Back Glass
crwdns2933313:01crwdne2933313:0 crwdns2934263:00crwdne2934263:0 |
Find my iPhone problem |
crwdns2933307:0crwdne2933307:0 crwdns2934263:00crwdne2934263:0 |
تكرا الانهيار والكتابة المفرطة على القرص |
Lining on Display falt |
Where to buy rear camera glass? |
- iFixit Precision 4 mm Screwdriver Bit
- Spudger
- iOpener
- Tweezers
- iFixit Opening Picks (Set of 6)
- Suction Handle
- Microfiber Cleaning Cloths
- iFixit Precision Bit Driver, Aluminum
- Heat Gun
- P2 Pentalobe Screwdriver iPhone
- Tri-point Y000 Screwdriver
- iFixit Safety Glasses
- Utility Scissors
- IA-3952 - Max Professional Consumable Isopropyl Alcohol
A3256 US, A3522 CA/MX/JP/SA, A3523 Global, A3524 China
Background
The iPhone 17 Pro was announced on September 9th, 2025 alongside the iPhone Air, 17, and 17 Pro Max. It features a complete redesign compared to the 16 Pro, with a large aluminum unibody coupled with a small "Ceramic Shield" glass pane underneath the enlarged camera "plateau." Similar to the last two generations, it has an Action button above the volume buttons and a Camera Control button on the right edge. It also features improved Ceramic Shield 2 screen cover glass that's more scratch-resistant.
Notably, the thermal system has been redesigned to have a vapor chamber to move heat from the new A19 Pro Chip into the aluminum unibody. The screen size remains the same as the previous generation at 6.3 inches, but the 17 Pro has better outdoor brightness and anti-reflection. The front camera has improved to be 18MP with a new "Center Stage" design for taking selfies. The rear cameras have all been upgraded to 48 MP Fusion. The optical-quality zoom now supports up to 8x (compared to the 16 Pro's 5x).
It's available in Cosmic Orange, Deep Blue, and Silver and starts at $1,099 in the United States.
Identification
You can identify the iPhone 17 Pro by the model number printed inside of the USB-C charge port.
- A3256
- A3522
- A3523
- A3524
You can also find the model number through the phone's UI by going to the Settings app and navigating to General > About. Tap on the number listed in the Model Number section and it should change to a format that looks like the numbers above.
Additionally, Apple offers a quick online tool to help identify your devices: Identify your iPhone model.
The iPhone 17 Pro features a 6.3-inch (diagonal) flat glass screen, thin black bezels, a pill-shaped, black "dynamic island" at the top of the screen, matte back glass with a glossy Apple logo, and aluminum side rails. Its camera "plateau" also reaches across the top left and top right edges of the backside of the phone. The 17 Pro has a small cutout for the Ceramic Shield glass pane underneath the rear cameras.
Volume controls and the Action Button can be found on the left edge, while the power button and Camera Control button are situated on the right. Three cameras protrude from the backside. This model has no home button.
The iPhone 17 Pro can be differentiated from the iPhone 17 Pro Max by its smaller screen (relative to the 6.9-inch screen on the Pro Max model).
The iPhone 17 Pro can be differentiated from the previous generation iPhone 16 Pro by its much larger camera plateau and aluminum unibody with a small Ceramic Shield glass pane in place of an entirely glass back cover.
Technical Specifications
Dimensions: 150.0 × 71.9 × 8.75 mm (5.91 × 2.83 × 0.34 in)
Weight: 206 g (7.27 oz)
Water Resistance: IP68 (maximum depth of 6 meters up to 30 minutes)
Colors: Cosmic Orange, Deep Blue, or Silver
Operating System: iOS 26
Processor: A19 Pro chip
- 6‑core CPU with 2 performance and 4 efficiency cores
- 6‑core GPU with Neural Accelerators
- 16‑core Neural Engine
- Hardware‑accelerated ray tracing
RAM: 12 GB LPDDR5X
Storage: 256 GB, 512 GB, or 1 TB
Battery: 16.57 Wh, up to 33 hours of video playback
- Qi2 wireless charging up to 25 W
- MagSafe wireless charging up to 25 W
Ports: 1x USB-C connector
- Wired charging up to 40 W
- Reverse charging of accessories
- DisplayPort
- USB 3 data transfer (up to 10 Gb/s)
Display:
- 6.3-inch “Super Retina XDR” OLED
- Ceramic Shield 2 glass technology
- Multi‑touch
- Haptic Touch
- 2622 × 1206 pixel resolution (460 ppi)
- ProMotion adaptive refresh rate (1-120 Hz)
- 2,000,000:1 contrast ratio (typical)
- True Tone
- P3 wide color gamut
- 1000 nits max brightness, 1600 nits peak (HDR), 3000 nits peak (outdoor), 1 nit minimum
- Fingerprint-resistant oleophobic coating
- Dynamic Island
- Anti-Reflective Coating
Pro camera system:
- Main module
- 48 MP "Fusion"
- 24 mm, ƒ/1.78 aperture
- Sensor-shift optical image stabilization (OIS)
- Autofocus with 100% Focus Pixels
- Enables 12 MP 2x optical-quality zoom
- 4K120 video recording
- Ultra-wide module
- 48 MP "Fusion"
- 13 mm, ƒ/2.2 aperture
- Autofocus with Hybrid Focus Pixels
- 120° field of view
- Telephoto module
- 48 MP "Fusion"
- 100 mm (4x), ƒ/2.8 aperture
- 3D sensor-shift optical image stabilization (OIS)
- Enables 12 MP 8x optical-quality zoom
- "Tetraprism" design
"Center Stage" selfie camera with Face ID:
- 18 MP
- ƒ/1.9 aperture
- 4K60 video recording
- Retina Flash
- Ultra-stabilized video
- Smart HDR 5
- Dual Capture
- 4K Dolby Vision video recording at 24 fps, 25 fps, 30 fps, or 60 fps
- 1080p Dolby Vision video recording at 25 fps, 30 fps, or 60 fps
- Cinematic mode up to 4K Dolby Vision at 30 fps
- Slo-mo video support for 1080p at 120 fps
- Time‑lapse video with stabilization
Sensors:
- Face ID
- LiDAR scanner
- Barometer
- High dynamic range gyro
- High-G accelerometer (Crash Detection)
- Proximity sensor
- Dual ambient light sensors
Wireless Connectivity:
- Apple N1 Wireless Networking Chip
- 802.11be Wi‑Fi 7 with 2x2 MIMO
- 5G, sub-6 GHz and mmWave (all models)
- Gigabit LTE with 4x4 MIMO and LAA (all models)
- Bluetooth
- Second-generation Ultra Wideband chip
- Thread networking technology
- NFC with reader mode
- Express Cards with power reserve
