Repair guides and disassembly information for Apple's 6th generation 12.9" iPad Pro. Released October 18, 2022.
possible switch from usb to lightning
can I swap out the USBC port with a lightning port for my iPad Pro 12.9 6th gen
I have had to replace it twice for shorting out and never had to replace the lightning port in my older model
if possible what should I order
I don’t think that’s possible as the physical connector is not the same between the USB-C and lightning port as well as the protocols running within the connector is very different.
The physical USB-C interface is what Apple used with its ThunderBolt-3/USB-C-4 interfaces. Different models still use different parts as Apple loves changing things under the hood.
While this won’t fix the damaged USB-C port on you iPad. This might offer a way to minimize the damage Apple USB-C to Lightning Adapter
Are you working in dusty/wet areas?you might want to get a USC-C silicone port plug to protect the iPads port.
mark miller crwdns2934231:0crwdne2934231:0
crwdns2936753:030crwdne2936753:0 9
crwdns2942667:0crwdne2942667:0 33
