airport/Blue tooth card replacement
The airport/Blue tooth card Im looking for is part number 661-4766. IFixit parts is suggesting a similar but different part for the 2011 MacBook. Will this replacement work?
The 2009 15” MacBook Pro AirPort board, Apple P/N 661-4766 sits within the Clutch cover with the antennas. It only offers WiFi as there is a second board for Bluetooth.
The 2011 15” MacBook Pro uses a combo board which is also larger AirPort, Apple P/N 661-5867 and sits within the main case
You need to use the correct part for your system.
crwdns2886500:0Replace the 802.11n Airport wireless internal card for MacBook Unibody (Model No. 1278) to fix wireless connectivity issues on your device.crwdne2886500:0
crwdns2934075:0crwdne2934075:0
MacBook Unibody (A1278) Airport Extreme Card
$79.99
crwdns2886500:0Replace a 802.11n AirPort Wi-Fi and Bluetooth Board compatible with Early 2011 to Mid 2012 Unibody MacBook Pro laptops. Part #661-5867. Model #BCM94331PCIEBT4AX.  Bluetooth 2.1.crwdne2886500:0
MacBook Pro Unibody (Early 2011-Mid 2012) AirPort/Bluetooth Board
$42.99
Unfortunately then, the iFixit site search takes me to the wrong part. Where could I find the 661-4766?
@chjowh - The link works, iFixit is just out of stock. I posted both so you could see the images of the two parts.
Here's another source 2009 802.11n Wireless Card, Apple P/N 661-4766
IFCJW crwdns2934231:0crwdne2934231:0
crwdns2936753:030crwdne2936753:0 9
crwdns2942667:0crwdne2942667:0 102
