crwdns2934263:02crwdne2934263:0
crwdns2934263:06crwdne2934263:0
crwdns2934263:05crwdne2934263:0
crwdns2934263:03crwdne2934263:0
Background and Identification
Power drills are tools primarily used to create holes or drive fasteners into materials and are essential tools in various settings including construction, woodworking, and metalworking. Corded drills receive power through an electric cord while cordless drills use rechargeable battery packs.
Corded Drills
Corded drills refer to power drills requiring a physical, corded connection to a power outlet. Corded drills include a grip handle, trigger, motor housing, and chuck. The chuck is the mechanism that secures the drill bit. Corded drills provide consistent power but require an outlet and cord.
Cordless Drills
Cordless drills use rechargeable lithium-ion or nickel-cadmium batteries instead of a cord for power. Cordless drills first appeared in the 1960s and 1970s using 7.2V batteries but now commonly use 18V or higher batteries that can produce as much torque as a corded drill. Cordless drills provide flexibility and portability but require battery charging and replacement. The battery pack is located in the base of the grip. Cordless drills have similar features to corded drills like a chuck, trigger, and reverse switch.
Parts of a Power Drill
• Power source: cord and plug or rechargeable battery pack
• Chuck: secures the drill bit, tightened with a chuck key
• Trigger: activates drill rotation and speed
• Reverse switch: controls drill bit spin direction (forward or reverse)
• Drill shaft: contains the motor and rotates the chuck
• Drill bit: inserted into the chuck to make holes in materials
To improve the performance and lifespan of a power drill, it is useful to understand how to identify issues and repair or replace parts. Make sure to disconnect the power source before attempting any repairs. The chuck, power source, trigger, or reverse switch are common parts that may need repair or replacement over time. With regular maintenance, a quality power drill can last many years.
Troubleshooting
Some common issues and resolutions include:
Additional Information
Kristen Gismondi
crwdns2935283:011/12/14crwdne2935283:0
109,284 crwdns2915208:0crwdne2915208:0
crwdns2935297:0271crwdne2935297:0
Staff
crwdns2935297:072,401crwdne2935297:0
crwdns2936751:024crwdne2936751:0 82
crwdns2936753:07crwdne2936753:0 531
crwdns2936753:030crwdne2936753:0 2,628
crwdns2942667:0crwdne2942667:0 72,603
