Repair guides and disassembly information for the 14-inch MacBook Pro released in October of 2021, featuring Apple-designed M1 Pro and M1 Max SoCs. Model A2442.
Is this a broken battery connector?
I spilled some liquid on my MacBook Pro 14” and opened it to disconnect the battery and didn’t realize that the cable right above the battery screw had a latch that was meant to be lifted to remove the cable, didn’t seem to take much force to lift but now it seems to have no connection am I SOL at this point? If there was a spare part for the cable that seems to be the only thing messed up if I could manage to remove the piece still underneath the latch.
Does anyone have any info on this?
The cable its self looks OK with the limited view you have here. As you appear to have more of an issue with getting the cable reconnected within the ZIF connector.
Review Step 11 in this guide MacBook Pro 16" 2019 Battery Replacement This is the same cable but routed differently in the 16" system. Basically you need to carefully lift the latch to release the clamping tension then feed the cable in making sure its square and fully pushed in.
Thank you so much, after taking a closer look I could see that the cable was in fact still intact, I just had to peel back the connections from the cable and was able to insert it into the connector above the battery. Thanks again, I really appreciate it
Jesus Bautista crwdns2934231:0crwdne2934231:0
crwdns2942667:0crwdne2942667:0 978
