Use this guide to replace the screen (aka the display) in a Late 2020 MacBook Air (M1).
crwdns2935267:0crwdne2935267:0Magnetic Project Mat$19.95
If your MacBook is running Big Sur v11.1 or later, disabling Auto Boot may not work. You can proceed normally, but make sure to disconnect the battery as soon as you're inside.
Use a P5 driver to remove the following screws:
Two 7.9 mm screws
Two 7.3 mm screws
Six 2.6 mm screws
Wedge your fingers between the display and the lower case and pull upward to pop off the lower case.
Remove the lower case.
Set it in place and press firmly to engage the two hidden clips underneath. You should feel and hear them snap into place.
Use the flat end of a spudger to pry up and unlatch the metal locking arm on the battery connector.
Lift straight up on the metal locking arm to pull the battery connector out of its socket on the logic board.
If necessary, push the rear, wire side of the connector into place first, then rock the front of the connector into place.
Use a T3 Torx driver to remove the 1.4 mm screw securing the antenna cable cover.
crwdns2935267:0crwdne2935267:0Tweezers$4.99
Use a pair of tweezers to grip the antenna connector close to its base.
Pull straight up to disconnect the cable.
Repeat for the second antenna cable.
Use a T3 Torx driver to remove the two 1.5 mm screws securing the display cable connector cover.
Remove the display cable connector cover.
Use the flat end of a spudger to pry the display cable connector straight off of the antenna board to disconnect it.
Use a T5 Torx driver to remove the six screws securing the antenna bar:
Four 7.4 mm silver screws
Two 4.7 mm black screws
Insert the pointed end of a spudger into the gap between the antenna bar and display hinge.
Pivot the spudger against the hinge to pry up the end of the antenna bar.
Repeat for the other end of the antenna bar.
Use your fingers to pry the antenna bar straight up and away from the case.
Thread the antenna board through the opening in the middle of the antenna bar.
Remove the antenna bar.
Use a T8 Torx driver to remove two 5.0 mm screws from each hinge (four screws total).
With the MacBook still screen-side down, carefully lift the upper case to open the MacBook as far as possible.
Lift the MacBook up and place it on its side, with the display facing away from you.
Use a T8 Torx driver to remove the two remaining 5.0 mm screws securing the display, one from each hinge.
Carefully begin to close the display until it's at a ~90 degree angle with the upper case.
Keeping the display at a 90 degree angle with the case, move the display away from the case while holding the case still, so that the hinges slide out the bottom of the case.
Remove the display.
Once you've completed your repair, your laptop may not power back on until connected to power.
crwdns2935229:0209crwdne2935229:0
crwdns2947412:084crwdne2947412:0
How to make the True Tone working on the screen from another air?
William Kang - crwdns2934203:0crwdne2934203:0 crwdns2950251:0crwdne2950251:0
The screen that your replacing should have true tone built in, it is a part of the display.
h_man08 - crwdns2934203:0crwdne2934203:0 crwdns2950251:0crwdne2950251:0
Like iPhones does the display need to be programed to allow true tone to work?
Zuhayr Muse - crwdns2934203:0crwdne2934203:0 crwdns2950251:0crwdne2950251:0
Just did the replacement! Was a breeze, just be careful not to over tighten any of the screws past a firm twist. Accident broke the head off a 1.5mm screw using a T3 bit. Didn’t affect the plates ability to cover or apply a firm press downwards, but a unfortunate thing nonetheless.
Caleb Stewart - crwdns2934203:0crwdne2934203:0 crwdns2950251:0crwdne2950251:0
After Replacing the display, the new display is dim and the F2 does not brighten the screen. Any resolution to this issue?
Already reset NVRAM and PRAM.
Beto Beto - crwdns2934203:0crwdne2934203:0 crwdns2950251:0crwdne2950251:0
