Battery has X, Mac Hibernates
Hey guys, this Mac has been giving me problems recently. The battery is the menu bar has an X on it. Click the battery icon and it says "No batteries available. Power Source: Power Adapter." Of course, the battery is installed. Recently, I was able to plug in the Mac, and then connect the battery while the Mac was running. At that point the Mac recognized the battery and it began to charge. It got all the way to 60% and stopped charging and went back to X in the menu bar. Then, after playing with the battery some more, the Mac started running on battery power. I drained it from 50% to 20% and charged it again, no problem. Then, upon sleeping overnight, the Mac went into a state of hibernation. I had to reconnect the power adapter and that's when the Mac woke back up; X on battery. Ever since, the Mac runs on the power adapter, and simply sleeps when on battery power. So, the Mac undoubtedly has power from the battery, it just seems to refuse to recognize it.
I have tried all the basics: NVRAM Reset, SMC Reset, Master Reset, Hard Reset, etc. to no avail.
Thanks in advance for any help!
Here’s a picture of the Coconut Battery while the X is in the Menu Bar: basically no help.
When playing around with the batter the Mac eventually recognized it:
Try going to finder / preferences / sidebar / enable under icloud the macbook name / then go to the location of the HDD / library / Preferences / and delete the 3 items:
com.apple.powerlogd
com.apple.PowerManagement & com.apple.Power***
Empty the trash. Restart. Charge it full..... run a video on repeat all night so it fully drains the battery, then full charge plus 2 hours and all should be fine :) This is another way to reset any battery status messages. But if a fresh install didn't fix it then fearthere is another issue at play....
Hope it works for you, it did for me on many different batteries that were still in good charging capacities.
@livfe - I know this is not software related, simply because I just reinstalled Mac OS X Lion with the battery firmware upgrade. Still had the same issue. But, I recalibrated the battery, and I haven't had any issues. So... I think the Mac is fine now!
What does CoconutBattery show you? post a snapshot here so we can see. You likely need to get a copy of the older release for this older system. Contact Chris directly with your OS version, his contact info is on at the bottom of the link.
crwdns2944067:010crwdne2944067:0:
@danj - Yep, I'll need to contact Chris. Coconut Battery requires macOS Sierra or newer. This Mac is trucking on Mac OS X Lion :P
I was going to get Coconut Battery beforehand, but I saw it couldn't run on this particular Mac. I didn't know I could contact directly, so thanks for that! I'll wait to see if I can even get the app to run.
Okay, I Googled older version of Coconut Battery
I actually think I just need a Logic Board replacement
@jadonlyon - The second imager shows its charging! So what ever you did appears to have solved things. Let the system charge up fully over night and post a fresh CoconutBattery output. You may just have had a loose connection or a bit of dirt/oxidation that was messing you up.
Sometimes the battery contact block breaks!
> MacBook Battery Connector/Sleep Sensor (non-Energy Star)
> MacBook Battery Connector/Sleep Sensor (Energy Star)
And here's the guide to replace it MacBook Core 2 Duo Battery Connector Replacement
@danj - So, I though that maybe the connector was loose or something, and now the battery has started working just fine. Strange problem. I did what @livfe told me to do, calibrate the battery, and I haven't had any issues. It makes me think the battery was almost stale if that makes any sense. After talking with the owner, he did mention he hadn't charged the battery for an extremely long time. Maybe the battery just needed some TLC. Either way, I think the issue has been solved. I wish I had another battery with me just to pop it in the Mac and see what would happen. As for now, I think the Mac is okay!
crwdns2934275:05crwdne2934275:0
Jadon Lyon crwdns2934231:0crwdne2934231:0
crwdns2936753:030crwdne2936753:0 4
crwdns2942667:0crwdne2942667:0 95
