The De'Longhi BCO430 coffee center is a combination pump espresso and 10-cup drip coffee machine with frothing wand, silver and black.
There fog in my timer
Hello I made a cappuccino and I think some water spilled to the clock and is now foggy how do I fix it ?
Update (10/08/2022)
Can you see the images? not sure if it got uploaded properly
Update (10/08/2022)
Did these images come ok?
Hi
Unfortunately there aren’t many options
You could leave it in a very dry environment until the moisture drys up
Or you could take it apart and see what the issue is from the inside(eg broken seal)
Unfortunately there aren’t many guides on taking it apart so if you decide to take it apart I can try and help guide you if you would like
Hopefully this helps
Any questions please ask
crwdns2944067:08crwdne2944067:0:
Can you help me with replacing the boiler lid on this one? I am not able to figure out how to expose the boiler fully so that I can replace it. I am able to access it from the top, but that will not help me remove the boiler. Thanks in advance.
@valchrisfamily
If you can upload some photos of what stage of dissasembly you are at using this amazing guide I can try and guide you
Adding images to an existing question
Uploaded 4 pics. The last one shows a close up
Of the boiler where the water input nut is broken and needs to be replaced.
Also - I did open the bottom as on the video. It the video was solving a problem with the drip coffee maker. I could not find a way to open the espresso side of things.
Thanks for any tips.
@Valentine Christopher
Thanks for the images(they all came through just fine)
Let’s start by removing the 4 screws on the right side of top of the machine to see if that uncovers anything
(Just to let you know I haven’t actually worked on this specific device ,iv only ever worked on things similar to it, so I’m just using my repair knowledge and priory experience for these sorts of devices)
These coffee makers often are similar. Compare to Saeco Magic Capuccino SIN017 Boiler ausbauen and Starbucks barista , perhaps it helps. Good luck!
crwdns2886500:0Starbucks Baristacrwdne2886500:0
crwdns2930805:0crwdne2930805:0
Starbucks Barista Teardown
crwdns2934079:0crwdne2934079:0
crwdns2937801:0crwdne2937801:0
crwdns2886500:0Saeco Magic Capuccino SIN017 Remove boilercrwdne2886500:0
Saeco Magic Capuccino SIN017 Boiler Removal
Pics attached - this is how far I could get
Update (10/08/2022)
Update (10/08/2022)
liluet_hernandez crwdns2934231:0crwdne2934231:0
crwdns2942667:0crwdne2942667:0 421
