Guides for the Wi-Fi version of the iPad Mini 4—model A1538. Announced on September 9, 2015, the iPad Mini 4 is the successor to the iPad Mini 3.
iPad Mini stuck at black screen, and shows garbage display
A friend asked me to diagnose his iPad. My friend says it looks like it turned off and it showed garbage display before turning off, then it shows a black screen. When pressing the lock button, I can see the backlight turn on and off, but nothing is displayed on the screen. I also noticed that the left part of screen is slightly lifted, I think its due to a battery swelling. Is the display broken because of the swelling battery?
Update: I was able to turn the iPad on again with the lock screen showing up, but after I pressed the lock button, it showed garbage display, then went black screen again. I was not able to let it go to lock screen again, I can only see the backlight turn on or off if I press the lock button.
Book yourself into your nearest Apple store, they will reset the IOS for you and correct this error for free
is part of the guarantee when you purchased the product, if it is determined that you did something to cause this like trying a jailbreak or some modification then they will charge you,
but usually it can be fixed for free, just call the store, and book an appointment with a tech, at your local apple store, and bring along your current login details.
they will fix this error for free.
if any internal replacements are needed like battery swelling as you suggested
they will let you know what the go is, and if and how much it will cost, but usually apple guarantee their products, and they usually fix or replace things for free if it was no fault of your own.
My friend already had it sent for repair but he was told that the mainboard is busted, but I doubt that since I was able to put the iPad to DFU mode and my PC with 3uTools recognized it. He also wanted to backup his data, if possible, before resetting the iPad.
Myles Earvin Uy crwdns2934231:0crwdne2934231:0
crwdns2936753:030crwdne2936753:0 9
crwdns2942667:0crwdne2942667:0 168
