Released September 20, Apple's mainstream 2019 iPhone comes with a 6.1" LCD touchscreen, dual cameras, and six available colors. Successor to the iPhone XR.
Restarting every 3 minutes PRS0
My iphone 11 is restarting every 3 min. Im not fluent in english, sorry.
I had put it on assistance to fix the power button, he came fine. 2 months post i accidentally dropped him in a pool and he instantly turned off. Another guy tried to replace the battery and flex cable but didnt worked.
Heres the panic full
This is an extremely common problem, especially on iPhone 11. The PRS0 sensor refers to the pressure sensor" which is on the charge port flex cable. So that's where I would start. It's especially common with liquid damage since it's on the bottom edge of the phone by the microphone grille, where water could get in.
Getting a high quality replacement cable is a must with these. Lower quality cables are likely to have the same issue.
I am going to assume that the flex cable that was replaced already was the power button cable since you mentioned the power button wasn't working? (Just making sure I mention things that haven't been tried already). But correct me if I'm wrong.
crwdns2886500:0Replace a lightning connector assembly compatible with the iPhone 11. Includes the flex cable, logic board connector, lightning connector socket, and one microphone. Part #821-02037.crwdne2886500:0
crwdns2934075:0crwdne2934075:0
iPhone 11 Lightning Connector Assembly
$24.99
Hi where you able to fix it? I have the same problem
conta vava crwdns2934231:0crwdne2934231:0
crwdns2936751:024crwdne2936751:0 9
crwdns2936753:07crwdne2936753:0 70
crwdns2936753:030crwdne2936753:0 307
crwdns2942667:0crwdne2942667:0 1,567
