Apple Watch Series 7 Battery Replacement
  1. Apple Watch Series 7 Battery Replacement, Power down the watch: crwdns2935265:01crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Apple Watch Series 7 Battery Replacement, Power down the watch: crwdns2935265:01crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
  2. Apple Watch Series 7 Battery Replacement, Safety Requirements: crwdns2935265:02crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Apple Watch Series 7 Battery Replacement, Safety Requirements: crwdns2935265:02crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Apple Watch Series 7 Battery Replacement, Safety Requirements: crwdns2935265:02crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    Safety Glasses
    $3.19
    • Because the gap between the screen and watch body is so thin, a sharp blade is needed to separate the two. Read the following warnings carefully before proceeding.
    • Protect your fingers by keeping them completely clear of the knife. If in doubt, protect your free hand with a heavy glove, such as a leather shop glove or gardening glove.
    • Be careful not to apply too much pressure, as this might cause the knife to slip and cut you, or damage the watch.
    • Wear eye protection. The knife or glass may break, sending pieces flying.
    • Attach or remove the watch band as needed to provide more control as you make repairs.
  3. Apple Watch Series 7 Battery Replacement, Soften the display adhesive: crwdns2935265:03crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Prepare an iOpener and apply it to the screen for at least two minutes to loosen the adhesive underneath.
    • A hair dryer, heat gun, or hot plate may also be used, but be careful not to overheat the watch—the display and internal battery are both susceptible to heat damage.
    • You may need to reheat the iOpener and repeat this procedure several times until the display adhesive softens.
    Can confirm that if you want this to work, pop the iopener in for around 45seconds and then let it sit on the watch for 6 minutes, 2 minutes is just not enough.
    Jeremiah Yoder - crwdns2934203:0crwdne2934203:0
  4. Apple Watch Series 7 Battery Replacement, Create a gap: crwdns2935265:04crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Apple Watch Series 7 Battery Replacement, Create a gap: crwdns2935265:04crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Apple Watch Series 7 Battery Replacement, Create a gap: crwdns2935265:04crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Be aware that a sharp tool easily scratches your watch housing when not handled with care. To avoid undesired scratches, take your time and work carefully rather than hastily.
    • Place the edge of a curved blade into the thin gap between the display and the outer case. Start at the short side of the display, most distant to the digital crown.
    • Once inserted, tilt the blade to pry the display open slightly and create a gap between the screen and the watch body.
    • The Apple Watch Series 7 display is equipped with a plastic bezel on its rear side. If you want to reuse your display, avoid using too much pressure with the knife or you may separate the bezel from the screen.
    Tried this for almost an hour, and I could not lift the display off at all. Broke the screen and chipped pieces of the screen as well.
    Excalibert89 - crwdns2934203:0crwdne2934203:0
    Yeah prolly gonna suggest an actual spudger for this step, or to be more detailed. Kept reheating the IOpener every 10mins keeping the watch under it for 5mins etc and it never budged after 3 hours of fiddling. Eventually broke the fine edge of the blade and scratched the casing, now the blade can't catch the groove and $8 down the drain.
    As experienced with the user above I tried heating it up with the IOpener 6x every 10 mins and it’s still tough to open. At first I left it a full 10 minutes to try and soften the adhesive. Then the advised 1 min and 30. it still won’t lift up. A spudger will definitely help but will prolly break it if pulled too much.
    Neal Quioyo - crwdns2934203:0crwdne2934203:0
    Four rounds with the iOpener I got it open... but then.... a cascade of errors...
    At some point while opening I saw a flash of lines across the screen. Significant?
    Cleaned adhesive off the case and screen for an hour with Q tips and alcohol... perfect...
    The replacement adhesive was not like in the photo, the tab to peel it was on a different corner, not a good start, it was very hard to position maybe easier for a lefty. Since it was so difficult to position, the blue protective cover was gone by the time It was well positioned with a spudger so once it was ready to test, it was sealed and the question will always be, is a cable unseated or was the display damaged opening it as it failed, it's awake, display is dark, it vibrates and makes noises with find my, but...
    So I tried to reopen it and check the cables and the glass popped off the OLED, the new adhesive which I worked so hard to ensure integrity for unfortunately gripped way too well. I'll have to destroy it to pull off the display. :(
    David Neff - crwdns2934203:0crwdne2934203:0
    No dice. Used the iOpener three times, then cut my finger open because there was no good place to hold the watch when the blade slipped. I give up.
    Roxanne Harvey - crwdns2934203:0crwdne2934203:0
    I tried it exactly this way of opening the display with the exact same tools as given here. starting with peeling on the short screen side with the fine blade. But then white lines appeared on my screen... Why? because exactly at that spot are the flat cables connecting the screen with the watch. Such a stupid recommendation from iFixit. It seems like they just copied the text over from another repair without validating it. now I broke not one but two watch displays because of that. I am very diappointed. I dont recommend doing this repair by yourself....
    Marlon Repair - crwdns2934203:0crwdne2934203:0
    I got it to work with a single heating of the iOpener. Heat the iOpener and set it on the watch as described for 90 seconds. Using the edge of the knife (I used an exacto knife), gently press the edge into seam between the glass and case, you'll see it sink in very slightly. Pull the edge out, move it down along the seam a couple millimeters, and then press it into the seam again. Keep working it down along the seem, slowly pressing the edge of the knife in and pulling back. After about a minute of this the edge of the glass started separating from the case, and I was able to negotiate the corner with the knife. I stuck a spudger underneath the raised edge and continued working around the screen edge until it was completely separated.
    Levi Noecker - crwdns2934203:0crwdne2934203:0
  5. Apple Watch Series 7 Battery Replacement, Slice the adhesive: crwdns2935265:05crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Apple Watch Series 7 Battery Replacement, Slice the adhesive: crwdns2935265:05crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Insert an opening pick in the gap your created.
    • Slide the opening pick along the short edge of the watch to slice the adhesive.
  6. Apple Watch Series 7 Battery Replacement: crwdns2935265:06crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Apple Watch Series 7 Battery Replacement: crwdns2935265:06crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Slide the opening pick around the corner and along the long edge on the opposite side of the watch crown to slice the display adhesive.
  7. Apple Watch Series 7 Battery Replacement: crwdns2935265:07crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Apple Watch Series 7 Battery Replacement: crwdns2935265:07crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Slide the opening pick around the corner to slice the remaining adhesive on the short edge of the watch next to the watch crown.
    • Don't try to remove the display. It is still connected to the watch assembly.
  8. Apple Watch Series 7 Battery Replacement, Swing open the display: crwdns2935265:08crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Apple Watch Series 7 Battery Replacement, Swing open the display: crwdns2935265:08crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Apple Watch Series 7 Battery Replacement, Swing open the display: crwdns2935265:08crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Be careful not to strain the display cables when you fold the display to the side.
    • Lift the display and carefully pull it towards the watch crown.
    • Swing the display open to an upward position.
    Hallo, ich habe leider beim Ausbau des Displays das Flexkabel beschädigt was zum Akku führt. Wie lässt sich dieses Kabel denn bitte tauschen? LG Thomas
    Th Ba - crwdns2934203:0crwdne2934203:0
  9. Apple Watch Series 7 Battery Replacement, Soften the battery adhesive: crwdns2935265:09crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Prepare an iOpener and apply it to the rear side of your Apple Watch for at least two minutes to loosen the adhesive underneath the battery.
  10. Apple Watch Series 7 Battery Replacement, Determine which procedure to follow: crwdns2935265:010crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • From this point, the battery removal procedure for the 41 mm watch differs slightly from the 45 mm version.
    • If you're replacing the battery for a 41 mm watch, continue with this step.
    • If you're replacing the battery for a 45 mm watch, continue with this step.
  11. Apple Watch Series 7 Battery Replacement, Pry up the battery: crwdns2935265:011crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Apple Watch Series 7 Battery Replacement, Pry up the battery: crwdns2935265:011crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Apple Watch Series 7 Battery Replacement, Pry up the battery: crwdns2935265:011crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • The following six steps show how to remove the battery from a 41 mm Apple Watch Series 7.
    • Insert an opening pick between watch body and the long edge of the battery.
    • Use constant, steady pressure to slowly pry up the battery.
    • Take care not to puncture or bend the battery with your tool—a punctured or bent battery may leak dangerous chemicals or cause a fire.
    • Don't try to remove the battery all the way yet. It is still connected to the motherboard.
  12. Apple Watch Series 7 Battery Replacement, Move the battery: crwdns2935265:012crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Apple Watch Series 7 Battery Replacement, Move the battery: crwdns2935265:012crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • The battery flex cable is long enough to allow you to place the battery outside the watch housing, but avoid straining or folding the the cable sharply when you lift the battery out of its recess.
    • Carefully lift and swing the battery out of its recess and place it next to the watch body.
  13. Apple Watch Series 7 Battery Replacement, Peel the black protective tape off the ZIF connector: crwdns2935265:013crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Apple Watch Series 7 Battery Replacement, Peel the black protective tape off the ZIF connector: crwdns2935265:013crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Use a pair of tweezers to peel the black protective tape off the ZIF connector.
    • Make sure to only peel the tape off the connector but avoid to remove it completely. Otherwise you have to replace the tape during reassembly.
  14. Apple Watch Series 7 Battery Replacement, Open the ZIF connector: crwdns2935265:014crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Apple Watch Series 7 Battery Replacement, Open the ZIF connector: crwdns2935265:014crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Use one arm of your tweezers or the pointed end of a spudger to pry up the lock bar on the ZIF connector securing the battery cable.
  15. Apple Watch Series 7 Battery Replacement, Disconnect the battery: crwdns2935265:015crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Apple Watch Series 7 Battery Replacement, Disconnect the battery: crwdns2935265:015crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Use a pair of tweezers to pull the battery cable out of the battery ZIF connector.
    • During reassembly make sure to push the cable all the way back into the ZIF connector before locking the it. Reapply the black tape on top of the connector to secure the battery cable or replace it with new one. Otherwise the battery cable may slip out of the connector and your watch won't turn on.
  16. Apple Watch Series 7 Battery Replacement, Remove the battery: crwdns2935265:016crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the battery.
    • Do not reuse the battery if it has been deformed or damaged, as doing so is a potential safety hazard. Replace it with a new battery.
    • If you're reusing your old battery during reassembly, you can reuse the existing adhesive to secure the battery during reassembly.
    • Secure a new battery with pre-cut adhesive or double-sided adhesive tape. In order to position it correctly, apply the new adhesive into the device at the places where the old adhesive was located, not directly onto the battery. Press the new battery firmly into place.
  17. Apple Watch Series 7 Battery Replacement, Pry up the battery: crwdns2935265:017crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Apple Watch Series 7 Battery Replacement, Pry up the battery: crwdns2935265:017crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Apple Watch Series 7 Battery Replacement, Pry up the battery: crwdns2935265:017crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • The following six steps show how to remove the battery from a 45 mm Apple Watch Series 7.
    Not a very good approach. Damaged back cover flex cable using triangular opening pick.
    Battery is well glued to motherboard and opening pick has just too little contact point.
    Better to start with metal prying tool from taptic engine side adding some drops of isopropyl alcohol from time to time.
    And of course take your time.
    Valdek Kangert - crwdns2934203:0crwdne2934203:0
  18. Apple Watch Series 7 Battery Replacement, Move the battery: crwdns2935265:018crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Apple Watch Series 7 Battery Replacement, Move the battery: crwdns2935265:018crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
  19. Apple Watch Series 7 Battery Replacement, Unfasten the battery connector bracket screw: crwdns2935265:019crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Use a Tri-Point Y000 screwdriver to remove the 1.1 mm-long screw securing the battery connector bracket.
  20. Apple Watch Series 7 Battery Replacement, Remove the battery connector bracket: crwdns2935265:020crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Apple Watch Series 7 Battery Replacement, Remove the battery connector bracket: crwdns2935265:020crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Use a pair of tweezers to remove the battery connector bracket.
  21. Apple Watch Series 7 Battery Replacement, Disconnect the battery cable: crwdns2935265:021crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Apple Watch Series 7 Battery Replacement, Disconnect the battery cable: crwdns2935265:021crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Use a spudger to disconnect the battery cable by prying the connector straight up from its socket.
  22. Apple Watch Series 7 Battery Replacement, Remove the battery: crwdns2935265:022crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • If you're reusing your old battery, you can reuse the existing adhesive to secure the battery during reassembly.
    • During reassembly apply new adhesive where necessary after cleaning the relevant areas with isopropyl alcohol (>90%).
If possible, turn on your device and test your repair before installing new adhesive and resealing.
For optimal performance, calibrate your newly installed battery after completing this guide.
crwdns2935229:020crwdne2935229:0
Dominik Schnabelrauch
crwdns2935283:011/23/16crwdne2935283:0
235,502 crwdns2915208:0crwdne2915208:0
crwdns2935297:0682crwdne2935297:0
Staff
crwdns2931471:0119crwdne2931471:0
crwdns2935297:021,011crwdne2935297:0
crwdns2947412:09crwdne2947412:0
Is it still waterproof after that? I swim daily. Watch is 2.5 years old doing great but the battery is at 76%.
Will the adhesive on the screen seal back up good enough?
Matt Reason - crwdns2934203:0crwdne2934203:0
Hi Matt,
retaining water resistance after the repair depends on how clean the mating surfaces are and how accurately the adhesive is reapplied. Your device will lose its factory-given IP (Ingress Protection) rating. Personally I wouldn‘t advise to go swimming with the watch after resealing it with tape.
Dominik Schnabelrauch -
if the socket that the battery plugs into breaks, is that something worth paying to fix, or should i just buy a new watch?
river D - crwdns2934203:0crwdne2934203:0
will battery health show 100% after the replacement battery is installed? or will it still show service recommended? thanks!
joseetan - crwdns2934203:0crwdne2934203:0
Accidentally peeled the glass off instead of the entire display. Will I need to replace the display now or can the glass be affixed again?
kevlar - crwdns2934203:0crwdne2934203:0
Can you use iFixit's jimmy tool (Jimmy) instead of the curved razor blade to pry open the case?
Aaron - crwdns2934203:0crwdne2934203:0
After replacing the battery half of my touch screen doesn't work anymore... Is this most likely caused by a bad connector or is something really broken?
Robert - crwdns2934203:0crwdne2934203:0
crwdns2936751:024crwdne2936751:0 187
crwdns2936753:07crwdne2936753:0 1,577
crwdns2936753:030crwdne2936753:0 6,040
crwdns2942667:0crwdne2942667:0 102,544
