audio jack not working
repairing the audio jack - what do i have to remove to access and repair the audio jack. It no longer provides an audio signal to headphones plugged into it.
I would just get a USB-A DAC adapter like CableCreation USB Audio Adapter as replacing the iMac headphone port is a lot of work as you need to take the logic board out to gain access to the port which is glued to the case so you can get a heat gun to it to soften the glue. Follow this guide iMac Intel 21.5" EMC 2889 Logic Board Replacement and here’s the needed part Headphone Socket and Cable
Thanks for providing bot a practical answer (which I will go for) as well as a link to the full solution which looks a bit difficult for me
crwdns2936753:030crwdne2936753:0 3
crwdns2942667:0crwdne2942667:0 110
