Repair and disassembly information for the second-generation iPhone SE that was announced and released in April of 2020.
Device not closing all the way after screen replacement
Heyo
Recently replaced my device's screen after accidentally breaking the cables when replacing the battery (ooooopsies |:-/ ). Anyway, now the device won't close all the way. I don't get that nice crunch when trying to close it up. It slides in fine, but it doesn't actually attach itself. Any suggestions?
Edit: Right now my plan is just to get one of those cases with a front portion.
I'm pretty sure this will work, but I'm hoping to use this phone for another 2 years before I have to buy another one lol.
Did you use display ashesive?
I tried to, but it got messed up immediately.
Hi
Did you make sure to slide the top on first as it need to latch or hook onto the top part of the phone
Also have you tried removing the battery and seeing if it fits?
Also if you follow this amazing guide and upload some photos we can get a better idea of what going on
Adding images to an existing question
Hopefully this helps
Any questions please ask
Check around the adhesive for screws, glass or dirt. Also check the silver rectangular chip on the screen isn't catching on the board.
Ensure all screws are in the correct position and tightened sufficiently. Note that a screw sticking out could be causing this issue.
Next, check for any damage to the body of the phone, slightly bent? Corners caved in slightly?
Further, check that the screws in the side of the screen, holding the heat shield, are in straight and fully. Check the brackets on the side aren’t bent, if they are: when going to push the screen down, carefully use a spudger to push them inside the phone slightly
Finally, ensure the new battery is properly installed, the adhesive isn’t too thick and that it isn’t swollen already. Although rare, I have received faulty batteries that come swollen and cause this issue.
Send us a picture of where it isn’t going down, we may be able to diagnose from that.
The issue is that it’s not going down anywhere. That’s why it’s so weird.
Sounds like the screen you have isn't the correct one for your phone. I'd double check the phone model and screen to see if they are both compatible
Ethan Johnson crwdns2934231:0crwdne2934231:0
crwdns2942667:0crwdne2942667:0 433
