Restore battery data without original battery
Hello I wanted to ask can you restore battery health without original battery? The message I know we can't take it out cause I don't have the original
Taking the gas tank out of your car only to put it back because its empty won't work either ;-{
Batteries over time break down or wear out, taking them out and the putting it ban won't change anything.
If you have a Mac you could plug it into it and then using a program like CoconutBattery getting the full version will allow you to check your battery a bit better than what Apple or many on phone apps offer and if the phone won't turn on it might also work.
No I mean that I have a phone se without original.battery , and doesn't show battery health and saying battery is not genue, so can I restore battery health without original.battery? Like true tone without original display with qianli device
@ibitaz - Bad battery then! Some batts are not compliant to what Apple needs for data input from the battery.
There is a small micro-controller chip within the battery which has programing to tell the phone what's happening within the battery. Either it's not programed correctly or the connection to the logic board is bad or missing (cable).
crwdns2936753:030crwdne2936753:0 4
crwdns2942667:0crwdne2942667:0 485
