Repair guides, support, and troubleshooting information for the first 13-inch MacBook Air to feature Apple's ARM-based M1 SoC (with an 8-core CPU and up to an 8-core GPU). Released in November 2020 and identified by model numbers A2337 or EMC 3598.
Black edge on screen
I have a 13” MacBook Air (A2337). M1 system
Appeared on screen black edge, part of screen not visible. How can i fix it ?
Can you take a picture using your iPhone so we can see the damage Adding images to an existing question
It looks like you have in fact two display issues the vertical line along the edge and the cross-hatch across the full display. Both of these issues is related to the display assembly. The first is what we call a TAB error which is when the glass LCD panel and the ribbon cable is bonded to it to carry the signals from the T-CON board to the LCD panel.
The second issue is a likely a noise issue within the T-CON
Given the age of your system I would see if Apple will cover it under an extended warranty as long as you hadn’t created the issue (something heavy sat on the system and/or liquid spill). Otherwise its an expensive repair as the full display would need to be replaced MacBook Air 13" (A2337, Late 2020) Display Assembly and here’s the guide MacBook Air 13" Late 2020 Screen Replacement
crwdns2886500:0Replace a display compatible with the model A2337 late 2020 13" Retina MacBook Air 13" laptop. Includes the 2560 x 1600 pixel LCD 13.3" screen, aluminum case, camera.crwdne2886500:0
crwdns2934075:0crwdne2934075:0
$399.99
Roro Alsunusi crwdns2934231:0crwdne2934231:0
crwdns2942667:0crwdne2942667:0 471
