The Oblo is part of the first series of the Nescafé Dolce Gusto, an espresso machine/coffee capsule system from Nestlé, manufactured by Krups. It's easily recognized by its round shape and its hot/cold manual toggle stick. This device is also known as Oblo KP110.
The machine switches off when starting
The heating element works. The pump works fine with cold water, but when I switch over to hot, the whole machine shuts down after about 1 second. I have tried descaling, although not easy to do with so short pump bursts. Any ideas?
My idea: because the fault appears when heating, the heater has a electrical short. Open the machine and find the heater. You can measure its resistance, it should be around 40 Ohms for a 230 V machine. If not, replace it.
Another possibility: the issue is a broken capacitor on the motherboard, find the motherboard. The capacitor should look like these e.g. in Nespressos. Replace it, (or both, If there are more) hopefully this will do the trick.
crwdns2886500:0Nespresso CitiZ Capacitorscrwdne2886500:0
crwdns2930805:0crwdne2930805:0
Nespresso CitiZ Capacitors Replacement
crwdns2934079:0crwdne2934079:0
crwdns2937801:0crwdne2937801:0
crwdns2886500:0Dolce Gusto Oblo Gasket of the water tank connector assemblycrwdne2886500:0
Dolce Gusto Oblo gasket of the water tank connector assembly replacement
40 minutes - 1 hour
Thanks VauWeh, it was the capacitors. I changed them a couple of years ago, but the symptoms then were different (must have been the other one, there are two) so I didn't think that was the problem. Anyway - it works - hurray!
Congratulations! Repair is war on entropy!
Olle crwdns2934231:0crwdne2934231:0
crwdns2936753:07crwdne2936753:0 33
crwdns2936753:030crwdne2936753:0 112
crwdns2942667:0crwdne2942667:0 738
