Brother PT-D210 Won’t Turn On After Inserting New Batteries
Hi everyone,
I just got a Brother PT-D210 label maker, and I’m having trouble getting it to work. I installed a fresh set of AA batteries (6 in total), but the machine either won’t turn on at all or only powers on for a second before shutting off.
Here’s what I’ve tried so far:
  • Used brand new alkaline batteries (tried different brands too)
  • Checked the battery compartment for any dirt or corrosion – it looks clean
  • Made sure all batteries were installed in the correct direction
  • Pressed and held the power button firmly
I haven’t tried using a power adapter yet since I don’t have the original one. I’m wondering if a 9V 1.6A adapter with center-positive polarity would work as a replacement.
Has anyone had this issue before? Any suggestions or fixes I could try? I’d really appreciate your help!
Thanks in advance!
The Brother TZe labelers are sensitive to the batteries used - I know this all too well, given I have a D400 and a factory refurb D610BT I bought now to beat the tariffs and run the larger 24mm tapes, given they are already in the US and refurbished here. You need to use a good battery like Energizer or NiMh rechargeable like Eneloops; otherwise, they do not take well to cheap no-name/store brand batteries. If you are using a good battery, check the terminals for corrosion, and if you see any, clean them with a wire brush. That's where I would start.
If it persists, take the unit apart and look for any wiring issues or internal corrosion.
ZZ S-GT3-AD crwdns2934231:0crwdne2934231:0
crwdns2936753:030crwdne2936753:0 72
crwdns2942667:0crwdne2942667:0 302
