottom left corner and along the left edge to slice the remaining adhesive.
crwdns2935267:0crwdne2935267:0Tweezers$4.99
Carefully lift the top edge of the sensor assembly with your opening pick until you can get a good grip with your fingers.
Lift the sensor assembly and carefully pull it towards the bottom edge of the watch.
Swing the sensor assembly open to an upward position.
Use a spudger to pry and disconnect the sensor assembly cable from its socket.
Remove the sensor assembly.
To reassemble your Apple Watch Ultra follow these instructions in reverse order to reattach the screen and the battery.
Apply a little bit of high isopropyl alcohol (>90%) to a Q-tip or use a cleaning pad to gently remove the leftover adhesive on the edges of the watch case and the screen before installing new adhesive.
crwdns2947412:07crwdne2947412:0
The back of the apple watch not the sensor what is that material.i know the sensors are ceramic coated but what about the surrounding area of the watch in which the screws go in ??
Woher bekomme ich diesen Bauteil?
Mein Sensor Glas ist defekt, habe in Euren Store nichts gefunden
Danke Lg
Where can you purchase another sensor? My sensor is cracked after 3 months from purchase, did not drop it and Apple not willing to replace. I'm not willing to spend another $500 for it. Thoughts?
I have the same problem. cracked after a few months from purchase. ceramic and sensors material is weak compared to the front (titanium material). Its weak point in ultra watch need to be fixed by Apple
The back casing is a huge Achillies heal of the Ultra watch. When the crack first occurred (two months after purchase, and occurred simply while removing the watch over a bathroom counter), it was so minor that I noticed no loss of functionality. After six more months, the heart rate monitor stopped working. Then the battery life plummeted. Now at 10 months since purchase, I'm deciding between $500 Apple service, NYC-based repair services, or do it yourself repair.
